#211 |
Drives: Asphalt FR-S
#212 | |
Drives: 2013 FRS, Raven, Auto
Maybe try this http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm |
| The Following User Says Thank You to joop1987 For This Useful Post: | Rican_D (03-23-2016) |
#213 | |
#214 |
That was the issue, works perfect now thanks
| The Following User Says Thank You to Rican_D For This Useful Post: | B-R-Z (03-23-2016) |
#216 |
#217 |
Drives: 2013 FR-S Hot Lava
Drill new holes into the existing brackets....need to move them back about 4mm for it to fit flush with the dash trim
#218 |
I just enlarged the current holes on the right side bracket (radio side) so it slide a little backwards.
#219 |
Drives: 2013 Scion FR-S in White
Anyone using this with an iPhone?
#220 |
Drives: 2016 ZC6
Well, there's gaps on the side of the radio with the 2016 BRZ radio dash panel, but I'm glad the panel fits over it. I was thinking I was gonna be running without a dash panel until getting a replacement panel that fits better. Lol. Not sure where I want to route the new mic to yet. I have it temporarily coming out of the gap on the side of the radio and sitting in from of the instrument cluster. |
#221 |
Drives: 2016 ZC6
| The Following User Says Thank You to Pointmutation For This Useful Post: | HuntingtonFRS (04-03-2016) |
#222 | |
Drives: 2016 BRZ
I have a 2016 BRZ, The stock HU sucks, which model did you buy? Does it have Navigation? Does back up camera work? Was it easy to hook up? |
#224 |
Drives: DGM BRZ
I installed it a couple of days ago, swapped pin 9 to 8, and dremelled down the pins on the bracket. Overall, for just a straight install it was pretty simple. It took maybe 30 minutes.
Nobody's really posted any instructions for a backup cam, but the trigger wire needs to be manually soldered to the correct pin on the existing harness, and I had to splice power as well. The harness I bought didn't have that. Getting the software to work the way I wanted to is a pain though. In total, I've spent ~6-8 hours trying to get it to work the way I want it to, including flashing new roms and stuff. Most of this was me being curious, and playing around though. It's as complicated as you make it. |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
