#3683 |
Senior Misanthrope
Would there be any negative repercussions to adding a little extra front camber at a track day?
Initial DD alignment was: -1.7* camber front -2.2* camber rear (no LCAs yet) -7.2* caster front 0.6* toe out in front 0.0 toe rear My understanding is that if I add 1* of front camber, I'll probably be closer to neutral toe on the fronts. Is this a terrible idea? |
#3684 | |
Drives: anything you let me
The more you go towards neutral/toe-in the more stable the car will behave (as far as wandering) but will be a little less responsive on turn-in. You'd be headed in the more predictable/safer direction so it's not a terrible idea. If you were going the other way it would make the car more twitchy. |
#3685 | |
Senior Misanthrope
#3686 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | jjaisli (04-07-2016) |
#3687 | |
Drives: '13 FRS - STX
| The Following User Says Thank You to strat61caster For This Useful Post: | kch (04-07-2016) |
#3688 |
Drives: 2015 AOZORA EDITION
hey csg mike which woould you prefer kw cclubsports vs eibach R2 car will see lots of track days
#3689 |
Drives: '22 BRZ
For anyone that's used RE-71Rs on track, what sort of tire pressures are you aiming for?
#3690 |
Drives: 2015 Series.Blue BRZ
I put mine at 28 cold, which was 34 hot. Couldn't be arsed to play with pressure so I ran with that all day
| The Following User Says Thank You to ScionOfHorus For This Useful Post: | DocWalt (04-08-2016) |
#3691 | |
Drives: '22 BRZ
I'm expecting the RE-71Rs to respond well to lower pressures, based on what people are setting them at for autocross. Obviously track day stuff puts more heat into tires for a longer time, which lead to my question.
#3692 |
Thanks
Ended up order so AD08R
I wanted to try 71r but seems above my level and more for time trial Would have been happy with re11a but not available AD08R closest to what I need I think any opinions feel free
#3693 | |
Thanks
I guess my car isn't prepped for the season anyway. Need alignment. Oil changes. tires. I signed up for friday the 15 at NJMP with NASA. Unfortunately I have to work the weekend so I cant do the 3 days. Also ordered some oil, AD08r and working on getting alignment. And hopefully fix my AC You gonna be there next weekend?
#3694 | |
I've seen the tires run successfully anywhere from 28 to 38 psi. Without knowing your exact setup, I'd say try to aim for 34-35 hot. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | DocWalt (04-08-2016) |
#3695 | |
Drives: '22 BRZ
Also figured I'd aim for that range of pressures hot and go from there.
| The Following User Says Thank You to DocWalt For This Useful Post: | CSG Mike (04-08-2016) |
#3696 |
Drives: Honda
Anyone have experience with running an aftermarket front grill (such as grillcraft) with an oil cooler? Could you share some temp data (with and w/out grill) if possible?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
