| Software Tuning Discuss all software tuning topics. |
#15 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
did you alter the cranking fuel injector pulsewidth A-J also when going bigger injectors?
#16 | |
Drives: Toyota 86
I did scale them all down, but there is an easier way to do it also: The IAT cranking IPW compensation table returns a multiplier value of 1.0 across the whole table. Some definitions have the table as % compensation applied, the definition below shows a value of the multiplier returned. You can change this to suit your injectors (enter value of 0.5 for a halving of pulsewidth). The Accelerator cranking IPW compensation table works the same way: if you turn the engine over with the accelerator depressed, no fuel is delivered. Code:
<table type="2D" name="Cranking Fuel IPW Compensation (IAT)" category="Fueling - Cranking" storagetype="uint8" endian="big" sizey="5" userlevel="4">
<scaling units="Cranking Fuel Injector Pulse Width Compensation Multiplier" expression="x*.0078125" to_byte="x/.0078125" format="0.000" fineincrement=".005" coarseincrement=".1" />
<table type="Y Axis" name="Intake Temperature" storagetype="float" endian="little" logparam="P11">
<scaling units="Degrees C" expression="x" to_byte="x" format="#" fineincrement="1" coarseincrement="5" />
</table>
<description>This is the change to the 'Cranking Fuel Injector Pulse Width (ECT)', based on the accelerator pedal.</description>
</table>
| The Following User Says Thank You to ztan For This Useful Post: | ST-A (12-06-2015) |
#17 |
Master Tuner
ace man
#18 |
Drives: Toyota 86
Not so ace.
I just did some logging with that value adjusted and it didn't affect my cranking pulse like I thought it should - I'll have to do a bit more troubleshooting and for now, back to adjusting all the tables. Having said that, it may still work with values <1.0. I was trying to get increasing fuel for E% and with a compensation value over 1.0, no additional fuel was being put in during cranking. Last edited by ztan; 12-13-2015 at 02:15 AM. |
#19 |
Master Tuner
well
i rescaled my tables after the asnu 650cc upgrade (699cc in their test sheet), so i changed 228 to 699, also changed the dead time table. Then i worked all A-J crank tables down (table values / 3) but the car did not start at all, just a small cough first attempt, nothing after that so i think the plugs are wet now. then i noticed while cranking it goes from injection mode 2 (DI) to mode 1 (port) maybe we can work it out it starts on DI ?? also i noticed my MAP value was constant at 0.65bar, even if i played the throttle while cranking, so this seemed off so i replaced it with a new omni 4bar map and scaled the 3 tables to 0.831 multiplier and 0.012 offset but nothing, no starting at all. also tried the 0.825 multiplier and 0.031 offset stated in the ecutek manual, no effect. either my plugs are wet/fouled or there is something wrong. |
#20 |
Master Tuner
ok....
after some testing found a solution: revert back to stock the MRP compensation table (was set to 0 overall) 699cc inserterted into port injection tab insert correct dead times leave ALL crank tables like stock.... 4bar omni map with 0.831 and 0.012 calibration started now first crank. Last edited by ST-A; 12-12-2015 at 10:36 AM. Reason: added video |
#21 | |
Drives: Toyota 86
Which ROM are you using, and where is the MAP sensor scaling address? For A01G, the MAP multiplier is at 0x11CC20 and the offset is at 0x11CC24. You only need to adjust one set of MAP scaling values. If you're using EcuTek and your MAP sensor reads 0.65 bar despite changing 3 tables, you'll need to get the right ROM address from them. |
#22 |
Drives: Toyota GT86
As far as I know ST-A is using a G-serie OFT ROM. So that should be a A01G ROM.
send using the coffeemaker
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#23 |
Master Tuner
i'm on the 700G rom.
adresses are: scaling a - 0x1000cc scaling b - 0x1000e4 scaling c - 0x11cc20 the map sensor i had before (the denso K series) worked fine before, i just rplaced head gaskets, now i think they went because the map sensor was stuck at 0.65bar, while i was running boost on the kraftwerks sc. now with the 4bar omni and entered 0.831 and 0.012 in those 3 tables, i run stationairy at about 6.5psi / 0.44bar and when ignition on, engine not running but throttle opened 14.7psi/1bar so it is now good. |
#24 | |
Drives: Toyota 86
#25 |
Drives: Toyota 86 Turbo, Lexus NX300H
@ztan
there is plug and play data for DW450 on DW site http://goo.gl/BYHCL3 how do you think about this table? would it work for just copy and paste? I'm planning to upgrade port injectors, but in my country , there is no one can handle FR-S, so I should do my self. I'm on 10~11PSI now, and targeting 12~13PSI for future..
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
#26 | |
Drives: Toyota 86
Just be careful how your injector scaling is described in your .xml file. If in ms/ml, the value needs to go lower for bigger injectors, if cc/min, the value needs to go higher... pm me and I can send you a dropbox link to my .xml and current A01G tune. You might want to think about 700-1000 cc injectors and/or built engine if you want to go to 12-13 psi. On E85 at 10psi I'm running them at around 80% duty at redline. I'll be passing through Seoul next month. |
| The Following User Says Thank You to ztan For This Useful Post: | Yobiwan (04-08-2016) |
#27 | |
in their Excel file. injector flow scale for DW450 is 145.35 for DW700 is 80.35 for DW900 is 72.63 then I think that value is with ms/ml scale (as you said ) and Injector flow scale is 222.32 (cc/min) in my rom. so I try to solve this math =( am I going right way?
#28 | |
Drives: Toyota 86
2 Different values in RomRaider: A01G Injector flow scaling at 0x10C6B4. Default .xml defines as "2707090/x" which displays as 222.32 - this is the value that you are working off above. I didn't touch this value A01G Injector Flow scaling BRZ at 0x10C680. With scaling as per descriptor below (expression="x" to_byte="x" ; you see what the float value is stored in ROM): Stock value is 263.10, my scaling is 123.18 for DW450; 145.35 would run rich in my car at the top end. Code:
<table type="2D" name="Injector Flow Scaling BRZ" category="Fueling - Port Injectors" storagetype="float" endian="big" sizey="1" userlevel="2">
<scaling units="ESTIMATED Flow Rate - Gas Only (ms/ml)" expression="x" to_byte="x" format="#.00" fineincrement="1" coarseincrement="10" />
<table type="Static Y Axis" name="" sizey="1">
<data>Injector Flow Constant</data>
</table>
<description>This is the fuel injector constant represented with an estimated flow rating (gas only). The underlying raw value does NOT represent the injector flow rate and there is no standard for measuring the flow rate of injectors. Therefore, it should NOT be thought of as a value that is going to exactly match published rates for your injectors but as a means to get you in the general ball park as a starting point to tune from.</description>
</table>
| The Following User Says Thank You to ztan For This Useful Post: | Yobiwan (04-09-2016) |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Scaling for vortech 2.5 bar map sensor? | Frs32907 | Software Tuning | 2 | 11-08-2015 05:41 PM |
| What MAF scaling says about your intake | BuBlake | Software Tuning | 27 | 12-09-2014 05:01 AM |
| BRZEdit MAP scaling | jamesm | Software Tuning | 13 | 10-02-2013 12:43 PM |
