| Software Tuning Discuss all software tuning topics. |
Drives: 2013 Scion Frs 6mt
oft "file not compliant"
trying to upload a new tune to my oft and it says file not compliant any help?
never happened before. |
#2 |
figured it out thanks to Shiv. great guy. buy his oft.
| The Following User Says Thank You to Nah For This Useful Post: | tato.valverde (03-17-2016) |
#3 |
#4 |
Drives: 15' Raven FR-S
I got the same issue too, trying to upload the UEL F40C.bin but getting the "file not compliant".
#5 |
Drives: FT86
#6 |
Oh I see, I have D00C. So in that case if Shiv updated any files for example "D00C" be updated? Ive seen lately he was beta testing a new UEL 91oct map.
#7 | |
Drives: FT86
_
however you need to use the rom calid that was originally in your car when uploading tunes to your oft the "tune" in the oldest 400C rom is same as the latest F40C roms the new beta test rom changes have not been released yet, but when they are all rom calid will be updated Last edited by steve99; 03-16-2016 at 08:46 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | Tcoat (03-16-2016) |
#8 |
so i used shiv's vvt angles for the jdl uel header and WOW... I cannot believe how much my car has improved. can anyone chime into as in why retarding the exhaust cam angles in the vvt tables drastically improved the fa20?
LTFT at wot are at .78 now so no need for me to mess with the MAF scaling I am however, going to mess around with base timing b any tips as in to where i can tap some more usable power? thanks guys. oh and if you haven't changed your throttle response do it! so much easier to drive down low. |
#9 | |
Drives: GT86
My base map was the RON98 though, results may vary. Be careful. Gesendet von meinem Jolla mit Tapatalk |
#10 |
yes I would never add lets say 10 degrees advance just cause... a couple here and there wont hurt...
When i added five degrees up top IAM dropped to .9 so I realized that adding timing in the upper rpms did absolutely nothing. Good for me to experiment, oh that and I could tell my by just listening to the motor it did not like the extra advance. Im gonna do some small increments later tonight and see what happens, for now I have been messing with throttle response. question for you guys, VVT angles on the exhaust /intake can anyone explain exactly what happens when you advance or retard those? |
#11 | |
Drives: UK GT86
For the latter question, go read the AVCS thread that's floating around.
.: Stealth 86 :.
#12 |
Read the thread...very good stuff... Do you know when exactly our intake and exhaust cams open up?
#13 |
Drives: UK GT86
How do you mean open up? The info is in a pdf attached to a post early in the thread before my spreadsheet calculations for overlap etc.
.: Stealth 86 :.
#14 |
I guess what degree does the intake cam and exhaust cam hit TDC their crossover point? Sorry if I'm not specific enough? I am under the impression that there is a certain degree where the intake cam is closed then opens at a certain degree of advance, then there is the cross over point and the same happens to the exhaust cam?
| OFT "Error in opening the file", Now Bricked | kodyo | Software Tuning | 48 | 03-01-2016 10:27 PM |
| OFT - The File Selected Is Not Compliant | Kody | Software Tuning | 8 | 08-18-2015 06:01 PM |
| Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 11:17 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 07:34 PM |
