Old 04-06-2016, 11:56 PM   #57
Originally Posted by Wired86 View Post
Wouldn't heel toe just be:
1) Clutch in
2) brake + blip throttle (heel toe)
3) shift to lower gear
4) release clutch
So exactly what was said above, plus braking?
Reverse steps 2 and 3 and you're good. This is to rev-match and engage a target gear while threshold braking. Rev match is especially important while threshold braking because the rear wheels are already unloaded. Dumping the clutch to engine brake in a lower gear would be a fast ticket to swapping ends.
You're not going to be threshold braking anywhere except driving 10/10 on a track. Heel-toe is pointless on the street.
ADRNLNE (04-07-2016), extrashaky (04-07-2016), Wired86 (04-07-2016)
Old 04-07-2016, 12:39 AM   #58
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
what he said... I need to go to sleep
spicyricecake is offline   Reply With Quote
Old 04-07-2016, 12:43 AM   #59
Wired86
Wired86's Avatar
Drives: 2016 Subaru BRZ, Limited, MT, CBS
Okay, sounds good.
Originally Posted by softgrip View Post
Last night I took a corner that would have given me a 4 wheel power slide in the WRX. The BRZ hunkered down and massacred the corner with no loss of traction or speed.
Wired86 is offline   Reply With Quote
Old 04-07-2016, 06:43 AM   #60
extrashaky
Drives: 2014 BRZ Limited
Just wanted to add emphasis.
Old 04-07-2016, 09:43 AM   #61
Romanov
Just another BRZ owner
Romanov's Avatar
Drives: 2014 Subaru BRZ Limited MT
I heel toe downshift just to piss everyone off. #becauseracecar
Just kidding, typically I just Rev match on the street from best practice. That's just what I've learned and it helps smoothen out those downshift. Heel toe is really unessisary on the streets.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz
Romanov is offline   Reply With Quote
Old 04-07-2016, 10:24 AM   #62
Wired86
Wired86's Avatar
Update: Did this this morning while coming up to stops and it worked really well, especially when just before I got to the light and it changed green, I was already in the right gear to go!
Clutch in
Lower gear
Blip throttle
Clutch out
Also, when doing this I am really not braking at all. What if some half-wit jabroney behind me doesn't realize that I am slowing down since I am downshifting instead of coasting in with brakes and he doesn't slow down and plows into my rear? I mean I suppose I will already be in gear so that I can get out of the way, but still, there's a lot of hosers out there on the road. Lol. Should I tap the brake once while I'm downshifting just to let the simpletons know that I am slowing down?
Old 04-07-2016, 10:48 AM   #63
berkbrzfan
Drives: WRB BRZ
Over thinking the whole thing once again! If it feels right do it. If not don't.
Right!
When I learnt manual, all I was taught was higher gears for higher speeds and lower gears for lower speeds. Once you start driving more, you begin to find ways to fine tune the technique and remove the jerks and stalls. You begin to understand what needs to be done for a smoother downshift.
In fact, I didn't know what rev matching was when I first heard it. Once I read about it, I realized I was already doing it. Just that I didn't know what it was called!
berkbrzfan is offline   Reply With Quote
Old 04-07-2016, 10:50 AM   #64
ButeraFRS
Guest
Posts: n/a
Clutch in
Lower gear
Blip throttle
Clutch out
I wouldn't use downshifting as your main method for slowing down or braking for the reason you mentioned but also because it's cheaper to replace brake pads than it is to replace a clutch.
Sent from my SM-G530W using Tapatalk
Old 04-07-2016, 11:04 AM   #65
spicyricecake
I just feel safer being in gear when I'm slowing down.
I'm also the type to brake early rather later so as I'm coming to a stop I'm on the brake with different levels of pressure the whole time, and thus heel-toe to downshift during this process. I don't typically downshift to 2nd if I'm not taking a slow turn though cause that's a pain. Usually all the way to 3rd and shift into neutral is good enough.
I will say however that I do notice the braking is a lot easier with engine braking going on, and now that I'm used to it I don't like braking without it. If you're like me and like to have fun, just do it... Don't worry about saving brake pads or clutch and shit.. just replace it down the road. The point is to have fun with the car while you have it. If you're not doing #racecar stuff to have fun because you'd rather replace brake pads instead of the clutch years down the road, then you're not having as much fun on the car as you could IMO.
Granted, those that baby the car (I do too, if you could believe me) also enjoy the car to the threshold they're willing to take the risks with.
Just do what makes you happy
Old 04-07-2016, 11:15 AM   #66
Wired86
Wired86's Avatar
Downshifting makes me happy. I will still occasionally brake if need be, but I think it is likely that I will downshift most of the time just to remain in gear. I will just have to keep a close eye on the hooligans behind me. haha
Old 04-07-2016, 11:17 AM   #67
Wired86
Wired86's Avatar
Originally Posted by berkbrzfan View Post
Right!
I have way too analytical of a mind to not figure out all the technicalities and such. Haha. That's why I love engineering explained.
Old 04-07-2016, 02:03 PM   #68
Thought about this last night. It does take quite a bit of practice. Nothing wrong with practicing.
Old 04-07-2016, 03:21 PM   #69
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
I guess this is where I'm a bit ignorant mechanically, but if I'm driving to "keep the tach straight up" I will brake, clutch in, blip as I'm moving it through nuetral, grab gear, release. Everything I've read says blip and grab gear, not grab gear and blip. Wouldn't it be difficult to get into second if you didn't blip prior when at an aggressive rpm?
ajaxthebetter is offline   Reply With Quote
Old 04-07-2016, 04:00 PM   #70
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I don't think that's good emphasis, but rather just apply COMMON SENSE towards using the appropriate technique for the situation at hand.
You can't really break down a combination of simultaneous fluid actions with individual steps.
Too much reading and overthinking, OP should just get out and start practicing.
krayzie is offline   Reply With Quote
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 06:59 AM
[Poll] Preferred method to start stop on hills Koa Scion FR-S / Toyota 86 GT86 General Forum 62 02-20-2015 04:34 PM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 01:00 PM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 09:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 01:20 PM
