Old 08-20-2015, 12:48 PM   #57
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Originally Posted by xkalelx View Post
A note about the bleeders on the Brembos. They are installed from the factory with red loctite. You have to use a torch to weaken the seal and they come right out. http://www.ft86club.com/forums/showthread.php?t=90441
Car looks awesome by the way!
Thanks! Yea the older calipers were a definite no-go. The brand new ones I was able to remove all but one of the allen plugs by hand and then used a torch to heat and unscrew. Not an easy job if you have older/heavily used calipers however!
kuczynskika is offline   Reply With Quote
The Following User Says Thank You to kuczynskika For This Useful Post:
xkalelx (08-20-2015)
Old 09-02-2015, 02:45 PM   #58
kuczynskika
Photo update
Trap63 (12-07-2015)
Old 09-02-2015, 07:58 PM   #59
kvnbarillas
Drives: STEEL SCION FR-S
I really like the caliper. They look great!!
Did you notice any kind of change in the brake bias with these calipers?
kvnbarillas is offline   Reply With Quote
Old 09-02-2015, 08:01 PM   #60
kuczynskika
I haven't tracked them so no. Under super hard (sudden stop/trip abs) braking you can feel the back end get a little squirmy. I'm sure better tires would help tho
Old 09-24-2015, 07:02 PM   #61
kuczynskika
No new parts, but I got some new plates
Old 10-17-2015, 07:11 PM   #62
kuczynskika
Found a fellow 86er today.
The Following 2 Users Say Thank You to kuczynskika For This Useful Post:
chaoskaze (11-25-2015), Trap63 (12-07-2015)
Old 11-25-2015, 05:12 PM   #63
JerryIII
Drives: Subaru BRZ
edelbrock has already started to develop smaller pullies i have not seen anything out of the cosworth camp
JerryIII is offline   Reply With Quote
Old 01-27-2016, 01:35 PM   #64
eromsdal
ERO
eromsdal's Avatar
Drives: '16 Subaru BRZ Series Hyperblue T
Brake bleeder plugs
Originally Posted by kuczynskika View Post
update on the calipers...
This installation has been very painful. Realized the front drivers side caliper, top bleeder is leaking. The seat is ruined from drilling out the original bleeder cap and rethreading. I was forced to cap the bleeder with a brass screw-head to keep from leaking brake fluid. I Installed the calipers and equipment and it is still leaking. Before this weekend I thought this installation would be relatively easy, but now I am starting to reconsider. Complication after complication has made this process ridiculous.
Most likely going to have to go back to the stock setup and get a new brembo caliper to replace the ruined one.
Did you buy new plugs when you swapped the bleeder position? If so? Where and which plugs did you buy? I'm having a hard time locationing the correct plugs.
eromsdal is offline   Reply With Quote
Old 01-27-2016, 05:25 PM   #65
kuczynskika
The first time when I tried the swap and ruined the 1st set of calipers I bought new bleeders and used those to cap the ends since I drilled through the allen plugs.
Second time I did the swap I used brand new calipers and with some heat I was able to remove the allen plugs and swap them with the bleeder plugs without problems.
Like you I tried to buy allen plugs but they are not available anywhere.
eromsdal (03-17-2016)
Old 02-02-2016, 10:43 PM   #66
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
very nice
Atticus808 is offline   Reply With Quote
The Following User Says Thank You to Atticus808 For This Useful Post:
kuczynskika (02-03-2016)
Old 03-15-2016, 09:58 PM   #67
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
hey kyle, did you replace your wheel studs for your 5mm rear spacer?
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
Old 03-15-2016, 10:08 PM   #68
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Any updates on power options you may do?
MS, CSCS, TSAC-F, CPT
Old 03-15-2016, 10:10 PM   #69
kuczynskika
What's up. Yes, I did. They were included with the HnR kit. They seemed short but I got about 6 1/2 turns out of em. I'm lookin at going bigger to 5mm front and 15mm rear. Btw... Bought some black mirror covers. Thanks for your help!
chermo12 (03-16-2016)
Old 03-15-2016, 10:11 PM   #70
kuczynskika
I'm looking seriously at Harrop and edelbrock. Harrop more so. Need monies tho!
weederr33 (03-15-2016)
Cosworth SC build... Ernie L Member's Car Journals 184 09-10-2015 04:25 PM
What did YOU do with your Cosworth plaque? weederr33 Engine, Exhaust, Transmission 31 02-24-2015 04:23 PM
Cosworth worth the $$$$? EAGLE5 Off-Topic Lounge [WARNING: NO POLITICS] 28 02-24-2015 01:12 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
