Old 03-24-2016, 04:13 PM   #29
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Buy separate hats? Other than ST and z flex I haven't heard of anything recommended under $1400. If you aren't doing a ton of racing most anything but Megan is probably ok. I have Stance ($1100ish) and they seem ok. First set of coils though so... take it for what it's worth to you. Maybe get a good set used in classifieds for <$1000
I would stay away from BC and Megan if ride quality matters
Old 03-24-2016, 04:16 PM   #30
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
The s2ki guys love their Fortune 500s. Other than that weird cup kit thing ice never heard bad about Fortune
yeah the new air lift is still in development for the FRS they messed up and released it too soon before making sure it fit the FRS lol!!
Old 03-24-2016, 04:17 PM   #31
Ashikabi
Ashikabi's Avatar
Shit happens. Doesn't mean their quality is bad. Just might not fit lol
The Following User Says Thank You to Ashikabi For This Useful Post:
go_a_way1 (03-24-2016)
Old 03-24-2016, 04:21 PM   #32
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
exactly I think they are trying to appeal to the stance crowed now as well as the track crowed. Not a bad move as a company to reach more customers
Old 03-24-2016, 04:31 PM   #33
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
FA prime might be worth looking into. its the low end line that fortune auto just came out with to compete with BC/Megan/Flex Z ect.
http://www.ft86speedfactory.com/prim...l#.VvRIkeIrLcs
Likely no reviews as they are brand new and FA is a fairly new company but honestly a great company. Pick up the phone and drill them with questions I challenge you, those guys know their stuff hahaha!!
I would highly recommend upgrading to swift springs, Swift makes some of the best springs in the world.
Definitely look into that.
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
Old 03-25-2016, 03:37 AM   #34
FR-Sky
FR-Sky's Avatar
Alright I am going to assume 1-1.5inch drop only any lower and I will suggest another route. Get camber bolts for the front and max them out (aim for -2.5 camber front but you will likely only get about -2.0) Get cheap LCA's for the rear and set you camber to -1.5 to -2.0 camber in the rear and dial in the under-steer/over-steer you desire but adjusting the camber accordingly. More camber in front = over-steer, more in the rear means under-steer.
If any of this does not make sense to you then you should not be putting coilovers on your car. and have fun!
Do you have a picture of -2.5 front camber ???
thanks
Old 03-25-2016, 06:15 AM   #35
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
The Flex Z are disposable coilovers,
Pedant mode.
The coilovers are not disposable; just the damper part. One replaces the damper not the whole unit.
go_a_way1 (03-28-2016)
Old 03-25-2016, 08:26 AM   #36
Ashikabi
Ashikabi's Avatar
thanks
I could take a pic of my 3.5 I guess. It's noticeable but not stanced. If someone thinks it is, it's because they are stupid and you probably wouldn't talk to them. Hard cornering rolls your wheel out a certain number of degrees based on how hard you're turning and wears the outside edge of your tire. Camber just preadjusts it so under cornering your wheel is at ~0 camber. It's not something you should be doing or not doing for looks. Too low OR too high of camber will REDUCE cornering traction. Around-3 front is good for MOST racing applications and won't adversely wear your tires. After 8k or so miles I'd consider a rotation though, just to keep it even. You can always measure tread depth
Old 03-26-2016, 08:13 PM   #37
FR-Sky
FR-Sky's Avatar
OK, i just bought these.
http://www.ft86speedfactory.com/prim...l#.VvclHPlrhqM
What is the best spring rate? For DD,,1 or 2 track per year.
i chose 8k front 8k rear. Is it ok?
Old 03-27-2016, 12:31 AM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
ahhhh crap, who let @go_a_way1 answer the questions -.-
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 03-28-2016, 07:51 AM   #39
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
thanks
Not yet, give me 2 weeks or so and I will once the summers go on.
Old 03-28-2016, 07:53 AM   #40
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Pedant mode.
true, but you are still replacing not rebuilding
Old 03-28-2016, 07:55 AM   #41
ZionsWrath
Thanks
ZionsWrath's Avatar
If you just do a track day a year just set it up for street and live with whatever it does on track. No reason to compromise the 99% of your use.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 03-28-2016, 07:56 AM   #42
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I run 7k front and 8k rear its way stiffer then stock so if you can live with that sure, but a 6kish rate will probably be more comfortable
LMAO I do know a thing or 2, but I tend to spend most of my time in off topic
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
cdrazic93 (03-28-2016), FR-Sky (04-02-2016)
Question on suspension. skavengers412 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-08-2015 11:12 PM
Suspension Set Up Question FR-Shred Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-01-2015 01:50 PM
suspension question... FloridaBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-17-2014 12:37 PM
Suspension Question TONYpepperon1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-12-2013 08:57 AM
BRZ vs. FRS suspension question smbrm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-12-2012 09:55 AM
