Old 03-14-2016, 01:33 PM   #15
qqzj
Drives: MDX, Camry
Originally Posted by mixtape View Post
I use the Mobil 1 Extended Performance filter. I put Mobil 1 EP oil in my car after the break-in period ended in January. It just made sense to combine the two.
How long do you keep the filter and oil? Even 12k seems a little scary. So I am thinking about put the OEM filter and extended performance oil on and change them after 10k miles. Question is whether the filter is good enough. The oil should be okay. (I have three new OEM filters lying around. No extended performance M1 filter.)
qqzj is offline   Reply With Quote
Old 03-14-2016, 01:39 PM   #16
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
I do not remember the exact number, but the oil I used, Amsoil Signature Series 5w30, is rated for some astronomical mileage (20,000 or so). I changed it after my break-in period at 1,100 and will change it again close to 12,000. I will change my filter at 6,000 just for peace of mind - but I imagine that the Mobil 1 ET filter could easily make it all the way to 12,000.
In your situation, I feel like changing the oil every 10,000 and the filter every 5,000 would be good. That is what I would do in your place, for what it's worth.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 03-14-2016, 05:06 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I am going to use the Mobil 1 Extended Performance 0w-20 oil (those in the golden jugs). It says on the jugs that it is good for 15k miles. But I am not sure whether it is too risky to stretch oci to 15k. Maybe 12k?
But even with 12k, if I use this oil and oem filter, should i replace the filter once? Or, I should get the matching m1 extended performance filter from the get-go? Thanks for your ideas.
If you have no idea what interval is good for your engine, stick with 7500 miles.
The only way you can truly change your OCI is to run used oil analysis and adjust intervals based on your driving needs and oil consumption.
-alex
Old 03-14-2016, 08:00 PM   #18
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Why ever use anything besides 15208AA130?
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Laika (03-15-2016), roddy (03-14-2016)
Old 03-14-2016, 09:06 PM   #19
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Name brand swagger.
Just so you say I have a $60+ JDM oil filter you over night from Japan.
Also so you can stand out among the peasants that have the same exact car. That use a $6-8 OEM filter.
Old 03-17-2016, 12:21 AM   #20
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Because a red, purple, or different color filter is cooler than a bland black subaru filter, duh :p
MS, CSCS, TSAC-F, CPT
Where to buy K&N performance air filter? 147kW AFRICA 22 09-13-2015 12:44 PM
Performance air filter? trexx0411 Arizona 0 08-03-2015 07:58 PM
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Clogged Engine Intake Filter kndonlee Issues | Warranty | Recalls / TSB 18 09-09-2012 10:47 PM
