Old 03-22-2016, 03:52 AM   #1
frsqc
Drives: raven FRS
Boosting 1st gens
It seems all im reading lately is that first gens ECU or the cams/valve issue comes up once you boost first gens. Ive had my car for almost 4 years now , early adopter first batch of production, about 34000km, On oft stage 2 and ive been wanting to go with a Supercharger but these stories have been keeping me away... Is it just a select few who have this issue ? Is it not as bad as it seems on the internet?
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
The Following User Says Thank You to frsqc For This Useful Post:
Sherb (04-04-2016)
Old 03-22-2016, 04:07 AM   #2
86fun
Drives: 2013 FRS
Besides the batch that had actual codes thrown and such, supposedly no others have the issue, but I wonder. I have issues that no one else has going SC and mine is a late first model year... however I did find one person in the official issue list which had a production date later than mine even.
With my edelbrock kit I'm not running correctly, we had to use stock cam timing to make it work, and still it's not really completely smooth.
I really wish I knew the answer to this one.
86fun is offline   Reply With Quote
Old 03-22-2016, 06:54 AM   #3
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Ya first gen has a valve issues on the forums. Also see more people eating valve rockers with 13 and early 14s. Of course no one new about this until a huge pattern started. Maybe people with the 13 and early 14 have tuning issues or something. I wouldnt take a chance with it all and build your engine if going FI.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-22-2016, 07:33 AM   #4
wbradley
Sarcastic SOB
wbradley's Avatar
Mine is doing fine.
The Following User Says Thank You to wbradley For This Useful Post:
Respect BRZ (03-23-2016)
Old 03-22-2016, 08:15 AM   #5
djdnz
1337
Drives: 2013 BRZ WRB S/C
I got my BRZ in July 2012, and put on an edelbrock supercharger at around 25k miles. No major issues so far, knock on wood but I do have some low-mid rpm hesitations that most of the other people don't seem to talk about. The car never threw any codes before or after the supercharger install.
djdnz is offline   Reply With Quote
Old 03-22-2016, 08:22 AM   #6
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
I'm having the same thing with Jackson... a few low to mid-range hiccups.
Spinning Sushi is offline   Reply With Quote
Old 03-22-2016, 11:46 AM   #7
frsqc
Drives: raven FRS
This is not reassuring at all lol. What do you all mean by low to mid hesitations??? I forgot to mention i still get that snmall rpm dip to on idle even after the oft but never threw a code either. For now it seems first gen really are cursed.:/
Old 03-22-2016, 11:57 AM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Got my car in June 2012, boosted at 552 whp (with 4 maps for different boost levels) for 2+ years, still running strong.
Boost, but also added all the supporting mods to it like suspension, brakes, cooling, catch can, clutch, motor mounts, fueling, wheels/tires, flex fuel kit and solid tune.
The Following 6 Users Say Thank You to Sportsguy83 For This Useful Post:
ATL BRZ (03-22-2016), GhostOp86 (03-22-2016), Kris86 (03-24-2016), MisterSheep (03-22-2016), xkalelx (03-22-2016), Yoda (03-23-2016)
Old 03-22-2016, 12:10 PM   #9
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I've also considered boosting and I have a "1st gen" it's a 2013 with 36k miles right now and has had the ECU replaced under warranty due to a CEL for a Cam gear.
Instagram: trevor.parque
Old 03-22-2016, 12:16 PM   #10
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Boosted 1st Gen. 36xxx, ~10K Boosted Miles. Just starting to get the Cam Gear CEL. Only happens on long trips, though it threw an ABS code that didn't give a CEl this last trip. Starting the diagnosis process as soon as I get time.
The Following User Says Thank You to DustinS For This Useful Post:
Old 03-22-2016, 01:00 PM   #11
86fun
Drives: 2013 FRS
I have hesitation issues too, that's the majority of my remaining issues since we went back to stock cam timing. It stalls sometimes when starting out or dips heavily at very low RPM/low throttle when shifting. I also get "bumps" in the power band when doing a WOT run.
I still consider the car quite drivable, but it's not ideal.
Old 03-22-2016, 04:55 PM   #12
djdnz
1337
I'm thinking of getting Shiv to custom tune my car with OFT since I'm local - I just want to double check my work and make sure theres nothing mechanical that could be wrong.
Old 03-22-2016, 05:21 PM   #13
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I,ll just say this: BOOOOOOSSSSTTTT DO IT!!!!
fumanchu1 is offline   Reply With Quote
Old 03-22-2016, 05:25 PM   #14
fumanchu1
Seriously though buddy @frsqc I have a KW c38 boosted BRZ (early 2013), it's been boosted for 20k+ km and is still going strong (aside from my throwout bearing but that's another thing).
Anyways I'm from Gatineau and you are more than welcome to make the drive down here if you'd like to see one in person and go for a ride shotgun in it see how it feels (and how nothing wrong is happening).
It's still not completely finished (few things like gauges, oil cooler, and other small things) need to be added and my tune does need a small revision but hell it made the trip from Mississauga to Gatineau no problem and hasn't given me any trouble yet(aside from a spinout and curb jumping session but that's more me than the car lol).
Additional considerations when boosting 86 South Africa Forced Induction 10 12-28-2015 06:54 PM
Boosting Auto 13' Frs SPAGNOLA Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 11:19 AM
Boosting my FR-S Team86 Forced Induction 48 11-10-2014 06:24 PM
General boosting question Pneub Forced Induction 8 10-30-2013 02:36 AM
finally boosting on my custom setup! Silverdub Forced Induction 25 04-30-2013 10:52 PM
