Old 02-02-2016, 10:52 AM   #71
PeterFRS
PeterFRS's Avatar
Drives: FRS
Originally Posted by Mr.Impreza View Post
Wow looks perfect...I will be doing spacers also for the stock rims, just will need to figure out width
kind of kicking myself that i didn't go with 25mm all around.
but by all means 20mm i was happy as well.
just that 25mm would hide the stock studs to be used with not so spacer friendly aftermarket wheels.
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
The Following User Says Thank You to PeterFRS For This Useful Post:
Mr.Impreza (02-02-2016)
Old 02-02-2016, 04:50 PM   #72
MrDinkleman
Drives: 2016 Oceanic, "base" model
This is an interesting thread even though I would never use spacers. I am (still) looking for wheels and the wheel I want comes in16X7, 35mm offset. I had been wondering if pushing the wheel out 1/2 inch (13mm) would create any problems with rubbing on the fender. It appears there is no problem with rubbing.
In fact, now this thread has me thinking of staggering the offset, 35mm front and 25mm rear...
MrDinkleman is offline   Reply With Quote
Old 02-03-2016, 03:46 PM   #73
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Spacers don't make your car feel heavy like with 17x9 wheels correct?
Like if i go 20mm, the driving characteristics would remain the same apart from better grip?
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 02-04-2016, 12:04 AM   #74
stevemp5
Drives: scion fr-s
15mm front and 25mm rear
stevemp5 is offline   Reply With Quote
The Following 3 Users Say Thank You to stevemp5 For This Useful Post:
Astroboy (03-16-2016), Juvenile (02-04-2016), Mr.Impreza (02-08-2016)
Old 03-16-2016, 09:09 PM   #75
Teseo
Drives: frs
Safe if i go with
[ame]http://www.amazon.com/gp/aw/d/B00ED4XR6I/ref=pd_aw_sim_sbs_293_1/189-1138321-9369204?ie=UTF8&dpID=41fCg0jMENL&dpSrc=sims&preST= _AC_UL100_SR100%2C100_&refRID=1QC3S8QPY3RMAH8SWY4J[/ame]
Need something else?
Old 03-16-2016, 09:58 PM   #76
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
Originally Posted by Teseo View Post
Safe if i go with
http://www.amazon.com/gp/aw/d/B00ED4...QPY3RMAH8SWY4J
The link isn't working... for me at least
Husker BRZ is offline   Reply With Quote
Old 03-16-2016, 10:46 PM   #77
Teseo
Drives: frs
Nvm, its no longer available.
https://www.amazon.com/gp/aw/d/B00ED...el+spacer+25mm
Old 03-17-2016, 12:03 PM   #78
Husker BRZ
Go Big Red!!
Those look like they should work for you.
The Following User Says Thank You to Husker BRZ For This Useful Post:
Teseo (03-17-2016)
Old 03-21-2016, 09:28 AM   #79
pioneer1109
Drives: 2014 red subaru brz
30mm back?
dose anyone have 30 mm in the back and 25 in the front with coilovers?
pioneer1109 is offline   Reply With Quote
Old 03-02-2017, 10:31 AM   #80
CkOne
Drives: FR-S RS 1.0 #1037/1500
sorry to bump of old thread but this is exactly the setup im looking for! do you have any more pics of this setup?
CkOne is offline   Reply With Quote
Old 03-06-2017, 07:59 AM   #81
Esseff
Drives: 2017 BRZ Ltd White
Presumably you guys are all part of the 'looks > performance' crowd.
I*expect you realize that there is a reason for the relative difference in the front and rear track, and simply pushing your*wheels out as far as you can get them will screw with the balance of the car.
Esseff is offline   Reply With Quote
Old 03-06-2017, 10:18 PM   #82
Husker BRZ
Go Big Red!!
Pretty sure most of us know that... I did it only as a temporary solution before I got the tire setup I really wanted.
Old 03-13-2017, 10:14 AM   #83
LowAndSlowBecauseNoTurbo
FRS 10 series #0239
LowAndSlowBecauseNoTurbo's Avatar
Drives: #0239 FRS 10 series silver ignition
Stock wheels, stock height. I'll post pictures after I install the eibach sportline springs I just ordered👌🏼
Front is 25mm and rear is 30mm stock height
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239
LowAndSlowBecauseNoTurbo is offline   Reply With Quote
Old 05-25-2017, 03:49 AM   #84
maximtheg
Drives: 2015 scion FRS
My apologies for bringing back this thread, but I'm a noob and I have some questions. Will I need extended studs with any wheel spacers? I'm thinking about running the 20,25 setup. Thanks!
maximtheg is offline   Reply With Quote
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 08:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 11:43 AM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 08:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
