Old 04-06-2016, 02:06 PM   #15
extrashaky
Drives: 2014 BRZ Limited
I would go to 3rd gear and when u start to get below 1500 rpms follow this sequence;
Clutch in
3rd to neutral
Clutch out
coast to stop
wait at light til green
clutch in
first gear
go.
Never just hold the clutch in when not needed. That puts premature wear on your throw out bearing and out cars are notorious for having bad TOB..
Hi. Could we get the IKEA version of these instructions? Kthxbyeeeeee.
Old 04-06-2016, 02:17 PM   #16
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I'm with @Tcoat. All of the overanalyzing.
Syncros do all the work for you. Any downshift blipping/rev matching, heel toe, etc is all above and beyond the necessary.
I'd like to take a second to counter something said before though. Coasting to a stop out of gear is a good way to end up in a situation you can't get out of. Stay in gear until you're at a point that your engine can no longer sustain it, or downshift.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 04-06-2016, 02:35 PM   #17
Wired86
Wired86's Avatar
Drives: 2016 Subaru BRZ, Limited, MT, CBS
Okay. This is probably a stupid question now, but how do I downshift without rev matching? Do I just wait until the rpms get low enough by taking my foot off the gas and then shift smoothly down? Or do I just do it whenever I want and let the engine brake as long as it isn't going to redline?
Originally Posted by softgrip View Post
Last night I took a corner that would have given me a 4 wheel power slide in the WRX. The BRZ hunkered down and massacred the corner with no loss of traction or speed.
Wired86 is offline   Reply With Quote
Old 04-06-2016, 02:36 PM   #18
I have given up even presenting that fact since some people just don't seem to get the simple concept of in gear = control of the car, coasting in neutral = soapbox racer.
Be prepared for the multi "But Bro brakes are cheaper than engines" responses.
Old 04-06-2016, 02:38 PM   #19
Both, depending upon circumstances. There is no one answer to this. I could show you how to do the various different things and what circumstances they are best for but to try to reply in print is almost impossible.
Old 04-06-2016, 02:39 PM   #20
ZionsWrath
Thanks
ZionsWrath's Avatar
Synchros do work but I disagree in general. If you drive even just slightly aggressive dragging the clutch will cause jerky shifts.
IMO anyone who regularly drives "spiritedly" should rev match
Old 04-06-2016, 02:41 PM   #21
Wired86
Wired86's Avatar
Damnit. I need just sit in a car with a good manual driver for a while to learn shit. I mean, I can get from point A to point B now, but I want to get better. I want to learn these situations. Trying to figure them out for myself will work I'm sure, but it will take a long time. haha. I'm almost at 1k miles, and I still feel like such a newby.
Old 04-06-2016, 02:46 PM   #22
ZionsWrath
Thanks
ZionsWrath's Avatar
I'm 40k still feel like a nub
Learn by doing man
Old 04-06-2016, 02:49 PM   #23
SmileyMe
Drives: 2016 BRZ series.HyperBlue
Wait, so to confirm do not hold down the clutch at like a stop light? Have I been doing this wrong the whole time? ffs
SmileyMe is offline   Reply With Quote
Old 04-06-2016, 02:50 PM   #24
A few seconds fine. A few minutes no.
Old 04-06-2016, 02:52 PM   #25
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I never said your shifts wouldn't be jerky, I said it isn't necessary. I always blip and actually heel toe if I'm trying to decelerate faster. I get a lot more lash than most if I don't blip though, too many bushings and stiffeners.
No, you'll eat your throwout bearing faster. Also don't rest your hand on the shifter.
Old 04-06-2016, 02:54 PM   #26
Learn by doing man
40 YEARS and still screw up every now and then.
Old 04-06-2016, 03:01 PM   #27
bababooey
Drives: BRZ SWP Limited -6MT
occasionally when downshifting, you may miss the time window for getting back into gas smoothly. rpms drop too low and let the clutch out, the momentum will drag the engine rpm up to meet the momentum.
opposite of that is over revving by giving too much gas for given momentum.
neither are best practice situations from a mechanical perspective (it would seem) but wont grenade the car if happens occasionally.
bababooey is offline   Reply With Quote
Old 04-06-2016, 04:10 PM   #28
gled21
gled21's Avatar
Drives: White brz 2015 / 93' s13
When I drive I like to pretend my car has a sequential gear box and go through the gears, usually heel toe unless I have the room to just engine brake. My philosophy is the more comfortable you are with your car the better you will drive on the track in a sense.
gled21 is offline   Reply With Quote
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 06:59 AM
[Poll] Preferred method to start stop on hills Koa Scion FR-S / Toyota 86 GT86 General Forum 62 02-20-2015 04:34 PM
1-Bucket Method (Gary Dean) - The best rinseless wash method Obsidiank Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 09-23-2013 01:00 PM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 09:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 01:20 PM
