Old 03-25-2016, 11:01 AM   #491
CSG Mike
CSG Mike's Avatar
Originally Posted by DukemLuke View Post
how does the clubsport 400 compare to the type A 350? your site claims it was designed for RHD but will fit LHD. is there any rubbing anywhere?
More torque, less power. Perfect for people that want all their power at low RPMs, and don't care to wring out the engine to redline.
drewbot (03-30-2016), Jmonty (03-25-2016)
Old 03-25-2016, 07:23 PM   #492
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Burnouts and donuts!
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
CSG Mike (03-25-2016)
Old 03-28-2016, 07:30 PM   #493
Hawk77FT
Drives: GTS 86
Talking
Ok, here are my impressions of the CS400
1. Installation: Very easy to install. Undo the engine mounts from the frame, lift the engine up about 1 inch, and slide that overpipe extension in with no problems. Let it hang in there and install the header, slide the overpipe in the 3 holes and put the bolts in. Make sure you don't tighten anything yet. Once header and overpipe are in position, start tightening the bolts. Done!
2. I am sure everyone wants to hear the driving impressions. Went for a long drive and my first five minutes were...I am not going to lie...smiliar to B250. Well, it behaved exactly like the B250 (and by that is not like B250 is bad in any way.) Did couple of half throttle, hard acceleration, etc...and after about 30km it started to feel different. Went for a drive next day and WOW what a massive difference. The low end torque has improved considerably and it just pulls like a bull. The more I drove it the better it got. I have an OFT tune for the B250 so I think it took a bit of time to learn the new set up!
After almost 500 km I can say that these are perfect for low end torque increase. So if you do a lot of hill climb, mountain run, or short tracks this is perfect. After 2500-3000rpm it just starts pulling up to 6000-6500...where it becomes kinda flat. The power delivery is different. On B250 it felt like a consistent and smooth increase across the rev range even at 7000 rpm...while the C400 feels like a very steep increase in torque and flat at about 6500.
I am planning to drop a 4.55 final drive in my car to get a bit more go...and I think coupled with this, I should have a nice grin on my ugly face for a long time!
Hawk77FT is offline   Reply With Quote
The Following 12 Users Say Thank You to Hawk77FT For This Useful Post:
AceHeader-MT (03-29-2016), Calum (04-05-2016), Cop (03-29-2016), CSG David (03-28-2016), CSG Mike (03-28-2016), DAEMANO (03-29-2016), DeaconRoc (03-29-2016), drewbot (03-30-2016), MaximeT (03-29-2016), SPCorBUST (03-28-2016), Teseo (03-29-2016), tracerit (03-28-2016)
Old 03-28-2016, 07:45 PM   #494
CSG David
CSG David's Avatar
We were informed of this CS400 header being shipped out to you by ACE. Glad to see some reviews for this and a validation of how the powerband was.
We will be offering this option for guys looking to improve their low-midrange powerband.
The Following User Says Thank You to CSG David For This Useful Post:
Hawk77FT (03-28-2016)
Old 03-29-2016, 06:30 AM   #495
churchx
churchx's Avatar
Drives: 2014 GT86
Hawk77FT: was mentioned OFT tune retweaked for CS400 after switch from B250 or used as is?
Hawk77FT (03-29-2016)
Old 03-29-2016, 06:43 AM   #496
Reamer
Drives: 2015 FRS
Sounds like it was used as is and he waited for the AFR to adjust, but this is speculation and I don't know how tuning really works in detail as far as what the ECU still adjusts dynamically after OFT.
Sent from my ONE E1005 using Tapatalk
Reamer is offline   Reply With Quote
The Following User Says Thank You to Reamer For This Useful Post:
Old 03-29-2016, 06:42 PM   #497
Hawk77FT
Drives: GTS 86
it wasn't tweaked at all...it was basically used as is. I don't even want to think about what this header will be like with a proper dyno tune, E85 and final drive! Actually I do want to think about it!
The Following 2 Users Say Thank You to Hawk77FT For This Useful Post:
CSG Mike (03-29-2016), Jmonty (03-29-2016)
Old 03-29-2016, 06:49 PM   #498
Reamer
Drives: 2015 FRS
Are you running an auto or manual gearbox? I'm impatiently waiting on my 350 to come in and hearing how the 250 and 400 perform I'm expecting a happy medium and it will be dyno tuned with my OFT. I am debating getting the FD done as well down the road, but we'll see.
Old 03-29-2016, 07:24 PM   #499
Hawk77FT
Drives: GTS 86
Manual gearbox . I would have gone 350 if the overpipe would've fit on the RHD cars.
A dyno tune and a FD will make you very very happy driver! Low mid torque will be massively improved.
The Following User Says Thank You to Hawk77FT For This Useful Post:
Jmonty (03-29-2016)
Old 03-29-2016, 10:06 PM   #500
tracerit
Drives: '13 SSM BRZ Limited 6MT
@Hawk77FT
Does the CS400 sound similar to these videos from Ace? [ame="https://www.youtube.com/watch?v=2Iw02bH7lfk"]Ace Header ClubSport 400 In-car Test - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=LGxhLPWOBhs"]ACE Header ClubSport 400 Drive-by 11's - YouTube[/ame]
That teeny RC car like sound is pretty awesome.
tracerit is offline   Reply With Quote
The Following User Says Thank You to tracerit For This Useful Post:
Old 03-29-2016, 10:14 PM   #501
Hawk77FT
Drives: GTS 86
Originally Posted by tracerit View Post
@Hawk77FT
I will do an in car video and drive by one too! I have 2.75 catted front pipe and Evo3 catback but with silencers in. It is pretty loud when accelerate but really nice sound. Nice rasp too.
To answer your question , yes..sounds similar.
So far so good! I am planning to ceramic coat them after I do a dyno and do the front pipe as well.
Jmonty (03-29-2016), tracerit (03-29-2016)
Old 03-29-2016, 11:32 PM   #502
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Waiting on my install and tune, updates to follow when complete
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
Hawk77FT (03-30-2016)
Old 03-30-2016, 07:46 AM   #503
Reamer
Drives: 2015 FRS
Can anyone confirm that the 350 does not have a lot of rasp to it? I don't hear any in the videos in the OP.
Old 03-30-2016, 09:39 AM   #504
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I could be wrong in my thinking. But i believe most of your rasp and definitely the tinny sound, will come from having a catless front pipe. As long as you have a stock FP or high flow cat FP, I bet the sound will be less obnoxious. Then it would be a matter of picking a CBE to fit the sound profile you want.
However, this is my theory. But i am currently in the process of trying out a HFC FP to minimize the sound that i find annoying. I have had OFH, Tomei and ACE B350 headers on different BRZs. The header itself has never made the sound obnoxious. But the accumulative effect of catless header and catless FP is where you get more rasp, farty, tinny sounds. At least I hope thats true this time around.
In a few days will be sharing some audio files of the ACE B350 header w/ ACE catless FP. And then ACE Header w/ HFC invidia FP. Hopefully this will tame the sound (I'm pretty sure it will) and then i can still run STX if I so choose. Once I add the HFC FP, if the sound is not tinny obnoxious...I may even add a CBE myself. I like about 60% of the sound coming out of my car. I loathe the other 40%. I bet the catted FP will fix most of my sound issues. But the header performance can not be denied.
I will let you know soon.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
The Following User Says Thank You to brzaapi For This Useful Post:
Jmonty (03-30-2016)
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
