Old 03-22-2016, 12:20 AM   #463
DSOmegaX
DSOmegaX's Avatar
Originally Posted by ed_423 View Post
just read through the whole build and i love it! def sway me to get some sti wheels in 18's. im still iffy on the sti springs though, i want a very very mild drop but 15mm seems too minimal, the front is fine but rear gap still seems pretty big. with that said, i haven't completely ruled it out yet. with the sti springs, is there really any need to angle? or for most places you can just go head in no problem, maybe just at a lower speed or something.
With the front lip there are still plenty of curbs I angle at just to be safe. I definitely don't need to go crazy like the truly dropped cars but it's always better safe than sorry.
@dsomegax.cars
Old 03-22-2016, 12:46 AM   #464
ed_423
ed_423's Avatar
Drives: 2016 BRZ Limited
awesome, so without a lip i pretty have have no problems 80% of the time then.
and since you're from socal too, it's good to know haha.
one more question. correct me if im wrong, but i want to know if the 18s sti wheels made the car feel slower? but if i read your build thread correctly, you got a tune before you threw the 18s on so im guessing that kinda made up for it if there were any negative effects
ed_423 is offline   Reply With Quote
Old 03-22-2016, 01:36 AM   #465
DSOmegaX
DSOmegaX's Avatar
Well keep in mind I also don't drive the brz often to places where I know the curbs and dips are larger .
Throwing on the 18s added weight due to both wheels and tires, but yeah it was offset by some other mods that were added later, namely getting it tuned on e85, the carbon driveshaft, and the reinforced rear axles.
@dsomegax.cars
Old 04-02-2016, 08:06 PM   #466
DSOmegaX
DSOmegaX's Avatar
Small change to the interior, courtesy as always from JPM Coachworks. Picked up this one-off gauge cluster hood:
@dsomegax.cars
Old 04-05-2016, 10:10 PM   #467
DSOmegaX
DSOmegaX's Avatar
Forgot to post this earlier, but here's a video Auto Tuned made when I was getting the Cusco sway bars installed.
[ame="https://www.youtube.com/watch?v=zi5FO_f2VUs"]Auto Tuned : Subaru BRZ tS Build - YouTube[/ame]
We'll likely be making a few more for my car in the near future as I will be having the following work done:
Spark plug service (oh joy)
STI engine mounts
STI tS rear subframe
STI rear subframe mounts
STI differential mounts
@dsomegax.cars
Old 04-05-2016, 11:57 PM   #468
Irace86
Drives: BRZ + Ducati M796
Saw it first here, but I am digging the design. They should make it standard.
http://www.ft86club.com/forums/showthread.php?t=96658
Irace86 is offline   Reply With Quote
Old 04-10-2016, 03:56 AM   #469
ed_423
ed_423's Avatar
hi there, more questions sorry :p
i know sti springs drop about 1/2". and i know you have different shocks to go with the sti springs. does that combo drop the car more? or is it still dropped 1/2". because for some reason your pictures show your wheel gap less than some other brz with the sti springs. other brz with sti springs still have a huge wheel gap, especially in the rear.
thanks man!
Old 04-10-2016, 12:08 PM   #470
DSOmegaX
DSOmegaX's Avatar
thanks man!
It shouldn't. The drop remains the same at 15mm (about 0.6"). The reason you're seeing less wheel gap is most likely due to having the 18" version of the STi wheels versus the 17" that comes on the series.blue.
@dsomegax.cars
Old 04-10-2016, 01:39 PM   #471
DSOmegaX
DSOmegaX's Avatar
Subframe and mounts are in. My cars working in harmony: Golf R used to transport parts for the BRZ
@dsomegax.cars
Old 04-10-2016, 01:48 PM   #472
Jordan Silveira
Jordan Silveira's Avatar
Drives: 2016 Subaru Series.HyperBlue #631
Hey Derek,
Novice question here but,
what exactly does the Subframe assembly do for the BRZ? What are the benefits and/or costs if any?
Thanks,
Jordan Silveira is offline   Reply With Quote
Old 04-10-2016, 08:28 PM   #473
DSOmegaX
DSOmegaX's Avatar
Originally Posted by Jordan Silveira View Post
Hey Derek,
Thanks,
Stiffens the overall rear assembly, decreasing potential movement in that area. It not only increases overall responsiveness, but decreases drivetrain loss from the engine to the rear wheels. The trade off is a less comfortable ride.
@dsomegax.cars
Old 04-14-2016, 07:57 AM   #474
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Hey Derek, quick question:
Did your tS suspension come with the STi stickers for the Showa shocks?
I ordered a set from jp but I seem to be missing them.
Thanks
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
Old 04-14-2016, 02:11 PM   #475
DSOmegaX
DSOmegaX's Avatar
Thanks
Yeah it should come with a full set in a separate, small bag (I think it was packaged with the instructions).
@dsomegax.cars
Old 04-22-2016, 06:58 PM   #476
DSOmegaX
DSOmegaX's Avatar
Joined that signed car club lol. Had the car signed by Chief Designer of the 86, Takayasu Furukawa. I'll make sure to get Tada-san's signature next time .
@dsomegax.cars
Completed build JK21 Member's Car Journals 46 12-11-2014 09:48 AM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 01:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-30-2013 11:10 PM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 10:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 09:18 AM
