Old 03-21-2016, 06:09 PM   #1
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Blown OEM shock paired with TRD springs
Hello all,
Took my 2014 BRZ (~12,500 miles) out for a drive, when I noticed a pool of oil beneath my passenger side rear suspension. I inspected the suspension further and saw that the leak is indeed coming from the passenger side shock.
Factory springs were replaced with TRD units about 6000 miles ago, by a friend who is a tech for a different manufacturer. I can't verify if he properly disassembled the shock assembly as shown in fig 2-2 in the installation guide (http://toyotaparts.sparkstoyota.com/...-18130inst.pdf). From my understanding, not doing so can cause the shock to fail as mine has.
Should I bother taking it to the Subaru dealer to get warranty work? I have a feeling they won't (and probably shouldn't) cover the work or the parts.
And even if this is replaced with an OEM replacement, I'm not sure if the tech did the same on all 4 corners. If that's the case, should I go ahead and replace all 4 shocks with something aftermaket and more performance oriented? I know AZP Installs is local, and their shop car is a BRZ so that's always an option. I don't have a use for fully adjustable coilovers, so I could go with something by Koni or Bilstein.
You opinions and guidance are appreciated.
nastynate88 is offline   Reply With Quote
Old 03-21-2016, 06:24 PM   #2
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
I don't think you'll have much luck with warranty in this situation though that could swing either way depending on your relationship with the dealer. They may eat it in the interest of goodwill but they would be well within their rights to decline a free replacement.
That being said I would take this as a good opportunity to upgrade the shocks.
Gear_One_Performance is offline   Reply With Quote
The Following 2 Users Say Thank You to Gear_One_Performance For This Useful Post:
finch1750 (03-21-2016), SlammedSilly (03-22-2016)
Old 03-21-2016, 07:17 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
^what he said. Sounds like a good time to get Bilsteins lol
Rear shock blown, need opinions with Swift springs JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-03-2015 01:37 PM
Blown Shock / Strut Club - Original,OEM units exE36M3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-29-2015 06:54 AM
Catless Front pipe paired to v1 exhaust BRZ_Kamil Engine, Exhaust, Transmission 0 12-08-2014 09:30 PM
Subaru keyfob paired to an FRS? post_break Scion FR-S / Toyota 86 GT86 General Forum 6 04-09-2014 03:57 PM
Two phones paired, one for speakerphone, one for audio bfrank1972 Electronics | Audio | NAV | Infotainment 2 11-04-2013 01:41 PM
