Old 03-17-2016, 07:39 PM   #127
invaliduser
Drives: 2017 86
Originally Posted by B-R-Z View Post
I think my header is cracked or something. I started getting like a clicky and more airy of a sound when accelerating, slightly worse gas mileage and when I pop the hood I can smell exhaust. I'm going to remove the skid plate this weekend and take a better look to confirm.
I contacted semotors.com and they said they only warranty for 1 year. I have a friend who welds who said he will attempt to fix it.
Have to reflash a stage 1 OFT rom too until this is resolved.
Has anyone else had issues?
Where is the crack
Sent from my Nexus 6P using Tapatalk
invaliduser is offline   Reply With Quote
Old 03-17-2016, 09:01 PM   #128
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by invaliduser View Post
Where is the crack
This
.... I'm going to remove the skid plate this weekend and take a better look to confirm..
B-R-Z is offline   Reply With Quote
Old 03-17-2016, 09:05 PM   #129
invaliduser
Drives: 2017 86
This
Your asking a friend who welds to fix a crack that you don't know exits.... That..
Old 03-17-2016, 09:10 PM   #130
B-R-Z
B-R-Z's Avatar
Uh..yes.. I don't get what you're trying to be a wise-ass about.
I have a good feeling it is cracked or has a hole in it or something. Based on this hunch, I asked a good friend if he would weld it if there are any cracks. Friend says yes. This is a daily driver so I'm trying to get this in order for a fast fix/recovery. Understand?
Old 03-17-2016, 09:22 PM   #131
invaliduser
Drives: 2017 86
Understand. Just don't see why you are posting in a review thread that you have a crack and a welder on standby before verifying that you have a crack. Sorry if I came cross as wise ass.
Old 03-17-2016, 09:41 PM   #132
B-R-Z
B-R-Z's Avatar
Well at the same time, I'm only saying I think I do and asking if anyone else has had an issue.
Old 03-19-2016, 12:48 PM   #133
B-R-Z
B-R-Z's Avatar
Took a look today and no cracks or holes and nothing looks wrong at all. The only part I cant check with 100% certainty is under the mesh for the flex pipe section.
Old 03-19-2016, 12:53 PM   #134
invaliduser
Drives: 2017 86
Can u record the noise you are hearing?
Old 03-19-2016, 01:20 PM   #135
B-R-Z
B-R-Z's Avatar
I'll record a sound clip when I leave today.
I'll try to describe it the best that I can. When I first installed the header, I got the typical sound most people report which is the sound of air rushing through the header pipes, which is normal. 2 weeks ago or so, I also started getting this minor/light clicking/tapping sound only when accelerating. I also have a slight reduction in fuel economy. I always reset my mpg average when I fill up and my normal is 30-31 but lately it's been 28-29...not a big difference, but it's a difference. When I sit somewhere idling, I can smell the exhaust which I never recall smelling before.
I did notice that the gasket for the header/overpipe was flaking away a little bit on the outside edges, I'm not sure if this is enough to cause leakage but I did notice it.
Old 03-19-2016, 01:29 PM   #136
invaliduser
Drives: 2017 86
U have access to a gopro u can attach down there?
Old 03-19-2016, 01:38 PM   #137
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
i had issues before between my header and overpipe connection. i used a thicker gasket and no more issues. with the car running, you can feel any air from the inside of the engine bay around the flange if leaking.
malubawla is offline   Reply With Quote
Old 03-19-2016, 01:50 PM   #138
invaliduser
Drives: 2017 86
If that's the case, get this. I had a similar leak and this fixed.
Remflex 6005 Exhaust Collector Gasket for Mopar, (Set of 2) https://www.amazon.com/dp/B00B2HMF7G..._Cdz7wbFJDFR2Q
Old 03-19-2016, 02:42 PM   #139
B-R-Z
B-R-Z's Avatar
Went out for coffee and as I go to leave and pull out of the parking lot I got a CEL and my traction control light came on.
The CEL codes are:
P0171 System too lean (Bank1)
P1170 Port Injector Fuel Performance Does not come on DTC
Old 03-19-2016, 02:50 PM   #140
invaliduser
Drives: 2017 86
The CEL codes are:
U have a tune?
Tsudo Header and Overpipe boredom.is.me Engine, Exhaust, Transmission 70 11-04-2014 01:14 AM
For sale: Tsudo UEL header jupillam Engine, Exhaust, Bolt-Ons 10 07-08-2014 12:40 PM
Anyone have the Tsudo header? Iam-Naimless Engine, Exhaust, Transmission 8 07-02-2014 01:55 PM
New Tsudo UEL header Fast_Freddy Engine, Exhaust, Transmission 1 05-11-2014 01:33 AM
Tsudo Header ML Engine, Exhaust, Transmission 7 01-11-2014 01:31 PM
