| Engine Swaps Discussion of engine swaps. |
#15 |
Y u do dis?
that's an LT, not an LS
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#16 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Automatic Transmissions were invented in 1904, and the first Torque Converter Auto was in 1948. Manual Transmissions may have come in the late 19th century, but the first cone synchro manual transmission was in 1952 by Porsche. So I guess OP is wrong on that count too. But hey, if you like living that PRNDL life, then live it!
- The Ancient BRZ Sacrament by Zaku |
#17 |
Drives: 86
For the cost of the swap and the donor car, you can buy a brand new Cayman with PDK.
/thread |
#18 |
Drives: 2013 Pearl White 6MT
Manual makes you noxious?
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#19 |
Drives: 2015 Raven V8
#20 |
If you're going to swap it with something crazy like this... you should just go LSX/4L60E. Electronically controlled trans, but might a bit rough getting it in due to it's size.
LSX w/ 4L60E would feel amazing and provide good cruising MPG. |
#21 |
Boosted
Drives: Not a supra....yet
Why not a 4l80 ?
#22 |
Drives: 85 corolla gts
I have a feeling to get an 80 in you may need to rebuild the tunnel, but I feel it would be worth it over the 60. You can build the 60 to deal with the power but you will have to refresh it more often.
#23 |
Wayward Member
Drives: Hot Lava 86
This topic is of interest to me, provided it doesn't veer too far off course or go down in flames (I'm not holding my breath to see which one happens first). I'm not considering swapping the FR-S, but down the line I'll need a good auto to go in something else that will get a shiny, new engine. I'd prefer an auto that operates just like the FR-S flappy paddle, but all the research I've done thus far makes it look like nothing operates quite the same way.
Good luck! Your success benefits me. Sorry I can't actually answer the question.
#24 |
No real reason not to. 4L80's only a few hundred more when buying a new trans.
Just know it's a bit bigger then the 4L60E and also about 100lbs edit: heavier, accidentally wrote lighter. (may not be on the dot, I didn't look up the exact weights) Last edited by Sonic Motor; 03-21-2016 at 04:45 PM. |
#25 |
Junior
Drives: a car
dog box. do it.
#26 |
Boosted
Only issue I had with a previous 4l60 was maintaince even when fully rebuilt, never the less It works well
#27 | |
Drives: 2013 Brz C38 (bought not built :P)
If you aren't mechanically inclined, even with a kit you'll have to enlist professional installation which will be another several thousands. And why oh why would you want a v6 in there, if you want a 6 cyl at least drop an inline in there. |
#28 | |
If the people starting these threads had actually done some research and at least knew a bit about what they were planning to swap for, what their goals are, their budget, etc. As it stands they mostly are in the same category as I'm gonna put a CAI in my civic and gain 50hp crowd. I mean before buying my brz I was considering a swap for my lexus is300, I had it down to 2 engines, had established most of the supporting/fabrication parts (was a 2 page list of parts with prices and where to buy them as well as some quotes from shops around my area for the work I couldn't do myself, was around 10k Canadian for parts and most of the labor if I shopped my parts around and wasn't pressed in time for my part fab) needed to complete the work as well as an estimate on labor costs and tons of info on the swap process. If these guys had half of the info I mentioned above then these threads wouldn't turn into giant flame sessions |
| Tags |
| automatic, fr-s, ls1, lt1-ls1bigdifference, nocluebutspoonfeedme, swap |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
| Is there anyway I can swap out my automatic transmission to a manual | Kushbrz13 | Engine, Exhaust, Transmission | 23 | 01-02-2016 06:10 PM |
| Using handbrake with automatic gt86 and other issues with the automatic version | Tommygt86 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 04-06-2015 04:42 AM |
| Do you think FT-86 will have automatic? | TRD | Engine, Exhaust, Transmission | 217 | 08-03-2013 09:36 AM |
