Old 04-02-2016, 05:41 AM   #43
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Not yet, give me 2 weeks or so and I will once the summers go on.
where is my pictures @!$##@%^$#&^%*(*
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
go_a_way1 (04-04-2016)
Old 04-04-2016, 09:55 AM   #44
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
ahahha lugnuts are still no here I have to wait till this weekend to get them on now
Old 04-04-2016, 04:29 PM   #45
FR-Sky
FR-Sky's Avatar
Oh yeah totally forgot those come with top hats!! The bolts are nice to make fine adjustments and in a race situation you want to get camber from the bolts vs the top hat due to the way the suspension travels but thats way above what the OP needs to worry about lol.
So i have make a appointment on Friday.
My plan is -2.5 front / -1.5 rear / 0toe
I have the prime coilover and SPC LCA.
he said he cant make it to 0 toe without the toe arm...
what should I do? I dont have time to buy a toe arm...
Old 04-04-2016, 04:39 PM   #46
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Car has factory toe adjustment, there's no reason he can't hit zero toe given your alignment specs.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
FR-Sky (04-04-2016), go_a_way1 (04-04-2016)
Old 04-04-2016, 04:42 PM   #47
FR-Sky
FR-Sky's Avatar
gotcha,,if he cant,,i ll just go to another alignment shop.
Thanks!
Old 04-04-2016, 04:58 PM   #48
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You should be able to get 0 toe?? the lower you go the more negative camber you naturally get (without effect toe much, if at all). You might have to settle with -2.0 rear but at that point you will be rather low.
Old 04-04-2016, 08:27 PM   #49
FR-Sky
FR-Sky's Avatar
i am planning 1.3 inch drop, i still can put 1 finger on the gap.
thats not too low right?
go_a_way1 (04-05-2016)
Old 04-04-2016, 10:18 PM   #50
Ashikabi
Ashikabi's Avatar
You're "too low"when you can't drive anymore. Don't worry about it. My tires are slightly tucked(18s), drives fine
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
FR-Sky (04-04-2016), go_a_way1 (04-05-2016)
Old 04-05-2016, 08:05 AM   #51
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
That should be fine. Probably where I will end up around myself. Dont go much lower then that unless you plan on doing some roll center corrections
Question on suspension. skavengers412 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-08-2015 11:12 PM
Suspension Set Up Question FR-Shred Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-01-2015 01:50 PM
suspension question... FloridaBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-17-2014 12:37 PM
Suspension Question TONYpepperon1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-12-2013 08:57 AM
BRZ vs. FRS suspension question smbrm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-12-2012 09:55 AM
