#15 | |
I'm going to see if I can find any other engine videos to see if I can see that pulley moving.
#16 |
Drives: '97 RSP JZZ30 GT-T
Seemed like DI noise to me
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
#17 |
After my commute to work today mine was making the chirping noise again.
Here is a quick video of it. [ame="http://www.youtube.com/watch?v=bmooGfYQxms"]Scion frs idle noise - YouTube[/ame] |
#18 |
Drives: scion tc
#19 |
Re-member
Drives: Toyota camry
In both vids there is a lot of injector noise and I think some of the higher frequencies sound injector related but I also hear another high frequency that sounds off. I'm using ear bud headphones. I hear a high frequency noise that is at a faster tempo than the injectors, it also sounds slightly intermittent (it doesn't maintain exactly the same tempo, which injectors will).
Nothing decays like progress, and nothing preserves like neglect.
#20 |
Well I just ran it for 15mins or so, and I didn't hear any chirping, but I noticed that if I let it idle for an extended period of time (say, 15secs+), when I give it gas the rpms will drop to 400-500 then go up. Seems to be an issue with the FR-S.
#21 |
Drives: Scion FR-S
Mine makes that sound too, not all the time though. I too thought it was normal but I'm starting to think I should take it to the dealer too, to get it checked out.
#22 |
Mine hasn't made it since the one time last night. A comment on the OP's video said he took it (FR-S) to a Toyota dealer and they said it was fine.
#23 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
louder exhaust will solve this problem
| The Following 3 Users Say Thank You to uspspro For This Useful Post: |
#24 |
Drives: Subaru BRZ Limited WRB Manual
Agreed.
That being said, my car makes the same noise occasionally after being driven for a while. It is more frequent than the injectors (slight pulsing, sometimes just a constant high-pitched sound) and sounds very different than the clicking. I've owned two wrx's before, and while I will be the first to say that boxer engines are naturally noisy, this noise doesn't sound familiar. However, I haven't noticed any performance or idling issues. Last edited by enjoyminutemaid; 06-29-2012 at 09:07 AM. |
#25 |
Here's a vid of mine doing it as well. It seems to be intermediate, since some times it'll do it, and other times it won't. Happened as I was getting back to work after going to the bank and getting lunch.
[ame="http://www.youtube.com/watch?v=UK_4uZz-oQo"]BRZ Chirping - YouTube[/ame] You can also see the idler pulley moving back and forth in the vid too.
#26 | |
Drives: '88 BMW 535is Turbo
The other thing that makes youtube sound diagnostics a bit tough is that most smart phones have extremely sensitive microphones for high frequency noises. So for one of us to compare what we hear on a car in person to your video is a tough comparison as well. Jason Griffith Engineering Director Nameless Performance |
#27 |
You can hear the chirping sound in all the videos. It sounds like a cricket. It's higher pitched then the ticking from the injectors.
| The Following User Says Thank You to Jayde For This Useful Post: | theneptune86 (03-04-2022) |
#28 |
Turn the A/C on and see if it stops? So hard to tell where its coming from but that higher pitched sound doesn't sound like belt squeal to me at all. Sounds like bearing noise.
| Hard shifting into first gear; normal? | blalor | Engine, Exhaust, Transmission | 54 | 08-31-2017 09:57 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 10:42 AM |
| What function can it be used for, the idle button place | yuli8466 | Cosmetic Modification (Interior/Exterior/Lighting) | 50 | 01-29-2013 03:17 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 12:00 PM |
| Scion goes normal | terrypm | Other Vehicles & General Automotive Discussions | 21 | 05-02-2012 10:16 AM |
