Old 04-01-2016, 10:22 PM   #225
Baymax86
Baymax86's Avatar
Drives: Whiteout Monogram
Originally Posted by dchan View Post
I installed it a couple of days ago, swapped pin 9 to 8, and dremelled down the pins on the bracket. Overall, for just a straight install it was pretty simple. It took maybe 30 minutes.
Nobody's really posted any instructions for a backup cam, but the trigger wire needs to be manually soldered to the correct pin on the existing harness, and I had to splice power as well. The harness I bought didn't have that.
Getting the software to work the way I wanted to is a pain though. In total, I've spent ~6-8 hours trying to get it to work the way I want it to, including flashing new roms and stuff. Most of this was me being curious, and playing around though. It's as complicated as you make it.
I installed a camera months ago and for the most part it was pretty straight forward. A little trial and error as first time ever doing one. I remember I grabbed some extra wire lying around and used that as a trigger wire, from the units harness. Just tapped it into the reverse light itself in the back. So when the light turned on so would the camera and the unit would know to show. I looked for a while for the factory reverse wire up front but could not find it. So I came up with the above. Been installed for months with no issues since.
Repinning pins 8 to 9 is that for the factory amp and door speakers?
Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
Baymax86 is offline   Reply With Quote
Old 04-06-2016, 03:11 AM   #226
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
i´m a bit confused with my HU, ter is a internal 1gb memory and a 16gb (nand flash) memory.
how can i instal my aps onto the 16gb?
Ralle109 is offline   Reply With Quote
Old 04-06-2016, 11:11 AM   #227
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
you can install it to your internal then move apps to external.
Old 04-06-2016, 01:33 PM   #228
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
But when move apps like poweramp on the SD card they eraded/ disappeared on next start? Did I miss something?
Old 04-06-2016, 05:13 PM   #229
Baymax86
Baymax86's Avatar
Stock firmware out of the box oddly only gives you a GB for apps. The custom firmware from malaysk changes partitions to allow the 16gb storage for apps and such. You'll need to install the custom firmware in order to utilize it.
Old 04-06-2016, 11:00 PM   #230
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Anyone install the latest firmware from joying site (3/28 date)? I tried updating but I keep getting an error.
Rican_D is offline   Reply With Quote
Old 04-06-2016, 11:34 PM   #231
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
I installed it, and now app to "sd" is working. No errors
But no update, full flash (from boot menu)
Old 04-07-2016, 11:58 AM   #232
Rican_D
Rican_D's Avatar
Mines is rejecting the update. Going to try downloading it again.
Old 04-09-2016, 10:56 AM   #233
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Finally had time to wire up my Joying head unit for the door speakers. Used an empty 28-pin harness (harvested from an AX-TOY28SWC adapter I stripped) to connect to my 2016 BRZ's 28pin connector and pinned position 9 with the head unit's amp turn on wire (orange wire labeled amp and coming out of the head unit). Door speakers are now functional again.
Debating if I wanna wire in my stock reverse camera. I've noticed I can reverse better and faster without it. Haha.
Pointmutation is offline   Reply With Quote
Old 04-11-2016, 12:48 PM   #234
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Ok, so I really do not know where to start with these XDA options. lol.
I would like to change out the interface to the Malysk? Unless someone has a recommended option. How do I know if my radio is compatible with the right download?
And what is up with the Weather not working on these? I have the Joying quad-core unit.
HuntingtonFRS is offline   Reply With Quote
Old 04-11-2016, 12:59 PM   #235
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Read the first page of the xda thread. Basically mcu is specific to the exact unit while firmware can be interchanged between any unit having the same processor and resolution.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
HuntingtonFRS (04-11-2016)
Old 04-13-2016, 03:12 PM   #236
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
I dont know if this is old or not. But it looks like Joying now sells 5.1 Android systems.Currently only some generic and VW ones. But I guess Toyota ones should pop up soon.
https://www.carjoying.com/android-5-...ereo-2din.html
It doesnt look like they have upgraded any of the specs , its still quad core 1.6ghz and 1GB Ram.
shadoken is offline   Reply With Quote
Old 04-13-2016, 03:14 PM   #237
B-R-Z
B-R-Z's Avatar
I'm sure 5.1 roms will be ported to our older units now that they are selling units with it. Malaysk will work his magic
Old 04-13-2016, 03:25 PM   #238
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
Looks like theres no point in me waiting any longer , I dont think any upgraded spec model is going to be coming out. Might as well hop on to these 5.1 units once they come out with a Toyota spec.
Btw is this the only plugnplay system for our Cars?
https://www.carjoying.com/quad-core-...vr-steeri.html
I would like to use something that has a slightly bigger screen and less buttons.
Kinda like this
https://www.carjoying.com/newest-joy...rror-link.html
But it looks like the dimensions are different , anyone on here tried other Universal Joying units? What brackets would I need to use?
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
