Old 03-31-2016, 11:49 AM   #15
Kiwis
Kiwis's Avatar
Drives: 2016 Blackout BR86
Originally Posted by Summerwolf View Post
Then new bumper clips, grille, turn signal area / fog light housing, fog light / turn signal assemblies (or brake ducts) bumper pad, badging, removal of the headlight surround....etc etc.
Clips are all of a few dollars at best, nothing major. The BRZ headlights have turn signals in them so I mean, shouldn't be too big of an issue and then I could simply put fog light delete panels if I don't want fog lights but even then, that's only about $75 extra provided you look in the right places. Bumper pads are also pretty inexpensive as well, shouldn't be that big of an issue. Also, just purchased badges for about $55 so that's not a big deal to me.
Now, I do have one question: What do you mean by the removal of the headlight surroundings? Pictures or thread regarding this?
Kiwis is offline   Reply With Quote
Old 03-31-2016, 11:57 AM   #16
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Search google for threads about converting FRS headlights to BRZ headlights. Should have pictures.
Old 03-31-2016, 12:06 PM   #17
Kiwis
Kiwis's Avatar
I think you understood me wrong then, I'm going from BRZ to FR-S, not the other way around?
Old 03-31-2016, 12:09 PM   #18
Summerwolf
Panda Trueno
Summerwolf's Avatar
No, I understood you.... nobody swaps from BRZ to FRS headlights though, so there wouldn't be pictures in a thread like that.....
Google is your friend. Several people have done this bumper swap, maybe you could find a thread that shows all the differences.
Old 03-31-2016, 12:11 PM   #19
Kiwis
Kiwis's Avatar
See I get that however I intend to keep my headlights, I'm simply switching out my bumper cover as everything else about the BRZ I enjoy.
Old 03-31-2016, 12:14 PM   #20
Summerwolf
Panda Trueno
Summerwolf's Avatar
OMG..... See, the pictures of the headlight surrounds would be IN a thread like that.
http://lmgtfy.com/?q=frs+bumper+on+a+brz
Do research. Should be first four or five hits on that search. First one has part numbers. Took me 30 seconds. Quit asking for spoon fed info, enjoy your car, don't hackjob it.
Old 03-31-2016, 02:27 PM   #21
Kiwis
Kiwis's Avatar
I'm not trying to start a fight but you really don't listen. I have a BRZ, the only thing I'm switching for FR-S replacements are the bumper and badges. I'm not touching the headlights, they don't need to be touched. What's so hard about that concept?
Old 03-31-2016, 03:30 PM   #22
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Mine is an OEM.
JazzleSAURUS is offline   Reply With Quote
Old 03-31-2016, 03:44 PM   #23
Summerwolf
Panda Trueno
Summerwolf's Avatar
They do need to be touched because of the surrounds!! You asked for pictures of said surrounds. I told you to search a thread showing headlight swapping because.... THEY WOULD HAVE PICS OF THE SURROUNDS.
http://www.ft86club.com/forums/showthread.php?t=12659
AGAIN spoon feeding you information.
Old 03-31-2016, 03:51 PM   #24
Kiwis
Kiwis's Avatar
I know and what I've said is I already checked previously and nothing involves that. It doesn't apply in this scenario, what on earth are you on about?
Originally Posted by JazzleSAURUS View Post
Mine is an OEM.
Not exactly helpful? Are you saying you purchased a FR-S bumper from the dealer or?
Old 03-31-2016, 03:55 PM   #25
Summerwolf
Panda Trueno
Summerwolf's Avatar
This....the FRS doesn't use the headlight surrounds. You asked for pictures. I tried to help you. If you can't understand.....
The Following User Says Thank You to Summerwolf For This Useful Post:
HachiRo (03-31-2016)
Old 03-31-2016, 03:58 PM   #26
JazzleSAURUS
I bought a used OEM one from a wreck partout. There was a bit of damage, a wrinkle in the tear duct, (if you pretend a headlight is an eye,) and a little bit of scuffing on one corner, but I just wanted a spare bumper cover to run in the winter so my stock bumper doesn't get messed up.
$50, if that helps give you perspective.
Old 03-31-2016, 05:18 PM   #27
Kiwis
Kiwis's Avatar
That's all that had to be said though, you didn't need to say anything else or be rude.
May look into that, the part I'm looking at is brand new (OEM) but almost $300.
Old 04-01-2016, 08:44 AM   #28
JazzleSAURUS
The hell did I say that was rude?
You're all about making friends, aren't you?
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
8R6 (04-01-2016), LOLS2K (04-01-2016)
bumper swap, debadge
anyone want a BRZ bumper? --Dark Grey front bumper swap Charlotte NC IroncladBRX Southeast 0 04-20-2014 09:18 PM
WTT(Midwest): MY 37j(pearl white) FR-S bumper w/fogs for YOUR BRZ limited bumper OmarGC Exterior Parts (Aero, Lighting, Etc.) 26 12-02-2013 11:44 AM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
