Old 03-13-2015, 10:41 AM   #1
exE36M3
Blown Shock / Strut Club - Original,OEM units
Gentlemen:
Had an interesting install yesterday. Went to Edge Motorworks in Dublin to install a set of Hotchkiss springs. Got a call from the shop... the driver-side/right-front strut was blown.
Odd.
Because the car was a 2013 model, bone stock, and had only 17,000 miles on it.
Symptoms of the things I've noticed in the last month...
1. Driving and cornering to the right... car twitches up front at speed
2. With strut housing removed (and dust boot removed) fluid coating everywhere
Good news is that I've got documented proof (photos and work order time stamp) before my springs went on that the strut was blown. But I am curious if you guys have had similar issues? It seems to be almost common on the Forrester forums and some WRXs.
Going in for warranty service next week...
exE36M3 is offline   Reply With Quote
Old 03-13-2015, 11:05 AM   #2
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
That's very odd. My 2013 has 19k and I have been lowered for the past 3k and everything is fine. Good luck with the warranty, which shouldn't be a problem.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 03-13-2015, 11:55 AM   #3
wparsons
wparsons's Avatar
Sounds like a fluke. My 2013 has 96k km's on it, has been lowered on Swift Sport springs for almost a year and zero signs of leaking.
flickr
Old 03-13-2015, 12:22 PM   #4
exE36M3
No kidding guys. I was as puzzled as everyone else. But then again, unless one takes apart their suspension, it's a hard one to spot because the dust boot hides everything.
I thought it was just my driving... but definitely the car being twitchy I thought was odd.
Old 03-13-2015, 04:23 PM   #5
wparsons
wparsons's Avatar
Mine are were definitely fine when I installed the springs, haven't looked closely since but no drivability issues either.
flickr
Old 03-13-2015, 05:02 PM   #6
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Both of my rear shocks are gone at 40k miles. I didn't even bother to look seriously at the fronts, as I am planning on aftermarket replacements anyway. I do a fair amount of short track driving/instructing, and 3 days on a long track. This probably overheated the stock shocks and caused the failure (well, that and -25°F temperatures frequently last winter).
The Following User Says Thank You to Black Tire For This Useful Post:
exE36M3 (03-13-2015)
Old 03-28-2015, 03:47 PM   #7
exE36M3
Thanks for everyones replies. Subaru of Livermore, CA pulled the strut, confirmed it was leaking and replaced under warranty.
As far as aftermarketing springs... if the drop is mild, it's the Service Advisors call on warranty work. But expect resistance.
Old 03-29-2015, 05:54 AM   #8
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
my rear shocks died at 10000 Km
Mars2 is offline   Reply With Quote
What can you learn from a shock dyno chart? Or shock dyno 101 Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 03-01-2016 07:40 AM
Shock dyno? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 10-30-2014 02:43 PM
Bilstein Shock B6-B8 Victor Draken Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-22-2014 10:46 AM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 11:00 AM
