Old 03-27-2016, 11:11 PM   #3641
troek
troek's Avatar
Drives: 2012 Toyota 86
Swapping my pads back out after the track this weekend, I noticed this. Never had any brake fade at all, stayed out of ABS almost entirely. Its on both front outboard pads. The pads are Project Mu RSF 01A. Stock calipers. My current theory is using them cold on the way home from the track they maybe got too brittle?
troek is offline   Reply With Quote
Old 03-28-2016, 02:10 AM   #3642
zhelinm
Drives: Toyota 86
I have the exact same pads as well and they are also crumpling off at the edges. However, I might be overheating the front brakes quite a bit. Thermal paint shows that I am above 610degC for front rotors. Had Porsche GT3 brake ducts installed but no improvements noted (610degC pink paint still turn white). No issues with the brakes in terms of braking power or fade though. Would like to know as well if this is a problem too.
zhelinm is offline   Reply With Quote
Old 03-28-2016, 03:12 AM   #3643
CSG Mike
CSG Mike's Avatar
Definitely overheating the pad.
CSG Mike is online now   Reply With Quote
Old 03-28-2016, 03:13 AM   #3644
CSG Mike
CSG Mike's Avatar
Originally Posted by nova.86 View Post
Going to be tracking my HyperBlue in the future, I've got a lot of stuff planned but first thing I'd want to do is get coilovers w/ 18 x 9.5 +40mm wheels and some nice PSS tires.
I'd want some high quality coilovers, my question is, should I get the regular KW V3 coilovers? Or the Raceseng ones with added components, links for reference.
Car will be track & DD equally both. I don't mind if my suspension is rough on the streets if it performs well on the track.
KW Variant 3 + CasCam + Shock Top
KW Variant 3
I feel like with the cost of the Raceseng ones I should get Ohlins or something. To be honest though I just got into cars as a hobby buying the HyperBlue and just want what's best for the car as I'm going for a high-end build. Cost not being that much of a priority but definitely up there with with performance as #1
The best favor you can do for yourself, is to drive you car completely stock, in terms of performance mods.
Get an oil cooler, race pads, and good fluids for your first few days. You will learn more on the stocks suspension.
Cost not a priority? Performance is priority #1? Penske.
http://counterspacegarage.com/penske...-frs-gt86.html
Old 03-28-2016, 04:45 AM   #3645
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Got it, so you're saying track the car while it is stock and learn from it? Makes a lot of sense actually, I think I'll do that, rbf 660 just arrived at my doorstep too so I'm going to put that in this week, ? I won't track as often this year probably 3-4 times this year, maybe next year I can track more times but I will go to canyons often. I'm going to be looking into an oil cooler this week, does it matter which one if I plan on going forced induction in the future? Works Stage 2 turbo kit specifically. And although performance is definitely up there for priority I can only do so much as a student lol. My budget on racecar parts is I'd say 5-7k a year. I'll go high end when I get my engineering degree haha.
-edit also just noticed you guys are an hour and a half away from me
-second edit
Found this online on a FRS/BRZ group
Thinking of getting W3s
nova.86 is offline   Reply With Quote
Old 03-28-2016, 05:18 AM   #3646
troek
troek's Avatar
Well I guess ill try to take it easy with the back to back hot laps. Time to start saving for a bbk then huh?
Old 03-28-2016, 07:17 AM   #3647
ZionsWrath
Thanks
ZionsWrath's Avatar
Ecsta XS
AD08R
or ?
Need new HPDE tires. RE71R seem to be oriented more for time attack from my research and I'm not at that level yet. What should I buy? Or just get 71r?
Originally Posted by Uplink View Post
There's a track day at NJMP on Sunday the 10th if you want to do some research. Just sayin'.
My lawyer is a wizard apparently so I'm gonna sign up for sunday. Can't make the full weekend
Old 03-28-2016, 12:39 PM   #3648
Uplink
Uplink's Avatar
Drives: anything you let me
Ecsta XS
AD08R
or ?
I daily the car and have been extremely happy with the Direzzas. Great grip and feedback and break away progressively. The RE71R's have better peak performance characteristics at the expense of usable life.
Never ran the XS on the FR-s, only on my Vette (600lbs heavier). They were fantastic, but much like the RE71R's have a markedly shorter lifespan than the Direzzas.
Who is this magic man?
The event is only 1 day, Sunday. Saturday night is just early tech if you don't want to be at the track at 7am. If you get put on the waitlist (some run groups are almost full), PM me your info and I'll see what I can do.
Uplink is offline   Reply With Quote
Old 03-28-2016, 03:29 PM   #3649
CSG Mike
CSG Mike's Avatar
Step up your compound a bit more. Try the 999, or Racing Sintered.
Old 03-28-2016, 03:30 PM   #3650
CSG Mike
CSG Mike's Avatar
-second edit
Start with the W5 for track use within the Winmax lineup.
If you're gonna get a WORKS turbo kit, then you want to get the WORKS oil cooler, but as with everything else I see coming from that company, while they do ride at a racing facility, their products can do everything but.
Old 03-28-2016, 03:43 PM   #3651
jonnyozero3
Drives: 4 wheels & some metal bits
Not meaning to spam (I figure this is the group who would want to know), but I am selling my used AP Sprint kit, plus some pads, if any of you are interested:
http://www.ft86club.com/forums/showthread.php?t=103576
jonnyozero3 is offline   Reply With Quote
Old 03-28-2016, 05:47 PM   #3652
troek
troek's Avatar
Ok I'll look into those. I thought the RSF 01A were along the same lines at the 999 as they were rated 200-900C. Is that not the case?
Old 03-28-2016, 06:43 PM   #3653
CSG Mike
CSG Mike's Avatar
Don't look at just the temp range...
You may ultimately still need a BBK.
Old 03-28-2016, 06:51 PM   #3654
troek
troek's Avatar
Ok, I will give those a shot. Thanks for the help as always. I'll continue recommending you guys to everyone I come across looking for a shop in the states.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
