Old 03-22-2016, 01:48 PM   #211
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by B-R-Z View Post
That's what I thought it was and its what I use. Someone else said they were able to use a larger one, though. :shrug:
Yeah, I'm confused lol
Rican_D is offline   Reply With Quote
Old 03-22-2016, 11:15 PM   #212
joop1987
Drives: 2013 FRS, Raven, Auto
Did you try formatting it into fat32? The radio probably don't read exfat. Windows cannot format more than 32gb but a 3rd party software should let you.
Maybe try this http://www.ridgecrop.demon.co.uk/ind...?guiformat.htm
joop1987 is offline   Reply With Quote
The Following User Says Thank You to joop1987 For This Useful Post:
Rican_D (03-23-2016)
Old 03-22-2016, 11:29 PM   #213
Rican_D
Rican_D's Avatar
Thanks that exfat might be the issue. I'll give that program a try.
Old 03-23-2016, 11:46 AM   #214
Rican_D
Rican_D's Avatar
That was the issue, works perfect now thanks
The Following User Says Thank You to Rican_D For This Useful Post:
B-R-Z (03-23-2016)
Old 03-24-2016, 01:17 PM   #215
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Am I retarded or something? I can't get my dash trim to clip in place over the unit, lol.
Luftwaffel is offline   Reply With Quote
Old 03-24-2016, 01:48 PM   #216
Rican_D
Rican_D's Avatar
I had to test fit a few times until I got it right. Elongating the bracket holes to slide them forward.
Old 03-24-2016, 05:20 PM   #217
Ketchum88
Ketchum88's Avatar
Drives: 2013 FR-S Hot Lava
Drill new holes into the existing brackets....need to move them back about 4mm for it to fit flush with the dash trim
Ketchum88 is offline   Reply With Quote
Old 03-24-2016, 07:53 PM   #218
joop1987
I just enlarged the current holes on the right side bracket (radio side) so it slide a little backwards.
Old 03-26-2016, 11:15 PM   #219
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Anyone using this with an iPhone?
HuntingtonFRS is offline   Reply With Quote
Old 04-01-2016, 11:28 AM   #220
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Well, there's gaps on the side of the radio with the 2016 BRZ radio dash panel, but I'm glad the panel fits over it. I was thinking I was gonna be running without a dash panel until getting a replacement panel that fits better. Lol.
Not sure where I want to route the new mic to yet. I have it temporarily coming out of the gap on the side of the radio and sitting in from of the instrument cluster.
Pointmutation is offline   Reply With Quote
Old 04-01-2016, 11:34 AM   #221
Pointmutation
Drives: 2016 ZC6
I use it with an iPhone. Bluetooth streaming music works fine, as does voice calls and Siri. Running on the stock setup. Haven't rooted it or played with custom ROMs yet.
The Following User Says Thank You to Pointmutation For This Useful Post:
HuntingtonFRS (04-03-2016)
Old 04-01-2016, 06:02 PM   #222
wwilder9
Drives: 2016 BRZ
I have a 2016 BRZ, The stock HU sucks, which model did you buy? Does it have Navigation? Does back up camera work? Was it easy to hook up?
wwilder9 is offline   Reply With Quote
Old 04-01-2016, 06:28 PM   #223
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Yes to all. There is a link to it a few posts back
B-R-Z is offline   Reply With Quote
Old 04-01-2016, 07:13 PM   #224
dchan
Drives: DGM BRZ
I installed it a couple of days ago, swapped pin 9 to 8, and dremelled down the pins on the bracket. Overall, for just a straight install it was pretty simple. It took maybe 30 minutes.
Nobody's really posted any instructions for a backup cam, but the trigger wire needs to be manually soldered to the correct pin on the existing harness, and I had to splice power as well. The harness I bought didn't have that.
Getting the software to work the way I wanted to is a pain though. In total, I've spent ~6-8 hours trying to get it to work the way I want it to, including flashing new roms and stuff. Most of this was me being curious, and playing around though. It's as complicated as you make it.
dchan is offline   Reply With Quote
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
