#44 |
Drives: 2015 Scion FRS
Talked to Albert, buddyclub's head tech and the bad news is that the coilovers will always make noise. He said because it uses a pillowball it's unavoidable, and that even his car, which also has the racing spec coilovers, makes noise... So I guess there's the answer
Sent from my SAMSUNG-SM-G928A using Tapatalk |
#45 |
Drives: S60R/Corvette
That's why I asked if you could measure it. It's probably cheap and undersized for the loads.
Sent from my ASUS_Z00AD using Tapatalk
Ryan M.
Strange Engineering Director of Suspension Development |
#46 | |
#47 |
Does anyone know if you need any new parts to use the stock tophats? Can you use the stock ones with any coilovers? and what are your thoughts on doing this?
#48 |
I'll have to check mine to see if I'm encountering the same issue.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#49 |
Drives: 86 GTS
Even high end Ohlins makes noise, so don't get too upset on your Buddyclub. LOL
[ame="https://www.youtube.com/watch?v=hQH3ZgVeHho"]Öhlins DFV knocking noise - YouTube[/ame] |
| Tags |
| clunk, coilovers, noise |
| Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc | Chase Bays | Brakes, Suspension, Chassis | 14 | 02-03-2016 09:14 PM |
| FS: Buddy Club Race Spec Coilovers | supertwo | Brakes, Suspension, Chassis | 11 | 07-26-2014 06:18 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| A few problems...but how bad are they? | deedz | Issues | Warranty | Recalls / TSB | 20 | 07-21-2013 02:27 AM |
| Gas Problems | Kelbyat07 | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 09:21 PM |
