Old 04-01-2016, 11:09 AM   #1751
qtwre
Drives: White FR-S
Does AVO announce these upgrades anymore? I used to see updates on the forum when they had a new product. Here I am with what I assume is a stage 1 turbo. I'm so many stages behind and I don't even know what they mean anymore.
Sent from my Nexus 6P using Tapatalk
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
Calum (04-01-2016)
Old 04-01-2016, 09:18 PM   #1752
Calum
That Guy
Drives: 2013 asphalt FRS MT
I remember when they brought out the stage 1.5 and 2. I still don't know what those differences were. I tried to figure it out, but gave up pretty quickly due to lack of GAF.
Edit: I just checked their website, it still doesn't give a complete list of what is in the stage 2 package. Nor stages 3, 4, or 5.
Old 04-02-2016, 03:01 AM   #1753
JD86
Drives: 2013 Toyota 86 GT
My memory is a little vague on stage 1.5 but the rest went something like this.
Stage 1. Basic turbo kit 5psi actuator ends at over pipe.
Stage 2. As above, plus 8psi actuator, plus full 2.5 inch exhaust, plus upgraded map sensor.
Stage 3. As two, plus billet wheel turbo, plus fuel injectors plus fuel pump. You were recommended to have a full 3 inch exhaust somewhere here too.
Stage 4. Ditto to 3, although I believe the stage 4 turbo received a bigger wastegate than stage 3 to counter boost creep. You must have a 3 inch exhaust turbo back exhaust by this point and access to decent fuel otherwise you're wasting your time. Plus a bigger intercooler which required a larger intercooler feed pipe, which meant modifying your windscreen washer bottle.
Stage 5 from what I can see has a new turbo (which has a lip on the intake pipe ftw!) and revised cold side pipe work. Plus fensport is running a complete custom fuel system.
I have a modified stage 4 kit installed at the moment, using some other manufacturers components (like the intercooler, wastegate actuator and other bits) and some slightly tweaked avo ones. Unfortunately I am finding like fensport I need a complete fuel system to run it. So I'm currently sitting with a nice conservative 8psi map until I finish that... And I'm going to steal their idea of enlarging the direct injector feed now that I've seen that... So my dyno graphs of stage 4 aren't reflective of its capabilities. Plus I'm waiting for the Motel flex fuel software update which should be in beta shortly. Plus Australian dyno/conditions... So will never be the lofty numbers the Americans on here are used to seeing :-p
I could be slightly out with the stages so feel free to correct me people. I don't mind admitting when I'm wrong.
JD86 is offline   Reply With Quote
The Following 2 Users Say Thank You to JD86 For This Useful Post:
Calum (04-02-2016), ChrisD (04-09-2016)
Old 04-02-2016, 06:11 AM   #1754
steve86gt
Drives: 2014 Toyota gt86 avo stg 2 e85
Originally Posted by ChrisD View Post
The flutter is actually a bad thing (even though I love the sound of it). It means air is going back the wrong way into your turbo and slowing it down or at worst causing it to stall completely. Presumably your system came with a blow off valve which eliminates this by dumping the pressure to atmosphere (when it does this you hear a short hissing sound when you let off the gas after flooring it for a while) or recirculating it back round through the intake pipes and turbo. The avo blow off valve has the option of being set to 50/50, so it recircs some of the air and dumps some to atmosphere.
Hey ChrisD , thanks for the response
Ive currently got the avo oem style on their at the moment.. I just love that flutter sound but if it does damage , not worth it in the long run i guess
steve86gt is offline   Reply With Quote
Old 04-04-2016, 02:22 PM   #1755
M1K3
M1K3's Avatar
Drives: vrooom...
Fensport GT86R
Fensport GT86R and AVO Stage 5 Turbo in action:
[ame="https://www.youtube.com/watch?v=hoKKGiFEuOA"]Fensport GT86R New 2016 Spec - 1st Overall @ Blyton Park R1 2016 - YouTube[/ame]
M1K3 is offline   Reply With Quote
The Following 2 Users Say Thank You to M1K3 For This Useful Post:
Draco_PR23 (04-04-2016), JD86 (04-08-2016)
Old 04-04-2016, 03:16 PM   #1756
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I have an AVO 50/50 BOV for sale if anyone is interested
PM!
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Astroboy (04-04-2016)
Old 04-04-2016, 06:26 PM   #1757
protpibe
protpibe's Avatar
Originally Posted by Astroboy View Post
I was told it was just the clutch disk springs rattling. So I'm going with that. Makes sense
Sent from my LG-D850 using Tapatalk
Your pms are full
And yes i got your address info
Old 04-04-2016, 07:05 PM   #1758
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by protpibe View Post
Your pms are full
Oh.. Ok. Hey I would like to buy it today, but the way that my bank account is set up, I don't think I can today.. Sorry.
I really want it. I can get it Saturday tho, which is payday for me 😔
Astroboy is offline   Reply With Quote
Old 04-04-2016, 11:59 PM   #1759
protpibe
protpibe's Avatar
I haven't formally posted it for sale yet. Shoot me a pm on saturday, I'm sure i'll still have it.
Astroboy (04-06-2016)
Old 04-17-2016, 06:36 PM   #1760
nopocrakr
nopocrakr's Avatar
Drives: CBS BLACK 2013 Subaru BRZ
AVO Turbo issue ?
Looking to get opinion on any red flags you may see in these pics.Name:  IMG_0788.JPG
nopocrakr is offline   Reply With Quote
Old 04-28-2016, 12:06 PM   #1761
jwvand02
Drives: 2013 SWP BRZ Limited
Sorry if this has been talked about already, but I swear I searched.
What's engine longevity looking like for the Stage 1 or 2 kit with E85? I know at that power level (~400 whp) a clutch and fuel is definitely necessary, but what about a built engine? I'm thinking about keeping the BRZ as a long term toy, and starting to get bored with 300hp
jwvand02 is offline   Reply With Quote
The Following User Says Thank You to jwvand02 For This Useful Post:
Astroboy (04-28-2016)
Old 04-28-2016, 12:28 PM   #1762
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Trans will probably go out before the engine does. Also, depends on the tune/tuner. I recommend James Martin/HRItuning.
904FRSlow is offline   Reply With Quote
The Following 2 Users Say Thank You to 904FRSlow For This Useful Post:
Astroboy (04-28-2016), Sportsguy83 (04-28-2016)
Old 04-28-2016, 04:06 PM   #1763
Astroboy
Astroboy's Avatar
Drives: None
Or if he's in texas or near texas, he can check out ATS racing in the denton. They are extremely good to
I've been told that the limit for stock motors are around 350-380.
Old 04-30-2016, 01:56 PM   #1764
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Im running essentially a stage 3ish on stock internals? with e85, around 400whp. Been running this for years and everything is still fine. Did wreck a tranny, so had to replace that, but other than that, everything been fine. Of course, I did upgrade all the other parts fuel, clutch, etc. when i did the initial turbo. This is my second cluthc, as my first one was an exedy stage 1, and it worked well for a while, but began slipping at higher powerlevels, now running an act 6puck
I garage this all winter, and really only drive on nice days, and the occasional track day, not a lot of miles, maybe 3000 miles a year, so not like i have been running it a lot, but always seems to run well when i do take the car out. but yeah, even with light use, my transmission went to hell.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Astroboy (04-30-2016)
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
