Old 03-14-2016, 09:55 PM   #13791
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
I'm shopping around currently for coils, fender turn signal and 4th brake lights.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 03-15-2016, 04:06 AM   #13792
DGMlJDlBRZ
DGMlJDlBRZ's Avatar
Drives: 2014 DGM BRZ
Got the RacerX LCAs, toe arms, and end links installed. Now onto the alignment shop...
DGMlJDlBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to DGMlJDlBRZ For This Useful Post:
kch (03-15-2016), raven1231 (03-15-2016)
Old 03-15-2016, 05:56 AM   #13793
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by pfaffendorn View Post
I put the same mud flaps on mine (but with gray branding, of course). At least I didn't suffer a scrape before I got them. I actually liked the sleek fit of the OEMs better, but they looked like they wouldn't fend off anything. Installation was not too problematic, but there is one screw on each rear flap which will never be tight, until tire rotation anyway.
Dang, I have never liked blue cars, but y'all have shined up your WRB Z's SO pretty!
Thanks! I ended up removing the rear tires just to get to that one screw.
Originally Posted by kch View Post
Installed the Racer X Fabrication oil cooler tonight. Mounts to the crash beam with a Setrab 619 core. A lot of oil cooler kits use this core, but the @racerx1715 mounting brackets, hardware, and sandwich plate were tip-top quality and are what really set this kit apart. Fitment was a little tight with stock airbox, but I made it work.
When you change the oil filter does the oil leak everywhere? Other oil coolers have some kind of catch but this one appears not to.
Trueweltall is offline   Reply With Quote
Old 03-15-2016, 10:42 AM   #13794
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have no issues with oil spillage with my Maximal oil cooler (using a similar design of sandwich plate) as long as I let the oil drain out of the filter for a while. I just change the filter last (after draining the oil) and everything stays clean.
Old 03-15-2016, 12:48 PM   #13795
kch
Senior Misanthrope
kch's Avatar
I don't know yet, as I literally just installed it. But in the past when I've done my oil changes, I don't recall there being more than one or two drops that came out of the filter. I'll just give it 30m to sit before removing.
Edit: even if it does spill onto the plate, it'll still get caught by the cup below. I'll just have to wipe down the plate.
Old 03-16-2016, 12:03 AM   #13796
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Finally got a few decent photos of my newly-installed parts:
- KW V3 Coilovers
- ICON Coilover Covers
- Raceseng Cas/Cam Front Plates
- Velox Rear LCAs
- Gorilla Mud Flaps
- HRE FF15 Wheels (18x9+40, Tarmac)
- Michelin PSS Tires (255/35ZR18)
No, I'm not going any lower, lol. Just wanted to kill the massive fender gap, but I'm not a fan of the wheel-under-fender look. I like when a small gap is maintained all the way around, to keep the wheel/tire separated from the body. The flaps were not for looks, but to protect the paint from the much wider wheels.
Man this thing changes direction so quickly now it's hilarious.
Stang70Fastback is offline   Reply With Quote
The Following 9 Users Say Thank You to Stang70Fastback For This Useful Post:
ajaxthebetter (03-16-2016), B-R-Z (03-16-2016), brzest (03-16-2016), DGMlJDlBRZ (03-16-2016), DocWalt (03-16-2016), Husker BRZ (03-16-2016), nisti (03-16-2016), RobertPaulson (03-16-2016), x1UP (03-16-2016)
Old 03-16-2016, 01:35 PM   #13797
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Did something whimsical/non-functional last night: I added an 'S' emblem to my trunk in the same position the TS emblem is placed. Since it's not an STI or TS build, I decided to designate it my own model 'S', which I shall claim stands for 'shiumai, supercharged, sport'...whatever. The S is STI pink and comes from the Subaru WRX STI S204 trunk emblem, so at least it's a Subaru emblem.
shiumai is offline   Reply With Quote
The Following 2 Users Say Thank You to shiumai For This Useful Post:
nisti (03-16-2016), trd87t (03-16-2016)
Old 03-16-2016, 04:06 PM   #13798
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 03-16-2016, 04:20 PM   #13799
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
You should ask Jason@DSG about the fortune auto's they sell. I have a set I just put on and was blown away with how they preform
Old 03-16-2016, 06:02 PM   #13800
chas3wba0
chas3wba0's Avatar
Drives: Yes
Cousin, is that you?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
BRZeer (03-29-2016)
Old 03-16-2016, 07:07 PM   #13801
x1UP
One & Done (AOZORA)
x1UP's Avatar
- KW V3 Coilovers
- Velox Rear LCAs
- Gorilla Mud Flaps
This is so clean! I love it! Nice build and nice job!
The Following User Says Thank You to x1UP For This Useful Post:
Stang70Fastback (03-16-2016)
Old 03-16-2016, 07:23 PM   #13802
shiumai
shiumai's Avatar
It is! It is, cuz!
LOL - 'S' and 'R' are probably the most common 'special edition' letters used on cars. That's why it isn't too much of a stretch.
Old 03-16-2016, 07:51 PM   #13803
Stang70Fastback
A.K.A. Starlord
Thanks, boo! Trying to go with a simple, clean black and blue theme
Old 03-16-2016, 07:55 PM   #13804
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
I just installed my Rexspeed wide anti-glare mirrors and I couldn't be happier! I tried my best to get an accurate before/after comparison below:
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following 3 Users Say Thank You to mixtape For This Useful Post:
DocWalt (03-16-2016), echo419 (03-17-2016), nisti (03-16-2016)
