#71 | |
Drives: '13 SWP ZC6 R
#72 |
Drives: 2016 Scion FR-S Release Series 2.0
Here's the wiretap fix for the door speaker issue. Let me know if it works for you too.
#73 | |
My wiring harness behind the radio: ![]() The left most connector in the picture is the OEM Audio Plus harness male connector, and the connector assembly on the right is the harness female connector plugged into the factory male connector (that previously went directly to the HU). Per the directions above, the harness male connector should have one solid blue and one blue/white wire in the 2/3 spot on the bottom row of the connector. Mine is blue and light blue, respectively. The light blue wire is connected somewhere in the wire loom but the solid blue is not connected to anything. The harness female connector has, in the same 2/3 spot, a solid blue and blue/white wire. You can see in my picture (under my index finger) that these two wires terminate with each other. The arrangement as pictured (blue and light blue connected) - and suggested above - did not fix the issue of my door speakers not working. Hopefully I'll hear back from Daniel soon so we can work out a fix...
#74 |
Sucks that didn't work for you, but I'm sure Daniel will get back to you pretty quick. Mine was for a 2016 FR-S, Reference 450Q, Pioneer Premium/NAV head unit. Looks like our wiring harnesses are slightly different. Should be simple fix, but probably different wires.
#75 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Still waiting on mine, I received an email saying it would ship out this week, right when I won't have time to install it.
#76 |
Drives: 2017 BRZ - Dark Grey Metallic
I've had the OEM Audio Plus Reference 400CF for about 3 weeks now. I held off on doing a review until I'd listened to it for a while, so as not to have "shiny and new" bias.
Install 3/5 stars I'd read that this was a simple 3-4 hour gig if you took your time. This wasn't the case for me. It took a lot longer. I started my install at about 12pm. Cleared the driveway and stripped my car as per instructions. Popping the stock tweeters out was a real pain in the ass, but not OEMs fault. I'm in Australia, so our vehicles are right hand drive. I'd previously sent multiple messages and support mails to OEM asking about the differences and got no reply. The instructions tell me to unplug the factory amp. What?!? I have no factory amp. My car is in pieces and I can't continue. I'd been supplied the US instructions which are different from the Australian ones. Our cars have no rear amp. I search the interwebs for answers and send off a few more support emails asking exactly what I'm meant to do. I've run out of sunlight at about 5:30pm, so the panels/trim go back on the car. The next day I get a reply from OEM. They supply me with the right hand drive manual as a PDF. I start the install at about 10am. I strip the car again (only half the number of panels needed to be removed this time), and plug in the unit without much trouble... until I get to the battery. The ring on the power lead is for 12mm, our battery terminals are 13mm. I hollowed out the ring a bit with a file, but then decided to just cut it and thread it down. This worked great. Unfortunately when tightening up the terminal again, my 13mm socket launched into my engine bay. It's gone... bupbow. I also have about 1m of extra power cable which is not ideal, but I'll manage. I could always trim it. Finally, everything is in except for the foot kicker panel. The OEM unit, at least the RHD version, does not give you enough cable length on the quicksync harness. Everything is taught. I pull the inch or so slack from behind the head unit and manage to squeeze the foot kick panel back on and cable tie the harness below the steering column. It's tight. Really really tight. The only thing left is to secure the sub in the boot. One of the brackets for the sub was slightly damaged, the thread would not let the bolt through. I got a power drill with an allen key attachment and worked the bracket until it would let the bolt travel reasonably. This generated a lot of heat which made the bracket brittle. Tip: when putting the rear bolt for the sub in, have your fingers under the sub - this helps the bolt hole line up. It's very easy to start screwing in only to hear the bracket fall off the frame. This is a pain in the ass because it's behind the boot carpet, but fortunately the bracket always lands within arms reach. This happened maybe 5 or so times. Anyway, with the bracket being so brittle, it ended up snapping. To get a replacement bracket is easy enough, but they are rare as hens teeth where I live. I drove to 7 different stores (with a loose sub in the back) to find a replacement bracket. Everything is in, and I'm happy. Total install time, about 10 hours. The downsides are - there is not enough slack in the quicksync harness to get my head unit out without cutting cable ties. There is not enough slack to unplug the amp without cutting my cable ties, removing the rear panel trim and pulling the lead through. I'm not liberal with cable ties - I have 2. One under the steering column, and one at the back near the earth. This unit needs another 12" on it's quicksync harness. It's stupidly tight. It's cut too short. I'm not sure if there was no demo RHD unit when they developed it and they just went off a car plan, or my harness is shorter than normal. The other slight disappointment is the rear of the sub, where the bolt attaches to the car. The actual hole in the sub does not have a flat top - so you end up damaging one side of the sub as you tighten in the bolt, and it's hard to tell how tight to go. OEM Audio were not forthcoming with information for a prospective buyer, but when you have bought their unit, they do a great job of following up queries and making sure everything is in working (and great) order. Somewhat ironic and frustrating that the prepurchase unanswered queries I had regarding right hand drive vehicles were directly related to the problems I had during the install. ![]() Sound 5/5 stars I had the stock head unit, but I ordered the OEM system with the Pioneer AVIC calibration. After setting the EQ to flat, the system sounded fantastic. Perhaps a little bass heavy, but perfect when driving. I have history as a sound engineer, music producer, and have experience with high end equipment, and a pretty sweet home theatre system. The OEM system clarity is comparable to MUCH higher cost systems. I demoed the system to my mother (mid 60s). She said the system was "clear and crisp", which made me laugh a bit, because I'd seen a review video that made me roll my eyes at those buzz words. Her boyfriend said it was very "clean". Hah! I've installed a Pioneer AVIC-F80DAB, a pair of Polk Audio 4" rear speakers ($110 AUD) and had my car sound deadened (Nitto). The sound quality is now amazing... the bass is no longer too heavy. It's perfect, stationary or moving. The sound is so good, I find myself listening to music I wouldn't normally. I love my heavy metal and psytrance, and these sound stellar, but there is something awesome about driving through hills listening to smooth jazz. I cannot say enough about how good the sound is. It's comparable to anything I've heard. The DSP magic this system has is really magic It can transport you to a concert or a studio.This system will give you goosebumps. Thanks for the awesome product OEM.
#77 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Ugh been almost a month since ordering the mid 4" upgrade with no word of when it'll ship. Anyone else waiting 30+ days?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#78 |
Drives: 2023 WRB BRZ (MT)
#79 |
Drives: 2013 Subaru BRZ Limited (Black)
#81 |
Addicted
Am I the only one? I'll e-mail first and call tomorrow if no response.
#82 |
Just call. Ext 4 gets u manager (Daniel). I'm on lik 6 week delay but got literally every single option they had and they got pushed back on strut tower option and some other supplier issues. Which is the reason for most delays
#83 | |
Addicted
#84 |
Drives: Scion FR-S
I want to listen to these speakers. I think that's the only bothering me about my car right now. I think the audio is really bad compared to my old 2002 Mercedes. It had a Bose sound system, and it was very loud and I really loved the "surround" sound it produced. Want to get that "surround" feeling in my FR-S. I can't afford the system just yet though.
| Tags |
| amp, audio, music, radio, subwoofer |
| Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 09:10 AM |
| Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 | slicktop | Miscellaneous | 1 | 07-11-2014 08:58 AM |
| WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio | YEAHdams | Want-To-Buy Requests | 0 | 07-01-2014 11:37 AM |
| FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 04:34 AM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 09:45 PM |
