Old 03-22-2016, 04:04 PM   #3627
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Uplink View Post
There's a track day at NJMP on Sunday the 10th if you want to do some research. Just sayin'.
Ill go if i can but all my plans are on hold right now. My lawyer is at my court day today to see if my license suspended
Also I need new tires but I can squeeze a day out of these
Old 03-22-2016, 04:16 PM   #3628
Uplink
Uplink's Avatar
Drives: anything you let me
Oh man, good luck! What did you not do?
Uplink is offline   Reply With Quote
Old 03-22-2016, 04:47 PM   #3629
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Plus when you eventually install the Edelbrock SC, it'll fit.
Hey now, we'll install ours eventually.
GSpeed is offline   Reply With Quote
Old 03-22-2016, 04:55 PM   #3630
Uplink
Uplink's Avatar
Guilty conscience? I meant that at 240, not you. But if the shoe fits...
(Oh, that made my day. Actually LOL at work. )
Old 03-22-2016, 04:56 PM   #3631
ZionsWrath
Thanks
ZionsWrath's Avatar
Just the usual. But for whatever reason the cop decided to give me much more than just a speeding ticket. Oh well, RIP driving privileges most likely, hope its not long.
Old 03-22-2016, 06:33 PM   #3632
ka-t_240
Honestly, unless you're REALLY frugal... buy a kit. I was able to source the stuff to build a 'Perrin-ish' setup with everything they use except the hoses for about $150 less than buying the kit. But I still would have had to make the hose ends and they were braided steel instead of the nice coated ones and didn't have nice crimped ends and the parts didn't have the lifetime warranty... So I bought the Perrin kit.
Mishi is even less expensive so you'd wind up saving even less money trying to build it.
Basically, unless you really like to fabricate your own stuff, want to save every last dime possible, or need some custom application (like mounting behind a fog light or at the rear of the car with a fan, etc.), most people wouldn't find the trouble worth the savings.
I like to build stuff, and if I get lazy my roomate makes Hydraulic lines for a living, I'm sure we could make some amazing lines. The biggest issue would be the Adapter.
ka-t_240 is offline   Reply With Quote
Old 03-22-2016, 06:39 PM   #3633
Uplink
Uplink's Avatar
That's easy... http://www.racerpartswholesale.com/p...andwich_Plates
Old 03-22-2016, 07:02 PM   #3634
CSG Mike
CSG Mike's Avatar
Originally Posted by Pat View Post
Is the Works turbo kit decent on track? I may be behind the times, but I thought anyone with a turbo able to drive their car at the limit would have overheating issues on track without insane mods (i.e. element tuning). AFAIK anyone that is even remotely serious about tracking their car with forced induction goes with a JRSC kit or maybe something similar.
I hope to one day actually see some data on the WORKS kit.
CSG Mike is online now   Reply With Quote
Old 03-22-2016, 08:33 PM   #3635
CB762
CB762's Avatar
Drives: Scion FR-S
Here's our test results of running 0W-20, 5W-30, and 5W-30 w/ oil cooler on track.
http://www.ft86club.com/forums/showthread.php?t=91820
Basically, 5W-30 is "mandatory" and an oil cooler is "a really good idea."
Will it make much difference (for hot track days) to run 10W-30 instead of 5W-30? I don't know much about engines.
TIA.
CB762 is offline   Reply With Quote
Old 03-22-2016, 11:03 PM   #3636
driggity
Drives: Silver Coupe with a Boxer
Does the mocal plate fit directly or is it one that requires extra clearance because of the lip on the stock filter location?
driggity is offline   Reply With Quote
Old 03-23-2016, 12:15 AM   #3637
Uplink
Uplink's Avatar
TIA.
The first number is your cold start viscosity. When both of those oils come up to operating temps they are a 30 weight.
As was mentioned earlier the lower cold start weight oil might have a slight compromise at the higher end of it's usable temperature range, but you probably won't notice the difference.
Old 03-23-2016, 12:20 AM   #3638
Uplink
Uplink's Avatar
Not sure, might need a spacer. Shouldn't be too hard to have a shop CNC one though, it's basically a pass through section of 3" rod stock.
Old 03-23-2016, 10:04 AM   #3639
cjd
cjd's Avatar
Drives: 2017 BRZ
Racer X sells just the plate with the included adapter. http://racerxfabrication.com/frs-brz...-adapter-plate
Old 03-27-2016, 06:09 PM   #3640
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Going to be tracking my HyperBlue in the future, I've got a lot of stuff planned but first thing I'd want to do is get coilovers w/ 18 x 9.5 +40mm wheels and some nice PSS tires.
I'd want some high quality coilovers, my question is, should I get the regular KW V3 coilovers? Or the Raceseng ones with added components, links for reference.
Car will be track & DD equally both. I don't mind if my suspension is rough on the streets if it performs well on the track.
KW Variant 3 + CasCam + Shock Top
KW Variant 3
I feel like with the cost of the Raceseng ones I should get Ohlins or something. To be honest though I just got into cars as a hobby buying the HyperBlue and just want what's best for the car as I'm going for a high-end build. Cost not being that much of a priority but definitely up there with with performance as #1
nova.86 is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
