Old 04-10-2016, 07:19 PM   #1
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Which part of the cooling system is this from?
I've been having overheating issues and I keep thinking it's a head gasket issue. But last time I had a bad head gasket, the oil temp shot up with the coolant temps. That isn't happening this time. I replaced the thermostat and the gasket was intact and also didn't fix the issue. I have no idea what this piece is from. It's the 3rd piece I've found while filling up my coolant tank. All the rubber is intact with the radiator cap so maybe it's the water pump? I have over 90,000 miles on her so maybe it does need to get replaced. Thanks for any info in advance. Name:  uploadfromtaptalk1460330350678.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 04-11-2016, 12:26 AM   #2
I can't get a fix on the size of that piece.
What is it sitting on..??
How about another picture with a coin to help scale it.
Old 04-11-2016, 01:42 AM   #3
texasbound972
USMC
At work right now. I'll take a picture with a quarter next to it when I get home. It's sitting on the lid of my trash can.
Old 04-11-2016, 01:52 AM   #4
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
That looks about an inch long.
Where did you find the piece? If it's floating inside the overflow tank, did you check the o-ring under the radiator cap?
aegisdrgn is offline   Reply With Quote
Old 04-11-2016, 02:05 AM   #5
texasbound972
USMC
It is about that long. I have checked under the cap and it was found in my Crawford coolant tank, not the overflow plastic tank.
Old 04-11-2016, 02:06 AM   #6
texasbound972
USMC
Oh and I'm running the 23-25psi cap from pepboys.
Old 04-11-2016, 07:22 PM   #7
Mr Nerd
Mr Nerd's Avatar
That is from your cold air box. Its the lip that meets the cold air tube, as if you were changing the air filter.
Mr Nerd is offline   Reply With Quote
Old 04-12-2016, 01:48 AM   #8
hmmmm......if so, how did it get into the coolant tank ...... ??
Old 04-12-2016, 02:06 AM   #9
Originally Posted by texasbound972 View Post
I've been having overheating issues and I keep thinking it's a head gasket issue. ............
Well, I suggest you take that piece and lay it on a piece of paper and "complete the circle" using your drawing or geometry skills.
I'll betcha you will find that the circle would "fit" your coolant/radiator cap.
If so, and the gasket has been compromised, the pressure would be decreased and the coolant temperatures would increase.
Maybe you need a new coolant/radiator cap ..... ??
Old 04-12-2016, 02:47 AM   #10
texasbound972
USMC
I'll find out from the dealership soon hopefully. Traded her in on a fucking Corolla. Just can't afford to keep dumping thousands every other month to keep it running.
All your cooling needs Evasive Motorsports Groupbuys 46 07-10-2017 05:47 PM
Found some rust on a part... what part is this, and is it a problem? flashburn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-02-2015 09:56 PM
Got hit (bumped)! Need part number for the black part of bumper. scottsampaio.com Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-25-2014 12:05 AM
Bleed air from radiator/cooling system? OnionTou Engine, Exhaust, Transmission 2 03-28-2014 08:54 PM
Magnaflow Catback Exhaust System / Part #15157 / Deepest Deal Allowed!! rickspecd Engine, Exhaust, Bolt-Ons 12 07-12-2013 11:49 AM
