Old 07-04-2014, 04:21 PM   #1
supertwo
Drives: 2014 BRZ
FS: Buddy Club Race Spec Coilovers
sold
I bought these Buddy Club Race Spec coilovers from a guy who was parting out his car a few weeks ago. I was going to install them when I got back from work travel in August but won't be able to. He said they were on his car for a couple thousand miles and look as such. There are the typical scratches and surface imperfections you'd expect from a set of coilovers with a couple thousand miles and a couple seasons. One of the rear bumpstops look to be torn but should be easily replaceable.
PM me if your interested
This from Buddy Club:
15 Level Adjustment
The 15 level adjustment corresponds to variety of racing stages, from Touge mountain roads to circuits. Adjustment is easy with its click adjusting dial. The dial is located on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for town use; hence, dampening setting ranges from hard to soft.
Single tube type shell case
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissipation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
Specialized Pillow-Upper Mount
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chassis movement. Caster adjustment allows the correction of camber for further tuning ability. Caster adjustment plates are not included on all applications.
Spring seat / lock seat
Each single full rotation equals 2mm drop. The adjusting locking seat allows for spring stress to adjust with out the necessity to change suspension position.
Original spring
Tremendous enhancement in durability resulted from a high quality surface processing. Constant testing resulted in a perfect spring rate for each application.
Racing Spec Dampers inherited the same great quality of the P-1 racing damper. Each Racing Spec Damper is made with special components and are tested and produced with out compromise. Each damper are assembled by skilled engineers to provide the best quality possible.
Spring Rate:
9K Front
7K Rear
supertwo is offline   Reply With Quote
Old 07-04-2014, 06:37 PM   #2
dizzario
Drives: FRS
I don't even need these and they're tempting...bump for a pretty good price!
dizzario is offline   Reply With Quote
Old 07-10-2014, 02:35 PM   #3
IIDutch
IIDutch's Avatar
Drives: 2014 Firestorm FRS
Willing to ship to Canada?
IIDutch is offline   Reply With Quote
Old 07-16-2014, 01:50 AM   #4
supertwo
Drives: 2014 BRZ
Yes, If you're willing to pay all shipping costs. Sorry for the delay, just dealing with the same issues.
The Following User Says Thank You to supertwo For This Useful Post:
IIDutch (07-17-2014)
Old 07-17-2014, 06:30 PM   #5
IIDutch
IIDutch's Avatar
All good, can you pm me a shipping quote to S6J 1G1 in Saskatchewan?
Old 07-20-2014, 12:51 PM   #6
supertwo
Drives: 2014 BRZ
Holy crap!!! Shipping is expensive to Canada. PM'd you the rates...
Old 07-23-2014, 07:27 PM   #7
supertwo
Drives: 2014 BRZ
Bump
Old 07-25-2014, 02:46 AM   #8
sashrafi
Drives: 14' Brz
Pm'd
sashrafi is offline   Reply With Quote
Old 07-25-2014, 05:11 PM   #9
speedtrip
speedtrip's Avatar
Drives: 2013 Scion Fr-s Whiteout
Shipped to 87107?
speedtrip is offline   Reply With Quote
Old 07-26-2014, 01:22 PM   #10
supertwo
Drives: 2014 BRZ
Old 07-26-2014, 04:44 PM   #11
supertwo
Drives: 2014 BRZ
Originally Posted by speedtrip View Post
Shipped to 87107?
Hey, I got your Payment but there's no shipping address listed in PayPay for you. Where am I shipping these things??
Old 07-26-2014, 07:18 PM   #12
supertwo
Drives: 2014 BRZ
SOLD
Buddy Club Racing Spec Coilovers - SpeedFactory Style - Good Photos and Video. FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 03-25-2016 06:22 PM
FS: Buddy Club Racing Spec Damper Kit Coilovers alpine Brakes, Suspension, Chassis 5 04-16-2014 05:18 AM
Buddy Club Racing Spec coilovers track and street test Mark Slide Squad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 12-09-2013 08:01 PM
First set of Buddy Club Racing Spec coilovers! jdmitr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-28-2013 06:59 AM
Buddy Club Racing Spec coilovers, anyone install them yet? Mark Slide Squad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 06-28-2013 03:17 AM
