Northwest AK, ID, OR, WA
Old 02-19-2015, 09:38 PM   #1
IgamaS
Drives: 2015 Whiteout FRS
Hyper flasher relay questions
Hey I know this is a stupid questions but for those who are running led front or back turn signals. What hyper flash relay unit are you using? Ive bough my from Vled in Bellingham and hey are great but the delay of my turn signals working properly is kinda getting to me now. Any suggestion on which unit to use that doesn't have a delay when initial turn signaling?
IgamaS is offline   Reply With Quote
Old 02-19-2015, 10:00 PM   #2
Burrcold
Drives: Subaru BRZ Limited
Easy...
http://www.ft86club.com/forums/showthread.php?t=33477
Old 02-19-2015, 10:36 PM   #3
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
that also comes with most aftermarket taillights so if you're planning to upgrade those you could kill two birds with one stone.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 02-19-2015, 10:59 PM   #4
Burrcold
You get a hyper blink relay with aftermarket lights but it doesn't address the turn signal delay. TapTurn does exactly that and more. Amazing product.
Old 02-19-2015, 11:00 PM   #5
RobertPaulson
Drives: 2017 Golf R
Ah, that's good to know. i've only replaced my taillights, headlights and fogs.
Old 02-19-2015, 11:11 PM   #6
Burrcold
If you've replaced your taillights and installed a new flasher relay you should still have a slight delay when you put your turn signal on. Perhaps you haven't noticed it?
Old 02-20-2015, 02:16 PM   #7
RobertPaulson
Drives: 2017 Golf R
hmm, no noticeable delay, i'll try to pay attention for it next time i take the car out.
Old 02-20-2015, 03:26 PM   #8
starron
Drives: FRS 10 Series
Compare to the cheap led relay I had before, tapturn has real small to no delay at all. Highly recommended tapturn
starron is offline   Reply With Quote
Old 02-20-2015, 06:18 PM   #9
IgamaS
Thank you
Old 02-20-2015, 07:31 PM   #10
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
If you're ok spending $100+ on the little tiny $10 part that's customized and programmed properly, then yes Tapturn is great. I'm a tightwad sometimes so I can't justify spending the money on one when the one that comes with the Tom's tails works, even though they have an annoying delay. just turn the blinker on sooner is all I do.
stockysnail is offline   Reply With Quote
Old 02-26-2015, 07:49 PM   #11
Koa
installed tom's before my switchbacks and didn't notice a delay.. switchbacks def did. Thanks tapturn!
Old 06-26-2015, 12:04 AM   #12
BRZseriesblue
Drives: 2015 Subaru BRZ Series.blue
I used the toyota relay off amazon (part number in video) for the past 4-5 months with no issues. I have led tail signal and stock front signals. Check out my video showing the delay which isn't bad at all. [ame]http://youtu.be/4ivLIQetWEo[/ame]
I also have one showing lock/unlock function. [ame]http://youtu.be/8pUW0x4squc[/ame]
BRZseriesblue is offline   Reply With Quote
OEM Tail Lights and OEM Flasher Relay $120 OBO BG.Ghost8 Canada Classifieds 0 08-12-2014 11:56 AM
LED flasher relay module alternatives ucsmfu Cosmetic Modification (Interior/Exterior/Lighting) 23 03-18-2014 12:12 AM
LED lighting upgrade and Flasher Relay. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 20 07-22-2013 08:44 PM
WTB: OEM Flasher Relay CanibeatNoel Audio/Visual, Electronics, Infotainment, NAV 2 05-01-2013 02:58 PM
WTB: OEM Flasher Relay CanibeatNoel Interior Parts (Incl. Lighting) 1 03-23-2013 01:19 AM
