Old 03-20-2016, 10:49 PM   #1
dave-
Drives: 86 GT
Upgraded Port Injectors
Installed ID850's but haven't changed the tune yet (car only just got put back together).
Starts first time but not once warmed which I assume is due to overfueling/cranking stuff.
What is the easiest/quickest way to temp fix that until I can get the car to the tuners (who isn't available right now)?
Basically just need to be able to start car and move it around the factory if needed without having to wait for it to be dead cold which is a pain in the arse.
dave- is offline   Reply With Quote
Old 03-21-2016, 12:29 AM   #2
steve99
Drives: FT86
port injector scaling is a parameter called Injector scaling BRZ in romraider
your going to need to adjust that to compensate for larger injectors
never done it maybe try @ztan
suppose if injectors were 30% more flow rate adjust parameter 30%
look at an oft e85 vs petrol tune that parameter is adjusted to make stock intectors inject 30% more fuel so you want to go oposite way
be carefull if you inject heaps of fuel it may cause damage
Old 03-21-2016, 06:41 AM   #3
dave-
Drives: 86 GT
Yeah was thinking the same with scaling though bit more than a 30% difference with 850's.
Other idea I had was 100% the PII ratio and take them out of the equation but don't think it works like that.
Old 03-21-2016, 07:02 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Port injectors are used for some fueling and will also be used if you exceed some of the max DI thresholds. To get the car to start up then you will need the port injector scalar and probably the injector minimum open time. Once fine tuned the latency will need to be done as well as changing any cranking values.
All this info should be available from the manufacturers.
.: Stealth 86 :.
Kodename 47 DJ:
dave- (03-21-2016)
Old 03-21-2016, 07:35 AM   #5
steve99
Drives: FT86
yeah im pretty sure car startup cranking is port only
Old 03-21-2016, 08:20 AM   #6
ztan
Drives: Toyota 86
Cranking is all PI.
Have a look at the ROM I sent you and compare to stock. Adjust Injector scaling BRZ - my ROM is DW450 450cc/min; I'm not sure which ROM def you are using but you can basically either halve or double (or 1.89x) my injector value depending on which way your ROM def is working to get you close enough to start dialling in. You'll have to find your latency value off the ID info.
You'll also need to reduce the cranking pulse width values by similar amounts. I think my car only uses cranking table B - but I've changed them all.
ztan is offline   Reply With Quote
The Following User Says Thank You to ztan For This Useful Post:
dave- (03-21-2016)
Old 03-21-2016, 06:00 PM   #7
dave-
Drives: 86 GT
Yeah your map confuses me sometimes with the custom def's and different scaling compared to BRZedit which I'm using at the moment.
Noticed ID have a spreadsheet for COBB subaru tuning (http://injectordynamics.com/injectors/id850/), need to have a look at that later and see if it helps as well.
Old 03-29-2016, 07:58 AM   #8
dave-
Drives: 86 GT
Got nowhere, I suck hehe! Bloody injectors.
Car is collecting dust until tuner is available, whenever that might be.
DIY Request- Port Injectors whitefrs DIY (Do-It-Yourself) Guides 37 08-23-2019 12:20 AM
Wtt upgraded fuel pump & injectors misooscar Brakes, Suspension, Chassis 0 04-09-2015 05:35 PM
WTB: Stock Port Injectors asphaltkyle Want-To-Buy Requests 0 03-23-2015 04:57 PM
FS: OEM Port Injectors Tactical_BRZ Engine, Exhaust, Bolt-Ons 2 01-05-2014 11:21 AM
