Old 04-01-2016, 06:02 PM   #15
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Cats change the sound quite a bit in my experience on a lot of different cars. For example, adding a cat made my GTI a lot less raspy and quieter outside the car but now it drones like crazy inside the car. Removing cats on my VR-4 just made it louder with no drone.
Lots of variables and it can get expensive quickly chasing your tail. If you can find a video online with a quality recording of the sound you're looking for, go for that setup.
Old 04-01-2016, 06:02 PM   #16
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Originally Posted by mav1178 View Post
To control noise you need to primarily address sizing of resonator relative to sound suppression capability of catback exhaust.
Having cats or not has very little to do with a quiet setup.
-alex
Originally Posted by Timmy_Jones View Post
False
Also I would like to chime in, mav1178 tested out the Fujitsubo Catless dual resonated front pipe and it is the quietest front pipe on the market today. In fact, in all his tests, it has kept the noise levels the same (fujitsubo vs stock front pipe) on different exhaust setups.
"The 84db @ 4500RPM is from the manufacturer and most likely w/ stock exhaust. In other words, compared with stock it doesn't change the sound at all.
The Berk front pipe on a stock muffler raised the sound by 3db, for your reference."
Keep in mind his Berk front pipe is catted.
Fujitsubo catless.
Also one of the tests he did.
Threw on the Tomei 60R (one of the loudest exhausts for our cars)...
Stock + Tomei 60R -- 107.1db
Fujitsubo Front pipe + Tomei 60R -- 107db
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 04-01-2016, 07:05 PM   #17
iarefluffy
iarefluffy's Avatar
Drives: CWP series blue brz
dont listen to these N1 naysayers, im running the N1 catback with everything else from JDL, catted headers, overpipe, ultra quiet front pipe. it really isnt too bad.
iarefluffy is offline   Reply With Quote
Old 04-01-2016, 07:33 PM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
That's what I was getting at... it's not so much a catalytic converter is there, but rather the question of if that cat is of enough volume to act as an effective resonator.
Sound on straight-thru exhaust piping is suppressed by volume. OE setups use baffles, hence the loss of power.
Whether you have a catalytic converter or not is not as important for sound as size and total volume of resonators.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
DocWalt (04-01-2016), Mr.Impreza (04-01-2016)
Old 04-01-2016, 08:25 PM   #19
Timmy_Jones
Spun
Drives: 23' Supra
Read my original post. I have the full setup already and it IS too loud on a cold start. Otherwise I love it.
Timmy_Jones is offline   Reply With Quote
Old 04-01-2016, 08:39 PM   #20
iarefluffy
iarefluffy's Avatar
Is the problem only the cold start then? You could always adjust the cold start RPMs to something more tolerable. I wouldn't say that getting the jdl front pipe vs the stock one changed much. Just more refined and in some aspects increased tone/volume. I feel like the front pipe did tone down the droning sound on cold starts.
Sent from my Robin using Tapatalk
Old 04-02-2016, 12:54 PM   #21
stockysnail
Just the tip
stockysnail's Avatar
False?
I ran a Fujitsubo catted header w/ a Berk catted front pipe. That setup was absurdly loud, even with my Fujitsubo catback (super quiet).
I put the stock front pipe back on, and it sounded like stock again.
-alex
The stock front pipe is much quieter (and a more restrictive cat) than the Berk catted front pipe, which is why it was quieter.
Old 04-02-2016, 09:29 PM   #22
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I run a variation of that JDL Ultra Quiet Front pipe on my build, I have the one with the over pipe integrated into it. But in all honestly it will make your exhaust louder if you upgrade from the restrictive stock front pipe to the JDL unit. I think you will only notice it to be quieter if you have already previously had a un-catted front pipe and upgraded to the JDL unit.
I personally love mine, it provides the most sway bar clearance on the market the same can't be said for the unit in question that you mentioned (Non-Over pipe integrated unit) & that sound off a full turbo back 3" JDL exhaust system paired with a Tomei Type 80 is amazing.
R2RO is offline   Reply With Quote
Old 04-02-2016, 10:45 PM   #23
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have plenty of swaybar clearance too (the rub marks are from installation, and yes, it's rusty, they salt the ever-loving crap out of the roads here and depending on the grade of stainless it can get surface rust though I'm disappointed the ceramic coat didn't protect it a bit better)
HKS front pipe or dual resonated front pipe unsurety Engine, Exhaust, Transmission 18 02-22-2016 09:22 AM
Catless Front Pipe VS Test Front Pipe. What's the Difference? geruta Engine, Exhaust, Transmission 48 04-23-2015 04:07 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
