Old 03-31-2016, 09:58 AM   #1
dtrop
Drives: Wrb 2014 limited brZ
jdl header / tune questions
Current setup, Perrin 2.5 resonated CBE. (Massachusetts resident)
I'm looking to buy a JDL uel header (coated) and pair it with OFT.
I'm thinking about getting the catted version, but OFT stage 2 is created for cattless and i'm wondering what complications could occur from running the stage 2 catted. I really don't want to buy the header and run stage 1. Also note that this will be my first experience in any car tuning. I know i can get a custom tune from shiv, but I don't necessarily want to go that direction.
how much potential power will I "lose" from running catted?
i've read rasps/smells can occur with cattless and i don't want to encounter that.
any extra help would be great.
dtrop is offline   Reply With Quote
Old 03-31-2016, 10:09 AM   #2
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
In for answers as well. I live in NC and our emissions inspections would force me to go with a catted header, from what I have heard.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 03-31-2016, 10:21 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I dont think its worth getting a catted header unless you want to try and change the sound up a little (correct me if I am wrong, I live in redneck nation where we all run catless). The tune alone will make slight gains so thats worth doing.
MisterSheep (03-31-2016)
Old 03-31-2016, 10:23 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
You will want to run a stage 1 with the JDL with a cat. You can do a custom tune to try and get a few more ponies but a stage 2 is designed to ignore all emission laws and make max power on a catless system.
Old 03-31-2016, 10:24 AM   #5
Teseo
Drives: frs
IIRC its safe to use stage 2 with catted uel header
http://www.ft86club.com/forums/showthread.php?t=71157
The Following User Says Thank You to Teseo For This Useful Post:
go_a_way1 (03-31-2016)
Old 03-31-2016, 12:32 PM   #6
dtrop
thanks for the info, seems like some mixed thoughts. I had that link previously saved before, but haven't had a chance to read through the whole thing yet.
I would hate to buy the header to only run stage 1, but i am hesitant to run cattless. i would run cattless just i am not sure about smells that people refer to, i certainly don't want to encounter that. Rasps are another negative to me, but i do have stock op/fp and resonated perrin 2.5 cbe, so maybe it wouldn't be that bad?
Ultimately, I want to run my car with safety in mind first to avoid unexpected expenses.
Old 03-31-2016, 01:16 PM   #7
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Do they smog in your state? In NY they don't so you can run basically full catless as long as no CEL is on and pass.
Old 03-31-2016, 01:28 PM   #8
dtrop
http://www.dmv.org/ma-massachusetts/smog-check.php
It appears we do.
Old 03-31-2016, 01:59 PM   #9
kch
Senior Misanthrope
kch's Avatar
I have a JDL catless and have a high-flow cat in my JDL FP. The smells are negligible unless you're fully catless. Running corn helps it smell even better.
I'm not sure about the laws in Mass. Here in TX we don't have a sniffer test--they only plug into the OBD2 and check the emission system readiness. We're allowed to have one show "not ready" and still pass. Of course a CEL is insta-fail. Catless is doable here because the tune will disable certain CEL codes and all systems will still show "ready."
Look into your state's inspection procedures and see if you can do the same. I considered getting a catted header for a while because I was afraid of inspections. But I didn't want to half-ass anything, so I went catless. No regrets.
Old 03-31-2016, 02:46 PM   #10
deuncos
Drives: AT Hot lava FRS
http://www.ft86club.com/forums/showthread.php?t=103534 check out my thread
I had the same question myself about running stage 2 with a catted JDL uel, I'm still waiting on my headers to come in the mail , but from what other members, who have our jdl catted set up or have more knowledge on the subject matter, all seem to agree on is that running the stage 2 map doesn't present any glaring issues. I pm'd shiv to see if there are any possible long term negative effects of running the stage 2 uel catless tune with a catted header and am still waiting for a response, but if it comes down to it I might just end up getting an etune from shiv just to be safe as well as get a little more
deuncos is offline   Reply With Quote
Old 03-31-2016, 02:50 PM   #11
dtrop
as soon as you hear a response from him, let us know!
Old 03-31-2016, 02:54 PM   #12
deuncos
Will do
Old 03-31-2016, 04:30 PM   #13
G-awesome
Drives: 2015 Firestorm Scion FRS
running a catted jdl uel with an OFT stage 2 tune for a month now...no glaring issues that I can notice physically but I just started data logging my commutes to and from work to see if there's any issues internally. Will be posting results here: http://www.ft86club.com/forums/showthread.php?t=103534
G-awesome is offline   Reply With Quote
The Following User Says Thank You to G-awesome For This Useful Post:
deuncos (03-31-2016)
Old 03-31-2016, 04:40 PM   #14
dtrop
thank you for your current experience!
Several questions regarding tune. Please help. neutral Software Tuning 17 02-11-2015 01:00 PM
Header without a tune eddiev116 Engine, Exhaust, Transmission 73 02-07-2015 07:01 PM
EL header questions newports Engine, Exhaust, Transmission 2 03-29-2014 02:41 AM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
FI or Tune and Header? RSH Engine, Exhaust, Transmission 30 10-23-2013 06:09 PM
