Old 03-15-2016, 09:58 PM   #995
phrosty
Originally Posted by oldgunfan View Post
Well I have been playing with my MAF scale I think i'm close but around 2500 to 4000 it's going from rich to lean. I'm thinking I need to play with my load limits. I'm using Wayno's load limits. Any ideas?? my pull http://www.datazap.me/u/oldgunfan/ge...ata=1-3-4-9-14
He has like 10 load limits, which are you using? Looks like the 3800rpm limit should be raised.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
oldgunfan (03-18-2016)
Old 03-16-2016, 12:17 AM   #996
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You should have 1.1 @3800 in LL and probably around 68/69 @ 3.2V in MAF scale, depending on which one you're using. On your car it looks like MAF scale should be smooth but instead looks like you have a dip @ 3.2V.
Did you try just Shiv's scale with LL of 1.1 @ 3800?
It looks like you're using US.Lean and you need to change 3.2V to 68 to smooth it out.
The Following User Says Thank You to Wayno For This Useful Post:
Old 03-17-2016, 10:38 PM   #997
Rezi
Drives: GT86
Hey guys,
could someone please explain me how to reduce/eliminate knock?
I got some FBKC up to -1.41 on Wayno's stage1 98 v98 tune between 3200-3700@0.5-0.6 load. (Fuel is BP Ultimate Super, it is fine, when not the best available here, no e85 fuelstation available)
So i decided to pull some timing out of Base Timing B like in the Knock Correction thread vom steve99.
Like below:
Now i got some FBKC spikes up to -2.09! and a couple of -1.41 again.
Did i something wrong? Does the Base Ignition Timing need to be a "lower" or "higher" value? IAM is still at 1 all the time, but -2.09 is pretty huge..
You can see the FBKC below:
http://datazap.me/u/rezi/170320161?l...zoom=1465-1695
http://datazap.me/u/rezi/170320165?l...zoom=2995-3941
http://datazap.me/u/rezi/170320163?l...4&zoom=90-1007
I really dont know what the heck is going on. Gonna "beat" the crap out of it. If it still persists i'm going to flash back
Rezi is offline   Reply With Quote
Old 03-17-2016, 11:13 PM   #998
steve99
Drives: FT86
make sure your on @Wayno s latest version of tune , you might have to make it run a bit richer in that area and see if that helps you may need to change the ol and cl fuel maps
Old 03-17-2016, 11:24 PM   #999
Wayno
Wayno's Avatar
If it doesn't drop IAM, then don't worry about it. You won't feel it at low load. If you really, really want to smooth out that area you can do this change attached. It's important not to pull timing from the adjacent high load columns where no knock is happening. If you do that you're just detuning your car for no reason. Better to pull from the adjacent low load column where the timing ramps right up. You shouldn't pull timing based solely on the base timing table. You should be looking at base timing + kca combined. If you did you'd see there's a mountain of adv in those cells @ 0.5.
Originally Posted by Rezi View Post
Hey guys,
Like below:
Rezi (03-17-2016)
Old 03-17-2016, 11:32 PM   #1000
Rezi
Drives: GT86
Thanks Wayno for you help!!
Only the changes in picture 1 on my current rom?
Or do i use the last one where you changed the complete timing of the map?
Old 03-18-2016, 12:11 AM   #1001
Rezi
Drives: GT86
@Wayno Are these changes correct?
I will try it today. If not, i am flashing back to your "stock" v98 tune.
Old 03-18-2016, 12:37 AM   #1002
Wayno
Wayno's Avatar
Just do the diff.
The other 2 are total timing - 6.
And if it still knocks there without dropping IAM, forget about it.
Old 03-18-2016, 08:26 PM   #1003
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Yes my load limit is 1.10 at 3800 and my MAF scale at 3.2v is 66.5. I never did try shiv's load limit. I'll give it a try and maybe 67 or 68 at 3.2v. Thanks for the reply.
oldgunfan is offline   Reply With Quote
Old 03-18-2016, 08:57 PM   #1004
Wayno
Wayno's Avatar
No, Shiv's SCALE i.e. OTS Stg2 maf scale.
There are no load limits OTS tunes worth copying.
And copy LL from here.
http://www.ft86club.com/forums/attac...6&d=1458280187
Old 03-18-2016, 10:21 PM   #1005
Rezi
Drives: GT86
@Wayno @steve99 , thank you so much!!
The logs are looking really good!
* one FLKC of -1.3 between 6000-6500rpm when doing 3rd gear wot pull from 2000-7000
*one FBKC of -1.41 when AC was on @3500-3600
The rest is looking really good. Absolute zero FLKC and very little -0.69FBKC.
IAM was always at 1. LTFT are looking much much better. It is between +0.78% / -1.57% the most of the time. Idle @ -5.47% which is normal. And this is without MAF-scaling.
Fuel used was 90% BP Ultimate 98. (got some litre of OMV MaxxMotion 100 in it, but i think it is better to log with the "lowest" fuel)
WOT FLKC: http://datazap.me/u/rezi/190320164?log=0&data=1-10-11
FBKC w/ AC?: http://datazap.me/u/rezi/190320165?l...zoom=6477-6622
Rest: http://datazap.me/u/rezi/190320161?log=0&data=1-4-10-11
http://datazap.me/u/rezi/190320162?log=0&data=1-4-10-11
http://datazap.me/u/rezi/190320163?log=0&data=1-4-10-11
Old 03-18-2016, 10:40 PM   #1006
oldgunfan
oldgunfan's Avatar
Ohhh MAF scale, Yes it was wayyy too rich. I'm close to your us lean. I like the looks of the new load limits i'll try that thank you very much.
Old 03-18-2016, 11:35 PM   #1007
Wayno
Wayno's Avatar
The new US.Lean has 68 @ 3.2V
Old 03-18-2016, 11:38 PM   #1008
Wayno
Wayno's Avatar
You have to wait for LTFT above 5k to go +ve, which will make it richer and alleviate the timing pulled.
Rezi (03-18-2016)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
