Old 03-13-2016, 03:47 AM   #1
STZ
Drives: '15 WRB BRZ Sport-tech
Flasher Relay Help
Hey guys, I'm looking for some help regarding the flasher relay under the steering column.
No matter what I try, I can't seem to un-attach it. Am I hitting the wrong spot with my flat-head? Do I hit the hole in the white part (clip), or the tiny little slot on the flasher itself?
Also, from using search, it seems some people gave up and just pulled downwards on it to remove it via brute force. Is this just easier and I should say fuck it and do this?
Any suggestions or help would be greatly appreciated.
STZ is offline   Reply With Quote
Old 03-13-2016, 07:52 AM   #2
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
I had the same issue. I ended up sliding the bracket that holds the relay off of the column to gain better access. After that, it came right off since I could actually see what I was doing and was able to get 2 hands on it.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following User Says Thank You to Joyride86 For This Useful Post:
STZ (03-14-2016)
Old 03-13-2016, 04:34 PM   #3
STZ
I was thinking of doing this too.
Do you still remember where the flathead goes to remove the thing?
Is it in the little gap on the relay itself, or on the white clip?
Old 03-13-2016, 06:19 PM   #4
LED86
LED86's Avatar
Drives: Black 86 GTS
My advice is don't even bother trying to remove it. Just disconnect the connector and plug in the new one then tape it so it doesn't knock around.
LED86 is offline   Reply With Quote
The Following User Says Thank You to LED86 For This Useful Post:
STZ (03-14-2016)
Old 03-13-2016, 08:42 PM   #5
wtfrs
Drives: 2014 Monogram
When I did mine I just pried it off with a flathead, it's just a annoying plastic peice holding it in, or just tape it like he says.
wtfrs is offline   Reply With Quote
The Following User Says Thank You to wtfrs For This Useful Post:
STZ (03-14-2016)
Old 03-13-2016, 09:11 PM   #6
Joyride86
Joyride86's Avatar
I want to say the gap was on the relay. I used a very small screwdriver and pushed it in the gap and pried it up. It's weird how it was super easy for some, but a stubborn bitch for others.
STZ (03-14-2016)
Old 03-13-2016, 10:27 PM   #7
STZ
I was trying this too the other day. I couldn't pull it off :X.
Where's the clip on the connector, and how many clips are there? Just from blindly feeling I found one clip on the top, but holding that down and pulling yielded no results.
Old 03-13-2016, 10:55 PM   #8
LED86
LED86's Avatar
Just the one push pin at the back like you described. It's a pain due to angle but keep trying.
STZ (03-14-2016)
Old 03-13-2016, 11:21 PM   #9
NahumCC
Drives: 2013 FR-S 10 Series
You need a very thin and short handle screw drier. The angle just makes it a bear. The thiner the blade of your flat tip the easier it'll be to get into the slot and actually get it to release. A short and skinny handle will help give you more room to angle upward before contacting the structure of the steering column.
NahumCC is offline   Reply With Quote
The Following User Says Thank You to NahumCC For This Useful Post:
STZ (03-14-2016)
Old 03-14-2016, 12:56 AM   #10
wtfrs
Also look at the new flasher relay and you can see where it slides into the plastic clip and so just mirror it
Old 03-14-2016, 01:20 AM   #11
STZ
http://puu.sh/nFSoy/969dd6f0a1.jpg
Jam the screwdriver in that gap on the relay then?
Old 03-14-2016, 01:24 AM   #12
NahumCC
Yup, in that photo on the bottom of the gray portion. That little lip is the retainer to the chassis of the car.
Old 08-29-2019, 10:01 AM   #13
Zoik
Drives: 2013 black gt86
I also unplugged the oem relay,left it mounted, plugged my new flasher relay. tested, it wirked, dodnt bother to attach it
Zoik is offline   Reply With Quote
Hyper flasher relay questions IgamaS Northwest 11 06-26-2015 12:04 AM
OEM Tail Lights and OEM Flasher Relay $120 OBO BG.Ghost8 Canada Classifieds 0 08-12-2014 11:56 AM
LED flasher relay module alternatives ucsmfu Cosmetic Modification (Interior/Exterior/Lighting) 23 03-18-2014 12:12 AM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 02:58 PM
WTB: OEM Flasher Relay CanibeatNoel Interior Parts (Incl. Lighting) 1 03-23-2013 01:19 AM
