#1737 |
Drives: None
#1738 |
Drives: 2013 Subaru BRZ Automatic
where can i buy the turbo kit in China?
Hey guys, I'm in China, there is no AVO resaler in China
, where can i buy the turbo kit? Thanks
Subaru BRZ Automatic, World Rally Blue , Innovate Supercharger, AVO Stage 1 Turbo kit, 4.556 FinalDrive, STI Big Break, DeliciousTuning
#1739 |
Drives: White brz series blue
Just installed my turbo last night and I ran into some problems I was wondering if you could help with, there is oil leaking out into my intake side and it's going into the manifold and engine, is this due to a bad seal on the turbo causing it to leak? Oil seems to be leaking out and causing smoke around the turbo. Or is it possible the oil pump is not working correctly and is causing positive pressure in the system, sending oil out through the exhaust and up the oil breather line that's connected to the pcv and into the intake?
#1740 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
Like it's leaking into the turbo and being pushed into the engine? There are no external leaks?
Top Tier Imports - Check out my build journal HERE
#1741 |
Yes, oil goes into the turbo, then into the resiviour and from there the mechanical pump seems to not be working so the oil goes up into my PCV and then manifold because I teed into that line.
#1742 |
I am AVO kit owner now.
| The Following 2 Users Say Thank You to luckykevin For This Useful Post: | Draco_PR23 (03-09-2016), MisterSheep (03-09-2016) |
#1743 | ||
Miata traitor
Drives: 2002 Miata SE
Did you ever find the culprit? Quote:
Any news on this? Good or bad?
Sold the BRZ and bought a miata O_o
#1744 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
#1745 |
Drives: 2014 Toyota gt86 avo stg 2 e85
Hey everyone, i can say im a proud owner of a F/I Toyota 86 just had my stage 2 avo kit installed .. very happy with it !
I have been searching how to make the avo kit flutter but i cant find anything. does anyone have any suggestions? Thanks guys |
#1746 |
Drives: vrooom...
AVO Stage 5 Ball Bearing Turbo:
![]() Link to Fensport Post on FB: https://www.facebook.com/media/set/?...2933872&type=3 |
#1747 |
Drives: White FR-S
There's a stage 5 now? I guess you can never have too many stages.
Sent from my Nexus 6P using Tapatalk |
| The Following User Says Thank You to qtwre For This Useful Post: | nickmerronesucks (05-13-2016) |
#1748 | ||
Miata traitor
I didnt know this club existed and I dont necessarily want to be a part of it but here we are.... No confirmed problem or solution for it that I've seen. Just deal with it and a lot of times it goes away I guess. Quote:
(real album... they are in fact, on NOW 93)
| The Following User Says Thank You to KevinK121 For This Useful Post: | nickmerronesucks (05-13-2016) |
#1749 |
Drives: GT86
The flutter is actually a bad thing (even though I love the sound of it). It means air is going back the wrong way into your turbo and slowing it down or at worst causing it to stall completely. Presumably your system came with a blow off valve which eliminates this by dumping the pressure to atmosphere (when it does this you hear a short hissing sound when you let off the gas after flooring it for a while) or recirculating it back round through the intake pipes and turbo. The avo blow off valve has the option of being set to 50/50, so it recircs some of the air and dumps some to atmosphere.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits |
#1750 |
Drives: GT86
Yeah Adrian at Fensport is currently fitting the stage 5 to his car and should be racing it in the sprint series in a couple of days. Interested to hear what he thinks of it compared to the stage 4.
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
