Old 03-15-2016, 10:44 PM   #1
edigeek
Drives: 2014 White BRZ Limited
Question is 2013 pearl white same color as 2014 model?
i'm buying door panel from a 2013 BRZ for my damaged 2014 BRZ. They are obviously both white (satin pearl white) but I did a search for color codes on http://www.paintscratch.com and this is what I got.
Subaru BRZ
2013: 37J
2014: 37J/EH6
Does this mean they are different? After doing my research in the forum I heard that they are both the same, what do you guys think? for your help.
edigeek is offline   Reply With Quote
Old 03-16-2016, 12:49 AM   #2
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Originally Posted by edigeek View Post
Subaru BRZ
2013: 37J
2014: 37J/EH6
I have seen cars which were nominally the same color, from different model years, and when I checked the color codes, they were different. I believe that if you're not going to paint the door, be sure the color codes on the two cars match.
If you plan to paint the door, same deal -- be sure your BRZ and the paint can have the same color code. In your situation, it sounds like being completely sure of the color would be quite important; and the best way to be sure is to match the color code.
(The "similar threads" section below seems to be all about different shades of white in different model years. I'll bet you find something helpful there, but I'd avoid any mention of the FR-S; some folks post stuff about their Scion in our BRZ forum, and that could lead to a serious mistake.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 03-16-2016, 01:54 AM   #3
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
The 2105+ BRZ switched to the K1X crystal white color, but 13 and 14 have the same color. You should be fine mate. Probably.
MalcolmHimself is offline   Reply With Quote
Old 03-16-2016, 06:20 AM   #4
edigeek
I also checked colors for 2013 and 2014 frs and they are both 37J (same website) aren't both cars made in the same factory though?
Old 03-16-2016, 09:07 AM   #5
gtslow
Drives: 2015 Halo FR-S
Is EH6(C) the clear coat or the code for the pearl? I just googled EH6 and it seems to pull at this site with 37J:
http://paintref.com/cgi-bin/colorcod...Subaru&rows=50
Keep in mind that if you were going to spray a new panel, you would primer, base coat (white), pearl and finally clear coat.
gtslow is offline   Reply With Quote
2014 BRZ Limited MT, Satin White Pearl, 603 miles, WA Torebaa Cars for Sale/Trade 5 08-18-2015 09:00 AM
Used Dr Color Chips 37j white out pearl GodSays Cleaning and Detailing 1 07-14-2015 02:29 PM
FS: CA (SoCal) 2014 Stock Pearl White BRZ Premium 17,000mi w.k.s. Cars for Sale/Trade 6 03-29-2015 11:40 PM
Color difference between Satin White Pearl (Pre-2015) and Halo White (Post-2015)? LucidMomentum Scion FR-S / Toyota 86 GT86 General Forum 3 10-15-2014 12:29 PM
SOLD - 2013 Pearl White FR-S mtbikingrulz Cars for Sale/Trade 13 04-22-2014 01:18 AM
