Old 03-22-2016, 06:12 PM   #15
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Another 1st gen here, probably one of the earlier cars (purchased May 2012), ~38k mi (~3k mi on Edelbrock SC). Have not had any issue other than ignition coil CEL back when I was stock. The "hesitation" mentioned by others appears to be common among other FI'd cars, not only Edelbrock.
Old 03-22-2016, 06:34 PM   #16
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
What does "1st gen" actually mean in this post? I think its a misnomer used here.
I have an early 2013 BRZ. 48k, boosted for 10k. Ive never had cam or ECU issues. I had REALLY bad hesitation and stalling issues while I was on a Delicious tune (not a knock at Delicious, just didnt have good luck with my setup) I went to Dynosty in Louisville and got about 16 hours of dyno time, car drives WONDERFUL now. No issues.
xkalelx is offline   Reply With Quote
The Following 2 Users Say Thank You to xkalelx For This Useful Post:
continuecrushing (03-23-2016), nickmerronesucks (03-23-2016)
Old 03-22-2016, 08:59 PM   #17
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
It refers to the pre-2013.5 engines where they originally had different sized lifts than the ones on the engines now.
Spinning Sushi is offline   Reply With Quote
Old 03-22-2016, 10:56 PM   #18
armstrom
Drives: none
Is there a definitive method to determine which cars are prone to this problem? I just bought a 2013 BRZ Limited and would like to keep my options open for going FI in the future. My car was built in 12/12... Is there any way to mitigate the problems or is it just a wait and see thing?
-Matt
armstrom is offline   Reply With Quote
Old 03-22-2016, 11:47 PM   #19
86fun
Drives: 2013 FRS
For me it's just a suspicion. Tunes that apparently work fine on a bunch of other cars don't work at all on mine.... and the thing that worked around the issue, for the most part, was putting the cam timing back to stock. This tells me there is something fishy going on with the cams/timing/ecu or something related in my car.
86fun is offline   Reply With Quote
The Following User Says Thank You to 86fun For This Useful Post:
Sherb (04-26-2016)
Old 03-23-2016, 12:00 AM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Any way to remove all doubt if you think your engine will call it kaputs, is to build it.
If you are only buying an SC unit (the bare minimum) then you need to take a closer look at how complete you think a build needs to be for this car.
I agree wholeheartedly with Sportsguy. Its not just one thing or a few things that make it reliable, the car works dynamically, as soon as the checks n balances are thrown out of wack the rest of the system needs to be brought up to spec.
Old 03-23-2016, 01:16 AM   #21
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
Isn't there another change in the valvetrain in the 2015 and up models?
i'm asking because of those roller rockers shooting off on people who are FI lately and it's a scary thought
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
Old 03-23-2016, 03:59 AM   #22
ajc209
Drives: GT86 Cosworth
2012 GT86 picked it up September 12. Drove it stock for 3years fast road and a few track days. It's the toy car so gets thrashed (once warm).... I've had the Cosworth SC kit and tune for 5 months and its faultless. I used to get hesitation with the stock tune in cold weather and low revs sometimes but now it smooth as honey from 1500-7500rpms.
ajc209 is offline   Reply With Quote
Old 03-23-2016, 09:49 AM   #23
Yoda
Drives: Crystal Black BRZ(Sophia)
Got my car in June 2012, boosted at 552 whp (with 4 maps for different boost levels) for 2+ years, still running strong.
Boost, but also added all the supporting mods to it like suspension, brakes, cooling, catch can, clutch, motor mounts, fueling, wheels/tires, flex fuel kit and solid tune.
Who did your tune so I can visit them
Yoda is offline   Reply With Quote
Old 03-23-2016, 10:12 AM   #24
Dream20b
Y u do dis?
ran between 8 and 10 thousand miles on a Sprintex 210 kit with zero issues besides shredded belts- mostly my own fault. I am currently upgrading to a Sprintex 335 and hope for the same. 13 frs but unsure of build date
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-23-2016, 10:42 AM   #25
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
stock motor?
Old 03-23-2016, 10:45 AM   #26
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
James Martin at HRI Tuning in Orlando. Simply one of the best if not best tuner for this platform.
Originally Posted by NyC Zn6 View Post
stock motor?
Yes, stock motor.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
GhostOp86 (03-23-2016), NyC Zn6 (03-23-2016)
Old 03-23-2016, 10:45 AM   #27
NyC Zn6
NyC Zn6's Avatar
Yes, stock motor.
Goes to show that a good tune can go a long way
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
GhostOp86 (03-23-2016), Sportsguy83 (03-23-2016)
Old 03-23-2016, 12:36 PM   #28
xkalelx
xkalelx's Avatar
There definitely isnt enough emphasis on tuning in this community as a whole. I think its more important than anything else.
The Following User Says Thank You to xkalelx For This Useful Post:
Additional considerations when boosting 86 South Africa Forced Induction 10 12-28-2015 06:54 PM
Boosting Auto 13' Frs SPAGNOLA Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 11:19 AM
Boosting my FR-S Team86 Forced Induction 48 11-10-2014 06:24 PM
General boosting question Pneub Forced Induction 8 10-30-2013 02:36 AM
finally boosting on my custom setup! Silverdub Forced Induction 25 04-30-2013 10:52 PM
