| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#43 |
Drives: 2013 Scion FR-S 10 Series
I've run Millers Oils CFS 0W20 NT for 4,000 miles so far and plan to do my first oil change at 6,500 miles since I started using it - I always have Blackstone Labs perform an analysis, so I'll post it when I get the results.
I don't have a dyno report to support my claim, but my engine was perceptibly more 'free' after I changed over to it. Can an oil actually improve performance? It's hard to say definitively (without data) and maybe there's a placebo effect when paying this much for oil, but my seat of the pants impression was that it did just that - the engine felt noticeably stronger and it revs more quickly. Enough said - highly recommended. |
#44 | |
Drives: 92 Prelude
Edit: nvm just went through the thread lol
#45 | |
Drives: 92 Prelude
#46 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Still running great. Sticking to 3-5k intervals for now and that's not bad on the wallet considering I've averaged 5k miles/year on the car over 3 years.
#47 |
Drives: 92 Prelude
I did the switch, my engine sounds quieter that's for sure lol not sure if it good or bad.
#48 |
The Fail Boat
Drives: CWP S.B.
^ nice! More smooth can only be good I presume.
since it's mostly valve train noise?
#49 |
Drives: 92 Prelude
Yeah, don't know if I can feel a bump in performance but definitely is smoother and quieter
#50 |
Isn't that possible margin of error or different conditions from baseline? I guess to check that you would need someone to dyno @ stock, then same day as close to same conditions as possible swap oil out drive for a bit to break the oil in, cool down then dyno again for that "power gain"
#51 |
Drives: 92 Prelude
Something different that is occurring after I switched oils is on start up originally it used to shoot up to 1500 rpm then slowly go down.
Now it shoots up to 1000, then 0.25 seconds later goes to 1500 then goes down. It feels like its forcing itself go to the 1500rpm threshold on start up. I wonder why this is...
#52 | |
Drives: 92 Prelude
#53 |
My car currently has 6,100 miles, so I'm getting very close to changing the oil - I'll post the results of the analysis as soon as I get it. Thanks for your patience - so far, I'm a real believer in Millers Oils!
Last edited by RJasonKlein; 03-12-2016 at 12:04 AM. Reason: Corrected a typographical error. |
| The Following User Says Thank You to RJasonKlein For This Useful Post: | ATL BRZ (03-12-2016) |
#54 |
Drives: 92 Prelude
I have it as well but I'm not sure if I got used to it or what but I'm starting to forget what the power difference felt like lol!
| Oil Analysis - 1st oil change | R L Newb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 375 | 11-19-2021 09:24 AM |
| P1 at Miller Motor Cars | Tgionet | NY / NJ / CT / PA | 9 | 03-01-2014 12:48 PM |
| Used Oil Analysis Results | Captain Snooze | Engine, Exhaust, Transmission | 2 | 11-21-2013 12:59 PM |
| R Miller Auto Lipster kit | nixeighty6 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 03-08-2013 02:58 PM |
