Old 02-02-2016, 02:29 PM   #1
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
TrackSpec Hood Louvers
One of the major challenges with the FT86, is the ability to extract heat out of the engine bay. While a stock car that is street driven doesn't have any problems staying within normal operating temperatures, cars that are Forced Induction, or are driven hard on the track often have overheating issues.
Another occurrence the more spirited drivers may have noticed, is that the stock hood "flaps" at higher speeds. There is a lot of air trapped under the hood, and to escape, the air wobbles the stock hood, escaping out the side. This produces a few undesirable effects: extra drag, front end lift, and a general feeling of uneasyness about the hood staying in place.
CSG is proud to introduce the TrackSpec Motorsports Hood Louver/Heat Extractor Vents for the FRS/BRZ/GT86.
A major design hurdle was finding a proper model of the FRS/BRZ/GT86 to perform CFD analysis to determine the effectiveness of the hood. Such analysis is often performed, but CSG and TrackSpec discovered that all of the commonly available models had some major flaws: they all assume a flat underbody, and they do not model inside the engine bay at all! With such a flawed model, the analysis would also be heavily flawed, so we set about seeking to make our own model. Unfortunately, with the budget we have, it was impossible to laser scan such a complex shape (the underbody, and more importantly, the engine bay) to get the level of accuracy we sought.
This led us to use the flawed models, with some modifications, to attempt to simulate airflow through the engine bay. This data, being flawed, was taken with a grain of salt, and was used only to try different shapes, angles, and sizes of vents, which would ultimately be verified with real world testing. Due to the complexity of the actual car, real world testing would be the only feasible way to get accurate measurements (we don't have the budget for windtunnel testing... sorry!).
The end result of this testing, is the vent pictured below. The vent is designed to drop into the stock hood, and does several things:
- an overall 43% drop in under-hood pressure at highway speeds
- a 60% drop in under-hood pressure at 120mph!
- A net front downforce (we had to add wing angle during testing to balance the now-grippier front)
- Increased cooling (less pressure under the hood = more air flowing through the radiator; more air being extracted = more air flowing through the radiator)
The above claims were verified with real-world data, and tested at Willow Springs Intentional Raceway, aka "The Fastest in the West" at speeds up to 130mph under race conditions.
MSRP is $329.99, and are now available at http://counterspacegarage.com/produc...-frs-gt86.html
*** There have been many requests for covers or trays to address rain. We are in the process of working with TrackSpec Motorsports to design a cover which will prevent water entry for parked cars. We do not recommend that you drive your car with the Hood Louver covers on. More information on the covers will be posted, as we finalize the design.
CounterSpace Garage is offline   Reply With Quote
Old 03-28-2016, 07:28 PM   #2
OnionTou
OnionTou's Avatar
Drives: Toyota GT 86
can you take a picture of the inside of the hood? (To see what had to be chopped or changed to get it installed).
Thanks!
OnionTou is offline   Reply With Quote
Old 03-29-2016, 12:35 AM   #3
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Here are some pics, including one from under the hood.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 03-29-2016, 03:25 AM   #4
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I love your car :o
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 03-29-2016, 08:06 AM   #5
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
God these look so good.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 03-30-2016, 01:17 AM   #6
zdr93523
zdr93523's Avatar
Originally Posted by MaximeT View Post
I love your car :o
BTW... That's my wife going out for a TT session in the last pic! Technically it is her car hahaha.
www.makesmodels.com
www.camautomag.com
Old 03-30-2016, 05:23 AM   #7
JasonXieyf
Drives: 15BRZ
One off-topic question, what front splitter are you using??? thanks
JasonXieyf is offline   Reply With Quote
Old 03-30-2016, 09:12 PM   #8
zdr93523
zdr93523's Avatar
DrivewayLabs 5"
www.makesmodels.com
www.camautomag.com
Old 06-21-2016, 02:27 PM   #9
eddieflyinv
eddieflyinv's Avatar
I would be very very interested in these, if there was a cover option.
I leave my car parked for a week out in the open at work so I couldnt justify installing them without a cover..
Sent from my LG-H812 using Tapatalk
eddieflyinv is offline   Reply With Quote
Old 06-21-2016, 10:34 PM   #10
CounterSpace Garage
It is the same logic used on all vented hoods. With covers, the vents don't quite vent. Without covers, you are a bit exposed. With that said, it is definitely a compromise between the application's goal and aesthetic goal. Many of our clients have parked their cars out in massive storms and driven in adverse environmental conditions without issue. Understandably, not everyone has the same level of DGAF attitude.
Old 06-23-2016, 01:16 AM   #11
zdr93523
zdr93523's Avatar
Get an outdoor rated car cover and protect the entire car. Problem solved.
www.makesmodels.com
www.camautomag.com
Old 06-23-2016, 11:32 PM   #12
eddieflyinv
Hahaha my DGAF attitude has a line drawn at water pouring under my hood when it sits outside for a week, but I get your point,
Idgaf if it happens while driving the car lol
Old 06-23-2016, 11:33 PM   #13
eddieflyinv
I would probably resort to that, integrated covers just seem way more convenient
Old 06-24-2016, 10:34 AM   #14
CounterSpace Garage
Yes. It's a varying form of it, however, any vented hood is a 'risk' regardless of rain covers or not.
Integrated covers don't allow air to be evacuated properly.
holy forum drama batman, rampart
TrackSpec Hood Louvers CounterSpace Garage Forced Induction 75 02-21-2017 08:09 PM
TrackSpec Hood Louvers CounterSpace Garage Cosmetic Modification (Interior/Exterior/Lighting) 15 07-27-2016 06:41 AM
