Old 03-21-2016, 04:45 PM   #3613
CSG Mike
CSG Mike's Avatar
Originally Posted by nova.86 View Post
Should I get a lightweight underdrive pulley kit if I'm planning to get a turbo kit in the future? More precisely the works stage 2 turbo kit. Pros & cons of pulley w/ kit and without? Are there any issues with a pulley kit and boosted engine?
Negative; use your stock pulleys, or a fluidampr.
Old 03-21-2016, 10:52 PM   #3614
peaches
Drives: '14 BRZ Limited
Spent the weekend at NCM, first time on that track. Fun course after you get to know it, ran brand new Kumho V720, lots of grip.
Day 1 was cold but dry, 45 all day. Started with a 3:28.595 and ended up with a 2:47.646. Could have dropped more if the session hadn't been cut short. Video for the fast lap was corrupted, so this is for the previous fast lap 2:49.561. I know I can brake later in some areas, less in others and use more of the track.
[ame="https://www.youtube.com/watch?v=0hQUsbHRQVg"]NCM - BRZ HDPE3 NASA Great Lakes YouTube[/ame]
Day 2 was a wet track, 39 and windy. Started with a 4:32.266, ended up with a 3:17.952, switched to Continental DWS. I was told there is no good wet line, so I had to figure it out on my own.
[ame="https://www.youtube.com/watch?v=Hk9mwQPWD6E"]NCM wet track - BRZ HDPE3 NASA Great Lakes YouTube[/ame]
peaches is offline   Reply With Quote
The Following 2 Users Say Thank You to peaches For This Useful Post:
CSG Mike (03-22-2016), DocWalt (03-21-2016)
Old 03-22-2016, 05:20 AM   #3615
Northwest86
Drives: Velocity Orange 86 GT
Originally Posted by Pat View Post
Is the Works turbo kit decent on track? I may be behind the times, but I thought anyone with a turbo able to drive their car at the limit would have overheating issues on track without insane mods
Here in Aus the Sprintex has the majority of the supercharger market (being more local) The JRSC is almost nonexistent since no-one locally sells it. All of our fast FI guys are Turbocharged and with our setup, Overheating with a oil cooler alone has proven to not be a problem with sessions up to 30 minutes. But the kit we run is a much better kit than the others we've seen for both efficiency and heat.
Note some of us run well over 200kw at the wheels (230kw on most other dynos) but use EBC's to turn the turbos down somewhat simply to help with traction and to better suit our local tracks. Mind you we don't run Aero or big track builds so we are limited on grip. Good Suspension and R-spec Semis are what most of us run.
Northwest86 is offline   Reply With Quote
Old 03-22-2016, 09:15 AM   #3616
CB762
CB762's Avatar
Drives: Scion FR-S
I'm asking for an opinion on motor oil: are there any benefits of using 5W-20 or even 10W-30 on hot track days (80F .. 90F)? I was using Amsoil for years on other car and they offer only 5W-20 or 10W-30 racing oil.
(Car never goes out when temp < 50F).
TIA!
CB762 is offline   Reply With Quote
Old 03-22-2016, 10:04 AM   #3617
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
TIA!
The "W" stands for winter and is the cold start (car sit over night = cold start) viscosity so for this case you can ignore that number. Ideally you want it as low as possable so the oil flows better on start up. 90% of engine ware come from those cold starts. The second number is the viscosity rating at 212F (If I remember right) so this one is more important in this case.
You will maintain better oil pressure at higher temps with a thicker oil. Persnally I will never put anything but 0W-20 in my car. That being said I have an oil cooler so no need for me to go with a thicker oil. A 0W-20 will also get a slight (very very slight at track temps) increase in HP over a 5W-30. A 0W-20 will also get slightly better fuel economy but who cares about that on the track
TL;DR Use a 5W-30 on the track if you do not have an oil cooler
CB762 (03-22-2016)
Old 03-22-2016, 11:32 AM   #3618
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
I use 5W-30 on track with an oil cooler. I'm also supercharged.
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 03-22-2016, 02:06 PM   #3619
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Here's our test results of running 0W-20, 5W-30, and 5W-30 w/ oil cooler on track.
http://www.ft86club.com/forums/showthread.php?t=91820
Basically, 5W-30 is "mandatory" and an oil cooler is "a really good idea."
GSpeed is offline   Reply With Quote
The Following 4 Users Say Thank You to GSpeed For This Useful Post:
Bramick (03-22-2016), CB762 (03-22-2016), DocWalt (03-22-2016), ZionsWrath (03-22-2016)
Old 03-22-2016, 02:37 PM   #3620
ka-t_240
What oil cooler should I run, or should I make my own?
ka-t_240 is offline   Reply With Quote
Old 03-22-2016, 02:45 PM   #3621
ZionsWrath
Thanks
ZionsWrath's Avatar
I run 5w30 with an oil cooler. But I got no data, just basing my decisions of the experienced guys on this forum and thread. I'm relatively new to track but I hope to get some more experience and data logging equipment in the near future.
Old 03-22-2016, 03:41 PM   #3622
Uplink
Uplink's Avatar
Drives: anything you let me
There's a track day at NJMP on Sunday the 10th if you want to do some research. Just sayin'.
Uplink is offline   Reply With Quote
The Following User Says Thank You to Uplink For This Useful Post:
Old 03-22-2016, 03:43 PM   #3623
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Anything that wont leak is a good start lol! I run mishimoto and it does the job, nothing fancy.
Old 03-22-2016, 03:50 PM   #3624
Uplink
Uplink's Avatar
Honestly, unless you're REALLY frugal... buy a kit. I was able to source the stuff to build a 'Perrin-ish' setup with everything they use except the hoses for about $150 less than buying the kit. But I still would have had to make the hose ends and they were braided steel instead of the nice coated ones and didn't have nice crimped ends and the parts didn't have the lifetime warranty... So I bought the Perrin kit.
Mishi is even less expensive so you'd wind up saving even less money trying to build it.
Basically, unless you really like to fabricate your own stuff, want to save every last dime possible, or need some custom application (like mounting behind a fog light or at the rear of the car with a fan, etc.), most people wouldn't find the trouble worth the savings.
Old 03-22-2016, 03:51 PM   #3625
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Perrin's kit is good, they use a Setrab core. We've got one on the shelf right now.
The Following User Says Thank You to GSpeed For This Useful Post:
Old 03-22-2016, 04:01 PM   #3626
Uplink
Uplink's Avatar
Plus when you eventually install the Edelbrock SC, it'll fit.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
