#211 |
Drives: 10 Series #974 6m/t
#212 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
My tuner @Ross recommended me go with the KV8 for cost + build requirements. No reason to go with anything much higher (maybe the KV12 if I were trying to run dual injectors or something). Considering I have ID2000's, that'll support plenty of power by themselves.
| The Following User Says Thank You to slicktop For This Useful Post: | NyC Zn6 (02-03-2016) |
#213 | |
#214 |
DSS Pro-level axles just shipped as well~
#215 |
Just registered for WannaGoFast on 1 May in VA. If anyone will be out there, stop by and say hi - I'm curious to see what the FRS will do in the 1/2 mile. I'm thinking of upgrading to a surge tank, but I don't know if I have the time to. We'll see.
![]() ![]() The car should be ready next week.
| The Following User Says Thank You to slicktop For This Useful Post: | Stigasaur (02-19-2016) |
#216 |
Forgot I had this pic..
#217 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
what axles are they?
797Performance.com
#218 |
Driveshaft Shop - Pro Level axles
#219 |
Drive Shaft Shop http://www.driveshaftshop.com/
#220 |
The harness is about wrapped up and ready to roll.
#221 |
Drives: Toyota GT86 Pearl White
That harness is lovely! fantastic work. Following this build like mad, it's very close to what i'm doing at the moment. goodluck
#222 | |
Thanks a ton man! The harness was done by Brandon @ Trust Automotive in Chesapeake, VA.
#223 |
Yep. This happened.
#224 |
It's confirmed that Emtron works. I just got back from driving the car. EPS, tach, fuel level, coolant temp, speedometer are all working. @Ross will be using the Emtron to control traction control.
![]() ![]() ![]() [ame="https://www.youtube.com/watch?v=B8Bne1XCBLg"]2JZ FRS Idle - YouTube[/ame] [ame="https://www.youtube.com/watch?v=T3lDx5ptZYw&nohtml5=False"]2JZ FRS low speed drive-ability - YouTube[/ame]
| The Following 6 Users Say Thank You to slicktop For This Useful Post: | Draco_PR23 (04-09-2016), mmmcambelsoup (05-11-2016), NyC Zn6 (04-07-2016), R2RO (04-07-2016), rookie (04-07-2016), tirespin782 (04-07-2016) |
| Tags |
| 2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| Mr and Mrs FR-S Build | jaydee_do_work | Member's Car Journals | 2 | 12-04-2013 09:51 AM |
| 86 BUILD, AUS | JS86JS | Member's Car Journals | 9 | 05-31-2013 08:59 AM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 04:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 03:40 PM |
