Old 03-30-2016, 10:28 AM   #15
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
gear one performance has a trunk brace for their BRZ with the apr gtc 200 wing.
check out this thread:
http://www.ft86club.com/forums/showthread.php?t=88408
spicyricecake is offline   Reply With Quote
Old 03-30-2016, 10:28 AM   #16
08stiguy
08stiguy's Avatar
Drives:
Good looking wing but not sure that's what OP is looking for
I posted the vid to show everyone the brace that the voltex wing uses.
08stiguy is offline   Reply With Quote
Old 03-30-2016, 10:30 AM   #17
Ashikabi
Ashikabi's Avatar
Hmm I was imagining something that attached to the frame to counter act the sag in the deck due to the weather stripping being squished.
LOL you are the OP ... my bad
Old 03-30-2016, 10:32 AM   #18
08stiguy
08stiguy's Avatar
Drives:
Great input man. Time to do some more research.
Old 03-30-2016, 10:34 AM   #19
Ashikabi
Ashikabi's Avatar
Hmm you being facetious or saying you need to do more research?
Old 03-30-2016, 10:39 AM   #20
Ashikabi
Ashikabi's Avatar
UMMMMM OP posted it.
Yeah I saw that after I posted lol
Anyways, this awful sketch is what I was imagining
Old 03-30-2016, 10:42 AM   #21
Not sure how effective that would be if the trunk lid is to remain functional. When closing it has to go down further then the normal resting position to let the latch catch and that could be a problem even if it is only a couple of MMs. Would be fine if the trunk lid is fixed in the closed position though.
Old 03-30-2016, 10:53 AM   #22
Ashikabi
Ashikabi's Avatar
One reason why I'm so interested in this.I suppose you could use hood pins to latch it instead
Old 03-30-2016, 10:54 AM   #23
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
Like this?
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
Tcoat (03-30-2016)
Old 03-30-2016, 10:55 AM   #24
Still has to go below the pin holes before coming back up to level. Although you could just push the corners down enough to insert the pins I guess.
Old 03-30-2016, 10:56 AM   #25
Ashikabi
Ashikabi's Avatar
Originally Posted by VIP BRZ View Post
Like this?
Yeah if the trunk was still there and opened and shit. Don't you kinda need the trunk for aero purposes?
Old 03-30-2016, 10:57 AM   #26
Ashikabi
Ashikabi's Avatar
I dunno, again that's why I'm curious. Maybe some kind of latch like a tool box?
Old 03-30-2016, 10:58 AM   #27
VIP BRZ
VIP BRZ's Avatar
I'm sure the trunk could be attached with slits cut in, although it would never open/close
and you couldn't put anything in it.
I was interested in this super aggressive open trunk look (but my build is purely form)
Old 03-30-2016, 11:06 AM   #28
08stiguy
08stiguy's Avatar
Drives:
Not being facetious at all bro. I just really need to sit down and do the sketches and the math. I'm in no way a high horse power car so I'm not sure if the brace would even make a difference. I do notice the flex though.
I was thinking that, but I still want the trunk to be functional.
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney Enalband24 Exterior Parts (Aero, Lighting, Etc.) 10 01-03-2016 12:24 PM
sold all Whiteline Rear sway brace also dc Sports lateral brace stiboost08 Brakes, Suspension, Chassis 25 07-19-2015 07:49 PM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 11:52 AM
Supertek Brake Master Cylinder Support Brace - Now Available Supertek Industries Brakes, Suspension, Chassis 15 05-24-2014 11:45 AM
