#547 | |
Drives: WRB JR BRZED
#548 | |
PhoneFlash by EcuTeK
Sincerely, Zach Delicious Tuning |
#549 | |
Drives: N/a
Sent from my SM-N910T using Tapatalk |
#550 | |
#551 | ||
Drives: 2015 Scion FR-S RS 1.0
Great news on the overboost protection. The Double D, is this only going to be used for SuperCharger applications, or will it also apply to the Turbo applications as well? |
#552 |
#553 |
Drives: '15 FRS
After some consideration, I've decided to go in the get the flex fuel kit with the e85 flash and go tune today. Mike installed the fuel pump and injectors next door and then Zack flashed the tune soon after. I will comment back here with any updates but as for now I am very happy with how it turned out. My frs runs so much more noticeably smoother now than before (not to mention faster haha). Now gotta save up for a new set of wheels and tires!
| The Following 2 Users Say Thank You to whatevervu For This Useful Post: | Infamous Performance (03-25-2016) |
#554 |
Drives: 86
Hi guys. Im about to FI my 86 in the next couple of weeks with a custom low mount setup. Im using a Garrett GT2871R with .86ar. My goals are around 280-300whp on a stock engine.
Im able to run 102ROZ fuel. Will the flash&go tune need adjustments for the fuel? How much boost I have to do to reach the 280whp mark? Cheers from germany. |
#555 | |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | denso (03-30-2016) |
#556 |
Drives: 86
Thank you for your answer @Zach. Im on wg pressure (0.5bar) w/o any boost control (yet). Im getting ECUtek soon. Wich boostcontroller do I have to get to be able to do boost control via ECUtek RaceROM? Are you able to implement the bc into the software?
Cheers from germany |
#557 | |
Drives: Limited Silver
-Avo @ 10.5psi- |
| The Following 2 Users Say Thank You to Flashfire88 For This Useful Post: | denso (03-30-2016) |
#558 | |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | denso (03-30-2016), Infamous Performance (03-30-2016) |
#559 |
Drives: 86
Ah okay so I need a complete EBC. My thoughts are to implement the boost solenoid only into the stock ECU and use it with ECUtek. Is this possible in any ways? Wiring or other things arent a problem, im a technican at Lexus.
@Zach, you said that we can get over 300whp without pushing any limits with "my" fuel... I've read that the stock conrods will die at around 280whp. A friend of mine is pushing ~400whp on a stock FA20 w/o any failures @E85. How could this be possible? I know that the rods are weak at this power level and that they dont like any kind of knock. IF its possible to get around 300+whp w/o punishing the stock long block Im your man. But just if its really safe to do this. Im completely stock (engine, injectors, clutch,...). w/ oil cooler @ Motul 300V 5W-40. edit: I got a lot of track/race usage... cheers from germany Last edited by denso; 03-30-2016 at 04:54 PM. |
#560 |
Drives: UK GT86
@denso it's not power that kills the rods but torque, or more specifically cylinder pressure. That's why knock is bad but also if kept in check, especially at lower RPM, then you can be fine.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | denso (03-31-2016) |
| P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! | P&L Motorsports | Forced Induction | 9 | 03-26-2017 02:27 PM |
| Most *fun* forced induction | bfrank1972 | Forced Induction | 45 | 12-22-2016 12:36 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 01:38 PM |
| February Sale. All Delicious Tuning e-tunes are 10% off!!! | Infamous Performance | Announcements, Contests, Giveaways | 19 | 02-28-2014 01:37 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 12:36 PM |
