Old 03-17-2016, 12:51 PM   #239
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Be way better off with existing aftermarket I am sure.
I mean, if you take existing aftermarket parts and bolt them on to the new car with 205hp/156tq, will it make that much more, or about the same +5. Here's an example.
Let's say my '13 is 160whp stock and I manage a good build that gets me 200whp (hypothetical).
Will a similarly modded '17 start at 165whp and go to 205whp, or will whatever they've changed make it even better? Conversely, could it actually make it worse? Lets say they managed the 5 hp/tq bump by changing the tune and making it more efficient, leaving you less wiggle room. Now your 200whp build is only good for 190whp.
I might be over thinking the tuning here, but I actually think this might be something to consider.
Nevermore is offline   Reply With Quote
The Following User Says Thank You to Nevermore For This Useful Post:
MisterSheep (03-17-2016)
Old 03-17-2016, 12:52 PM   #240
Originally Posted by KungFuWaffle View Post
Curious if the BRZ will get a refresh too? Or if the brz will remain the same?
Probably. Many seem to think this refresh was due to the rebadge. That is not probable at all and would have been planned a while ago and would have happened even if still Scion.
Would think the BRZ one would be planned as well. Subaru has historically introduced their updates to the BRZ well after the FRS though so could still be a while until they release info.
Dadhawk (03-17-2016)
Old 03-17-2016, 12:53 PM   #241
wbradley
Sarcastic SOB
wbradley's Avatar
This thread is way too long.
Buy new, this is what you will get. Buy used, get the current model. Both good choices.
The Following 3 Users Say Thank You to wbradley For This Useful Post:
Hoahao (03-17-2016), MisterSheep (03-17-2016), stevesnj (03-17-2016)
Old 03-17-2016, 12:53 PM   #242
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I guess we wont know about this until they release it and tuners can get their hands on the engine.
Also I believe I've read somewhere that they changed the intake manifold and the valves for it to become more fuel efficient and raised the power by 5.
I wonder how much it increased in torque?
Instagram: trevor.parque
Nevermore (03-17-2016)
Old 03-17-2016, 12:54 PM   #243
Celica00
Celica00's Avatar
Drives: 86
I'm guessing by "powertrain upgrade" all they did was do a more aggressive tune. So literally no difference if you've already tuned your car. But more updates will comes us I have zero actual facts. I'd love if it was a slight engine internals upgrade somewhere
Celica00 is offline   Reply With Quote
The Following 2 Users Say Thank You to Celica00 For This Useful Post:
MisterSheep (03-17-2016), Nevermore (03-17-2016)
Old 03-17-2016, 12:54 PM   #244
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Depends what they changed. Likely they just closed the gap to the engines potential, which means no changes. Either in a tune or in a "bolt-on" part modification.
However, if they changed something on the internals, then there may be more potential.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
The Following 4 Users Say Thank You to Freude am Fahren For This Useful Post:
akyp (03-17-2016), MisterSheep (03-17-2016), Nevermore (03-17-2016), Tcoat (03-17-2016)
Old 03-17-2016, 12:55 PM   #245
All depends on how they got the extra 5 stock. If valves or something internal then sure you could add. If a header or intake or something then you would probably change for more anyway.
Edit: Took to long typing. What Freude said.
Old 03-17-2016, 01:00 PM   #246
Celica00
Celica00's Avatar
Drives: 86
I'm curious what the BRZ elitists' arguments will be now, considering it's now officially the weaker car.
I also am sad that as new things happen, facelifts, engine bay modifications, etc, the BRZ and FRS will grow farther apart. Hopefully it doesn't get so bad that people can only make aftermarket for BRZ or FRS.
The Following User Says Thank You to Celica00 For This Useful Post:
Old 03-17-2016, 01:00 PM   #247
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Any additional information the gear ratios? Because that's where you'll probably notice the acceleration difference.
jaorocks1 is offline   Reply With Quote
The Following User Says Thank You to jaorocks1 For This Useful Post:
Old 03-17-2016, 01:00 PM   #248
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
What I think alot of us are forgetting is that, the new one MAY fix some of the problems of the old one.
So instead of having a hoard of Crickets you'll now that a swarm of something else possibly.
all in jest, but really Im sure they did some fixes.
The Following User Says Thank You to Zaku For This Useful Post:
Old 03-17-2016, 01:01 PM   #249
HunterGreene
Hail Magnet
HunterGreene's Avatar
I think they said something like 156 torques.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Old 03-17-2016, 01:01 PM   #250
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
....what? I'm almost positive any change they made to the engine and transmission will be the same as the BRZ.
The Following User Says Thank You to Summerwolf For This Useful Post:
Tcoat (03-17-2016)
Old 03-17-2016, 01:02 PM   #251
MisterSheep
Killed Scion
This. The whole points of these cars is that they are twins and most (98%) of parts are interchangeable. I do believe that one day that Subaru or Toyota will end up splitting from the other leading to more drastic changes or the cancelation of the car altogether.
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
Celica00 (03-17-2016), Summerwolf (03-17-2016)
Old 03-17-2016, 01:02 PM   #252
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I guess I'm just offering a different spin on the car buying mentality. It might seem odd to look at which car you want based on what you have to change to get the right power, but lets assume anyone buying the car is going to mod it regardless. If you outright want a new car and don't care, buy the '17. But if you plan on modding the car for power, maybe wait and see which one responds better to tuning. If I was all about the numbers, I'd want to start with whichever car makes them easiest, wouldn't you?
People might go, "Oh, 5 extra hp/tq doesn't mean anything. They failed again." But what if that leads to an extra 20whp just because they changed the right stuff?
I dunno though. This seems like a unique way to look at it to me. I do that sometimes and people just shake their heads at me.
buttons everywhere, damn daniel, i hate it, i love it, much opinion, mustache ride, rosted zaku by soa, so change, very tryhard
2017 = more power alan.chalkley Engine, Exhaust, Transmission 62 07-08-2016 07:24 AM
2017 Toyota 86: The car so nice it's been rebadged twice dazob Scion FR-S / Toyota 86 GT86 General Forum 10 02-04-2016 05:12 PM
Styling cues Suberman BRZ First-Gen (2012+) — General Topics 22 11-04-2013 10:45 PM
