Old 03-15-2016, 02:25 PM   #15
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sorry, I'd do oil cooler long before radiator
The Following User Says Thank You to continuecrushing For This Useful Post:
go_a_way1 (03-15-2016)
Old 03-15-2016, 02:49 PM   #16
CSG Mike
CSG Mike's Avatar
Originally Posted by Trust86 View Post
I understand that, but viewing the situation as a DD. With 5w-30 I see no problems. I know the oil temp will spike sitting in 3rd gear, but the faster you go, eventually you will shift into the next gear, the rpms drop and more air is moving across the radiator which is cooling the coolant even more at faster speeds, which is cooling the block, and also helping the oil temps. No where near as much as an oil cooler would obviously. also having a radiator twice as thick helps bc more fluid that gets cooled before returning back to the block.
I don't think you're quite understanding what I'm getting at.
I'm not saying accelerate in 3rd gear on the highway; I'm saying to just sit in 3rd gear cruising. The reason for this, is that it approximately simulates the sustained high RPM you see while canyoning.
Your coolant temp has minimal correlation to your oil temperatures; you do not have a coolant/oil heat exchanger. The minimal relationship comes from your oil's heat being conducted into the engine, which is then conducting heat into your coolant, which then gets pumped into a radiator, which conducts the heat into the air. The heat is being exchanged 3 times, whereas an oil-water cooler exchanges it twice, and an oil-air cooler exchanges it once.
In other words, without an oil-water cooler, your coolant temp has zero correlation with your oil temps.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
continuecrushing (03-15-2016), DarkSunrise (03-18-2016), go_a_way1 (03-15-2016), Ultramaroon (03-16-2016)
Old 03-15-2016, 02:59 PM   #17
continuecrushing
From what I understand, and please correct me if I'm wrong @CSG Mike, but
high engine load=increased coolant temps
high engine rpm=increased oil temps
That, and anyone "beating/driving aggressively" on their car who does NOT have an oil cooler and does NOT have high oil temps is not "beating/driving aggressively" on their car...
The Following 3 Users Say Thank You to continuecrushing For This Useful Post:
CSG Mike (03-15-2016), Muaddib (03-23-2016), TRAKRAVN (03-18-2016)
Old 03-15-2016, 07:06 PM   #18
ryoma
ryoma's Avatar
after I installed the oil cooler, I felt that my throttle pedal was more responsive... maybe it's just in my head lol.
Old 03-16-2016, 12:27 AM   #19
It costs money to monitor oil temp. The engineers didn't just do it for funzies. Based on that alone, I'm willing to bet you aren't imagining it.
ajc209 (03-17-2016), CSG Mike (03-16-2016)
Old 03-17-2016, 01:24 PM   #20
Tainen
Drives: First SWP BRZ-L
I am guessing you are not running a thermostatic device on your oil cooler?
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 03-17-2016, 01:37 PM   #21
ajc209
Drives: GT86 Cosworth
The ECU monitors Oil temp because at 140C (284F) it cuts power a little to stop it going any higher. I've had it that hot a few times on moderately warm track days in less than 20 minutes. I'm by no means an amazing driver.
Coolant temps on the other had sat firmly between 90-95C (194-203F).
Even with 250WHP and an oil to water laminova oil cooler, using the low temp thermostat, coolant is pinned to about 83C (181F). I'd say the coolant system is pretty decent on the FA20.
ajc209 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
CSG Mike (03-18-2016), Ultramaroon (03-17-2016)
Old 03-17-2016, 03:50 PM   #22
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
You don't need a radiator, you need an oil cooler. Look at my coolant temps and look at my oil temps (with an oil cooler) from a 30 minute track session.
http://datazap.me/u/docwalt/10-25-15...data=1-6-11-12
I don't have logs handy, but I'd see similar sort of oil temps just cruising down the highway, which is nowhere near the same sort of abuse.
The Following User Says Thank You to DocWalt For This Useful Post:
Old 03-18-2016, 06:11 AM   #23
ajc209
Yeap before oil cooler, mine would sit at around 212F and it wouldnt take much to get it up to 250F.
The Following User Says Thank You to ajc209 For This Useful Post:
Old 03-18-2016, 07:44 AM   #24
DarkSunrise
DarkSunrise's Avatar
As suggested above, you may want to fashion some sort of block off plate for your oil cooler on the street.
I've got a Perrin oil cooler and use my front license plate to block off some airflow. On the street my oil temps are ~175 F cruising hwy with ambient temps around 65-70 F. On the track, I pull off the front license plate and peak oil temps are ~245 F with ambient temps around 90 F.
2022 BRZ Build
2013 FR-S Build
Old 03-19-2016, 04:09 AM   #25
ajc209
I had an oil to air setrab 619 radiator and a 212F thermlstatic plate. In the coldish winter here the parasitic flow was enough to over cool the oil on the highway. I had it mounted behind the fog lights like the full blown setup and I fabricated some ducting. I just couldnt be bothered blocking it off so I swapped over to a mocal oil to water laminova and it seems to work pretty well. I do have a low temp thermostat mind so that will help but oil temps, to my surprise, were as almost good as the 619 setrab on track.
Old 03-19-2016, 12:52 PM   #26
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Which one did you go with?
I couldn't be bothered to do a block off plate for my oil cooler either and it definitely over-cools my oil in the winter, though I only have the 180F thermostat in mine. It was only really cold here and there so I wasn't too worried, just took it really easy as if I was just warming the car up.
ajc209 (03-19-2016)
Old 03-19-2016, 01:32 PM   #27
ajc209
The medium size one. Spliced it into the water hose on the right side.
There's some details on the Cosworth owners thread.
DocWalt (03-19-2016)
Old 03-19-2016, 08:33 PM   #28
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
212* NOT is an interweb myth. Read a peer reviewed academic engineering paper, not reddit.
You can find my DIY on oil coolers. I have absolutely zero issues with oil temps even in the 14* days we had this past winter in DC.
The problems people have come feom running no thermostat, or running a less than acceptable oil sandwich plate with a shoddy thermostat.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
alphasaur (06-30-2020)
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 03:08 PM
Oil temps with JR SC and JR oil cooler dp1 Tracking / Autocross / HPDE / Drifting 87 11-14-2014 12:35 AM
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 12:30 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
