@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
Low coolant level?
I just recently had my car in for regular scheduled service & maintenance about a month ago.
Today while I was getting my car detailed, I looked into my engine bay and noticed that my coolant level was near "Low". Is this normal/acceptable? Should it always be at full? Why wasn't this topped up at my service appointment - I mean, I paid for it. I have some time today to go to my local dealer but wanted to get some advice form the public first. ![]() Sent from my iPhone using Tapatalk
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
#2 |
Drives: 2014 Subaru BRZ
How recently had you turned off the car? I assume you drove it to the detail location.
#3 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Its fine I will fill mine up and it always goes back down to around that level and stays there when cold.
#4 | |
@anthonysestito
Car was literally just turned off. But yeah, drove to detail shop
#5 |
#6 |
The Fail Boat
Drives: CWP S.B.
Just add a bit to be on the safe side, it's nothing to be worry about unless you are in the middle of a really long trip.
| The Following User Says Thank You to chaoskaze For This Useful Post: | brzzy (04-11-2016) |
#7 |
Let's be very clear here. That is a coolant expansion/overflow tank and does not reflect the level of the cooling system. Yes, some will need to be added if bone dry but as long as something is in it then the coolant system is not "low".
#8 |
Drives: 2005 Toyota Camry
As long as you are between low and high you are fine.
If you are paranoid, add some distilled water. -alex |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
| Should I be concerned with coolant and oil level? | B-R-Z | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-28-2014 12:03 AM |
| Coolant level when cold | GloriousJ | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-29-2013 08:03 PM |
| My oil level was low! | FRSjeff | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 12-15-2012 11:22 PM |
