Old 03-26-2016, 07:49 PM   #239
kehvynh
kehvynh's Avatar
Drives: 2015 BRZ Limited
Is anyone running 265s on this set up? with coils obviously. Is it just me, but is the 255s still leave a little bit of room between the rim and wall?
kehvynh is offline   Reply With Quote
Old 03-26-2016, 08:14 PM   #240
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I'm running 265/35/18 in the rear. there's still room between the rim and the sidewall - that's just the design of the rim. the rim will always 'poke' out a bit from the sidewall of the tire unless your tire has rim protectors/scuff guards.
shiumai is offline   Reply With Quote
Old 03-27-2016, 10:48 AM   #241
kehvynh
kehvynh's Avatar
Thanks! Can 265 fit square? And do you have any close ups of how it sits?
Old 03-27-2016, 11:00 AM   #242
shiumai
shiumai's Avatar
that i don't know - i'm running a staggered setup. i have some pics in the build thread in my sig line below.
Old 03-27-2016, 02:16 PM   #243
Daver
So guys, I have read thru this thread completely, and am still unclear. I hear some people say I can and Some say I cannot run the setup I want to run on a fully stock suspension. (I want to avoid purchasing coil-overs and control arms)
18x9.5x40 all around on either
245/40/18
or
255/40/18
Anyone clarify for a newb?
Daver is offline   Reply With Quote
Old 03-27-2016, 02:27 PM   #244
Scuba86
Drives: 2014 FR-S Monogram Raven
245/40/18
or
255/40/18
Not 100% sure on that either but if you want that wheel size for the concave you can go for the 18x8.5 +42 that have the concave face as well and will weigh less and are guranteed to fit on stock struts
http://www.ft86club.com/forums/showthread.php?t=92445
Scuba86 is offline   Reply With Quote
Old 05-31-2016, 11:15 PM   #245
Ry.ruzn
Ry.ruzn's Avatar
245/40/18
or
255/40/18
If you want to kill your stock struts and springs go for it. It will rub on stock suspension and wouldn't reccomend it. Camber will be bad as well,then again not all cars are created equal.. Coilovers I do reccomend young skywalka.
Ry.ruzn is offline   Reply With Quote
Old 06-01-2016, 08:38 PM   #246
KriSD21
KriSD21's Avatar
Drives: Ultramarine Scion FR-S
I really want this set-up. Which vendor did you guys go through?
Looking for one in Southern California (Preferably in San Diego, but can go anywhere between SD, OC, & LA). TIA!
Invidia n1 | Valenti smoked tails | CF spoiler | shark fin
KriSD21 is offline   Reply With Quote
Old 06-08-2016, 12:05 AM   #247
Daver
I switched it out to the 9.5s in the back and the 8.5 face2s up front, hoping that does not cause as severe issues that you point out.
Old 10-09-2016, 11:28 PM   #248
ShootinPutin
Drives: None
Gram Lights 57Xtreme SP Spec 18x9.5 +40
ShootinPutin is offline   Reply With Quote
Old 10-25-2016, 08:23 PM   #249
Cuztomizer
Drives: ZN6
Originally Posted by Bcarlos View Post
Hello Fellas,
Long time coming. Had these Gram Lights Xtreme installed for a month already, but haven't had the time to post up pics. Anyway, would like to thank Adam from No Limit Motorsports.com. Got hooked up with a great price on these including Tien coilovers. He even included free Muteki lug nuts and hub center rings. Special thanks to dudes like Hayashi and JoeBoxer for helping me out choose which size tires to get.
Hope to see you all soon at Irvine and Crossroad meets. Wanna cough up some new mods and ideas from you guys. Next mod is Perrin catback exhaust, filter, and inlet tube from Mike @ teamczp.com
hi what is length of lug nuts on rays 57 xtremes
Cuztomizer is offline   Reply With Quote
Old 05-06-2017, 04:46 AM   #250
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Fitment is bang on. BANG ON.
Can I ask why you ran with lower control arms? Could you not achieve that flush look without?
Originally Posted by Xerious View Post
Glad to find this thread and part of the happy family of Gram Lights 57Xtreme owners. Here's my setup:
Wheels
Rays Gramlights 57xtreme 18x9.5 +40 Square
Tires
255/35/18 Yokohama Advan Neovas
Suspension
Stance CoilOvers
Stance LCAs
Engine/Exterior:
Perrin 3" CBE
Sound delete
Tap Turn Module
DRL Mod
Tom's Clear Tail Lights
white_knight is offline   Reply With Quote
Old 05-06-2017, 01:16 PM   #251
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Yes you can fit it, I have an inch drop. I'm not at home, right now, but this is the best I can do
I got my fenders front and rear, rolled.
Alignment settings are -2 Front, -1.5 Rear, if I remember.
Edit: http://www.ft86club.com/forums/showp...postcount=2099
Alltezza is offline   Reply With Quote
Old 09-17-2017, 08:58 PM   #252
michaelmil
Drives: scion fr-s
Hi All,
I'm getting the 18x9.5 all around and wanting to do research on tires. For right now Planning on wearing out stock suspension. I don't want to have to stretch the tires and have excess wheel showing, rather I'd like to get tires that covers the whole rim, preferably even giving some excess sidewall for wheel protection.
However of course with stock body and suspension what's the widest tires can these fit?
A.) For size 255: seems to be the neutral not too narrow - too wide. What height? 255/35...255/40? What brand of tires, recommendations, experiences, pics?
B.) Would 265 width fit? what height treadwall...265/35? Would it fit stock? don't mind if have to roll fenders, doesn't seem like its that hard?
michaelmil is offline   Reply With Quote
gramlights 57xtreme, toyo tyres
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 05:57 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 MVJ1975 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 10-05-2013 02:29 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 12:44 PM
