Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 03-22-2016, 04:32 PM   #1
TheGut
Drives: 2014 Toyota 86 Hi A/T
BRZ vs 86 radio
Hey guys
New here and just want to make sure about something. This may be a very dumb question, but is the BRZ and the 86's radio's identical? I am looking at getting this headunit once I buy the car, but need to know it will work in the BRZ as well: http://www.kenwood.com/au/car/visual...ion/ddx715wbt/
Thanks in advance
TheGut is offline   Reply With Quote
Old 03-22-2016, 05:15 PM   #2
AT-86
AT-86's Avatar
Drives: 2013 Grey Toyota 86 High 6MT
As far as I can see and tell, they're identical.
Same hilux radio I had.
AT-86 is offline   Reply With Quote
Old 03-23-2016, 02:17 AM   #3
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Yep - pic above same as my Toyota.
I like driving!
86 South Africa is offline   Reply With Quote
Old 03-24-2016, 03:44 AM   #4
LostSalad
Drives: Toyota 86 - Charcoal Grey
Not at all like mine. I have the 86 hi-spec. It's a big touch screen. Wouldn't they be likely to have the same connectors to the car though?
LostSalad is offline   Reply With Quote
Old 03-24-2016, 04:25 AM   #5
AT-86
AT-86's Avatar
The cars will all have the same Toyota harnesses, only with different radios fitted from the factory.
"He who shall be last, shall be sideways and smiling."
Old 03-24-2016, 05:16 AM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by TheGut View Post
Hey guys
Thanks in advance
This isn't entirely true, the BR-Z navigation head unit not only has a subaru gps antenna which is easy to get.
The FR-S/GT86/86 HU sends power to the car's antenna booster amplifier via the separate single-conductor wire on the AM/FM antenna connector.
The BRZ HU sends the 12V power antenna signal out via pin #8 on the 10-pin power/speaker harness.
You'll need to rig up an adapter harness (or at least, add a jumper wire from the vacant slot on your car's 10-pin plug to the factory pin/wire on your car's AM/FM antenna plug.
This has been proven in other threads, that's why it's not worth transplanting one of the twins head units into each other unless they can be had for super cheap.
Old 03-24-2016, 05:56 AM   #7
TheGut
Awesome thanks for the reply. So would the above Kenwood headunit work?
Sent from my D6603 using Tapatalk
Old 03-24-2016, 06:06 AM   #8
FRSBRZGT86FAN
You may need to get a qualified installer to do it, there's another issue with our cars, the door speakers have a separate amplifier, and most head units aren't pinned to turn that amplifier on therefore the door speakers don't work but all others do. The result is the sound is low quality.
http://www.ft86club.com/forums/showthread.php?t=87247
http://www.ft86club.com/forums/showp...8&postcount=20
Those threads may help
Old 03-24-2016, 06:47 AM   #9
TheGut
Ok, will definitely check with my installer. I am changing the whole system though, but thanks for the heads up
Old 03-24-2016, 10:04 AM   #10
LostSalad
Super useful info, thanks for helping us Africans out @
I opted to not pay extra for the built in navigation. My experience with any "built-in" software vs a dedicated solution has usually ... left much to be desired. Is it possible to a) enable this without the dealership or b) just pay $$ to have it activated?
Does anyone have the GPS running on their 86 and is it worth it?
Old 03-24-2016, 11:54 AM   #11
86 South Africa
I use waze (on my phone) with a holder thing similar to what the uber drivers use. Hands free and the app is free too!
I like driving!
Old 03-24-2016, 04:02 PM   #12
FRSBRZGT86FAN
Super useful info, thanks for helping us Africans out FRSBRZGT86FAN
I don't know if our head units are similiar, but I bought a simple module, gps antenna, and a special harness and it enables the OEM toyota Entune system and navigation not sure if it works on your car.
Old 03-25-2016, 01:40 AM   #13
AT-86
AT-86's Avatar
I don't like head unit navigation. I have a Kenwood DDX715WBTM so I mirror my phone's Google Maps for navigation and realtime traffic.
Old 03-25-2016, 12:53 PM   #14
LostSalad
Hmm. Is it targeting the 86 specifically? If it's a super custom solution, it probably won't be available easily in ZA. Is it reliable?
I also use Google Maps, but the amount of battery drain is insane.
App Radio 2 Guaruja Electronics | Audio | NAV | Infotainment 11 11-28-2013 05:49 PM
Noticeably low and sharp volume with AM radio stations with stock BRZ radio tracerit Electronics | Audio | NAV | Infotainment 0 07-24-2013 02:38 AM
aha radio mechaghost BRZ First-Gen (2012+) — General Topics 1 08-12-2012 11:08 PM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 11:24 AM
BRZ HD Radio on/off ashtray Electronics | Audio | NAV | Infotainment 0 06-07-2012 12:42 AM
